Homemade door solenoid/popper ideas?
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Thu May 01, 2014 4:21 pm    Post subject: Homemade door solenoid/popper ideas? Reply with quote
Thinking about doing this modification, Anyone here done it before? What cars did you rob parts from?
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Fri May 02, 2014 8:50 am    Post subject: Reply with quote
GM Cars Trucks and Vans of the 80's -mid 90's have some pretty strong door lock actuators. They have a nice long stroke too.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
sixfootdan
Samba Smartass
PostPosted: Fri May 02, 2014 10:16 am    Post subject: Reply with quote
Ok so that would pull the latch but you would also need something to push out at the same time. It could be electric or just a simple spring. I'll post pics as I go but post your pics too.
GO SEAHAWKS!!!
VOLKSWAGNUT
PostPosted: Fri May 02, 2014 10:23 am    Post subject: Reply with quote
Those ^ GM actuator motors are fully reverseable depending on polarity used. It will either push or pull, or you can use a power window type switch (or switching relays) to make it fully funtional to both push and pull.. depending on switch posistion..
They are not intally "sprung".. so work well just incorporating to the standard door rods or use with a cable.
I simply make a bracket and create a "leg" off the original door rods to be able to keep full manual function as well.
It really depends on the door and latch used on too, not all are the same mod..
Pretty versatile...
As for making the door "pop" open... Create = mini tubing to create a bucket and a strong spring and pin to the lower door pillar to spring the door open when the electric is pressed.
Near the latch is best.
I have use old auto trans valve body springs... Wink Quite strong and small.
Of course.. door popper springs can be bought Razz
Its amazing sometimes what you can find and adapt from hardware store too.
aka Ken {o\!/o}
sixfootdan
Samba Smartass
PostPosted: Fri May 02, 2014 11:22 am    Post subject: Reply with quote
I figured if the popper was close to the latch it would work best. I have access to lots of metal so I was thinking of a spring tab sort of deal. It would not need much to pop it.
GO SEAHAWKS!!!
1972BUG
1972BUG is offline
PostPosted: Sun Jun 08, 2014 8:57 pm    Post subject: Reply with quote
Another option is to go very old school and utilize starter motor solenoids. You have find the right solenoid and modify the bendix fork but it is fun. Door popper springs I like using hood springs. Just somethings I have done.
retterath
retterath is offline
PostPosted: Tue Jul 15, 2014 8:57 pm    Post subject: Reply with quote
I shaved the door handles on my truck, and the seals are usually enough to push them open.
whiskeyandsawdust
whiskeyandsawdust is offline
PostPosted: Fri Mar 20, 2015 2:37 am    Post subject: . Reply with quote
Did you ever do this?
sixfootdan
Samba Smartass
PostPosted: Fri Mar 20, 2015 5:49 am    Post subject: Re: . Reply with quote
No sorry I have not touched this idea in a while. Laziness, Working overtime a lot, and moving are to blame. Laughing
GO SEAHAWKS!!!
