jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Sun May 11, 2014 4:29 pm Post subject: |
Got all excited and found a black case behind the seat today when pulling it all out. I was hoping it would be full of money but it was full of cassette tapes.
Then my wife was playing around with the aircraft stripper and the roof metal looks nice underneath but damn there's a lot of paint on there.
_________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sun May 11, 2014 7:14 pm Post subject: |
jpjohns wrote: |
Then my wife was playing around with the aircraft stripper ... |
Sounds like she's a keeper! |
Posted: Sat May 24, 2014 7:02 pm Post subject: |
So I couldn't do much today so I started stripping the lower front fender in front of the door. Lots of bondo, but it looks like someone tried to do a bad weldjob.
Still not sure what the original color was, LOL. I thought at first the blue was a guide coat for the bodywork but it's metallic.
Primed it just to stop flash rust since it's still outside.
I guess the PO didn't like the original antenna location so he decided to do another crappy weld job.
Posted: Sat May 24, 2014 7:08 pm Post subject: |
This was under the carpet, I guess he needed to cut the tunnel and didn't want to do another crappy weld job.
SO, I was trying to figure out how to get the seats out and it looks like they were attached to another floorpan then welded over the existing pan. The rear looks like there are 3 layers of metal. I'm thinking a halfpan was welded over another one.
Another hackjob radio install
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Sun May 25, 2014 7:18 am Post subject: |
Man that ghia had some mean people in its past. Once you get your patch panels and welding equipment go slow. Keep a rag in a bucket with water handy to cool the metal as you weld. Warping is a big problem.
Good for you for showing it some love. _________________ 63 ghia coupe |
Posted: Sun May 25, 2014 4:39 pm Post subject: |
Will do, thanks. What's sad is, that's a pretty common repair...to weld in a new pan over the old one.
Found this in the glove box, this is apparently who did an earlier resto, if you can call it that.
Posted: Thu May 29, 2014 4:02 pm Post subject: |
So I never noticed this but after cleaning this tag I've found that the body doesn't match the chassis. The chassis #148995359 is and the body number is 148566668 but at least it's all '68. Kinda sucks but it's still all there and will make a great driver.
vstylist Samba Member
Joined: April 25, 2010 Posts: 106 Location: Edmonton, Alberta
Posted: Fri May 30, 2014 9:03 am Post subject: |
So then it wouldn't matter if you found a decent pan to switch to??
Posted: Fri May 30, 2014 10:46 am Post subject: |
My chassis is actually pretty decent except for the floorpans. The body however, needs alot of loving. _________________ -Jared
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Fri May 30, 2014 10:59 am Post subject: |
jpjohns wrote: |
My chassis is actually pretty decent except for the floorpans. The body however, needs alot of loving. |
Yep, your car's body makes mine look good. Every time I get despondent about the amount of work I have to do, I look at yours, take a deep breath, and get back to the job at hand. There is hope for both of us, I think, although many would have abandoned our cars to the crushers. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Fri May 30, 2014 2:16 pm Post subject: |
kiwighia68 wrote: |
jpjohns wrote: |
Yep, your car's body makes mine look good. Every time I get despondent about the amount of work I have to do, I look at yours, take a deep breath, and get back to the job at hand. There is hope for both of us, I think, although many would have abandoned our cars to the crushers. |
I wont abandon this one. I mean think about it. In 1969 they made 27,000 Karman Ghias and I have one of them, vert owners are even more lucky. 27k may sound like a lot but it's not seeing what car makers pump out now. _________________ -Jared
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Fri May 30, 2014 2:55 pm Post subject: |
kiwighia68 wrote: |
jpjohns wrote: |
I probably should have. In the 9 years between the time I got my ghia and the time I started working in it I took a welding class then got a 2 year certificate in autobody at the community college, then spent 4 years working in a collision shop. Almost, but not quite long enough to hate cars. |
Posted: Mon Jun 02, 2014 7:45 pm Post subject: |
Finally got the seats out, what a pain. Removed the nasty smelling upholstery from one. Found a couple spots on the seat frame that need to be welded. Still they used '69 seats but I'll take them back to '68 headrests.
Still not sure why they did the seat rails like this, but then again they welded a pan over the old one so.....
Went ahead and cleaned up the taillights with the homemade soda blaster and shot some Rustoleum Chrome paint on the right one for comparison.
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Jun 03, 2014 5:04 pm Post subject: |
Have you thought up a name for your Ghia? Could call it Boccaruni- sounds Italian; pronounced botch-a-rooni. I've never seen seat rails botched in so poorly! And you're still in the "discovery" phase from the poor car's POs...
I certainly hope you stick with the rebuild and bringing honor back to the car! |
Posted: Tue Jun 03, 2014 6:58 pm Post subject: |
Rome wrote: |
Hahaha, no kidding. It's sad to think the person that did work on the car in the past actually thought it was a good job. I think a 10yr old with a MIG welder could have done it better. Every project has that point where you say "OMG what the hell did I get myself into" and this is definitely it but thinking about how much better the car will be when it's done right and I can say I did it makes it worth it. _________________ -Jared
Posted: Thu Jun 12, 2014 7:21 pm Post subject: |
Removed the 29PICT-1 carb, good thing it's going to be replaced with a Weber.
Not quite sure what the screw is shoved in the hole for...LOL
Looks a little cleaner
Posted: Thu Jun 12, 2014 9:21 pm Post subject: |
jpjohns wrote: |
Finally got the seats out, what a pain...Still they used '69 seats but I'll take them back to '68 headrests.
It's not a big deal to go back to '68 high back seats. All you need is the rail at the top providing the contour for the integrated headrest. Those rails slot into the seat rails at the sides near the top. If you need a photo, let me know. Been there and done that. _________________ Festina lente - hasten slowly
Posted: Fri Jun 13, 2014 5:50 am Post subject: |
jpjohns wrote: |
Off hand, I'd guess he used a screw because he couldn't get a nail to stay in as well.
Posted: Sun Jun 15, 2014 6:34 pm Post subject: |
So the engine is looking to be somewhat original after all, possibly a 1200 due to the 28PICT-1 carb. The AK looks to be just a replacement case.
No doghouse, definitely will be upgraded to one with a MAMO kit.
Old style generator, thinking about converting to an alternator...still debating
Definitely old style oil cooler bolted on top of the block
Posted: Wed Jul 09, 2014 7:11 am Post subject: |
Any new progress? |
