jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Wed Jul 09, 2014 8:49 am Post subject: |
Ha, yeah. I've been cleaining/painting engine tins, just haven't thrown up any pics. I was in MN for a couple weeks for work and got back last week. It's been so hot and humid outside I've been kind of motivated to get the garage cleaned out so I can push the car in and work in the A/C.
Next couple of weeks will be slow going, I have take my son to VaBeach this weekend and pick him up next weekend. Then we have a vacation at a family cabin in Gatlinsburg TN.
Still fighting with the damn DMV for the title (bastards) but that's another story. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Posted: Tue Jul 22, 2014 8:36 am Post subject: |
Got the title...finally. Working on removing the steering wheel ring. The damn PO used an aftermarket wheel and adapter and welded it on to the shaft! I'll post pics later.
Got the speedometer refurbished. The new trim ring from KGPR went right on. I ended up using the end of a BIC pen to crimp the trim ring around the edge without any scratches. Looks good, hope it works well.
Old
Restored
c21darrel Samba Member
Posted: Tue Jul 22, 2014 1:11 pm Post subject: |
Floorpans came in Saturday, set them aside for now.
Damn steering ring still won't come off. Don't know where that plastic ring came from, can't find it on any Ghia steering diagrams. I cut it off, figured it was with the aftermarket wheel.
Tons of heat and it still wont come off. Taking it to work tomorrow to try it on a press.
Who in the hell glues pennies under a fuel tank to seal holes? OMG! I was going to restore this tank, now I'm just buying a new one.
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Tue Jul 22, 2014 1:21 pm Post subject: |
These things are sent to test us, Jared. You can use up a year's allocation of bad words in just one afternoon trying to undo the PO's work.
I like your work on the speedo and will do mine next week. I like the Bic pen idea. I've been wondering how to crimp the new chrome rings on without damaging the,. Thanks for the tip.
Someone said that I was restoring my car from the inside while he was working from the outside inwards. Seeing your new floorpans, I think you are working from the top down towards the bottom.
To each his own. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Tue Jul 22, 2014 6:36 pm Post subject: |
I'm actually working on some pieces as I remove them until I get to the point where I can lift off the body. Then I'll just work on the chassis. I figured that if I check each piece as I remove it to determine if it can be replaced or restored it will make assembly later go faster. _________________ -Jared
Posted: Sat Aug 02, 2014 8:25 pm Post subject: |
Got the steering column parts painted, I think they turned out great. Painted them gloss black. I have to get the new bearing, turn signal switch and ignition installed and then I can put that aside for later.
New front and rear apron arrived, can't wait to start cutting.
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Mon Aug 04, 2014 5:01 am Post subject: |
Yeah, he actually welded the cancelling ring to a VW hub of some sort then attached the steering wheel adapter to the ring. Jackleg stuff I tell ya!
I'm trying to find a Nardi or comparable repro (Flat4 or ISP maybe?) wooden wheel that will go in for a decent price so it will have a proper VW hub and adapter. _________________ -Jared
Posted: Sat Aug 09, 2014 8:18 pm Post subject: |
Finally got he garage cleaned out so we could roll the Ghia in. Now we can start working on removing windows and get the body off.
Bloku Expert Noob
Joined: April 09, 2013 Posts: 559 Location: Tulsa/Jenks Oklahoma
Posted: Sat Aug 09, 2014 10:02 pm Post subject: |
I can't wait to see how this goes. I have not seen someone even look twice at a ghia with problems like this. Good luck, and I will stay tuned. |
ScottDoonan Samba Member
Joined: August 04, 2005 Posts: 546 Location: Northern California
Posted: Sun Aug 10, 2014 2:44 am Post subject: |
Bloku wrote: |
I agree never seen it either . Keep up the good work dedication, consistency and tenacity. _________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Sun Aug 10, 2014 8:13 am Post subject: |
I'm sure it's been said but bag and tag everything. Especially in the doors. Some special countersunk screws that will be tough to find should you loose them. I got lucky. I thought I would be going back together pretty quick then life happened and 5 years later I'm digging through small buckets and boxes looking for everything. Luckily I have another ghia to look at and figure out where things went, and steal from. I have spent hours organizing things as I find them. Save your self the trouble.
Have you found a local VW guy yet? They are worth their weight in vw knowledge.
Good pace keep,it up! _________________ 63 ghia coupe |
Posted: Sun Aug 10, 2014 11:17 am Post subject: |
jpjohns wrote: |
Why don't you get R2 to help you? He looks like he could do with a job stuck all alone in the corner of the garage _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Sun Aug 10, 2014 5:38 pm Post subject: |
Bloku wrote: |
Aw come on.. it's not THAT bad, I've seen way worse.
Quote: |
Why don't you get R2 to help you? He looks like he could do with a job stuck all alone in the corner of the garage Wink |
LOL, I wondered how long it would take someone to comment on that. _________________ -Jared
Posted: Sun Aug 10, 2014 6:42 pm Post subject: |
jpjohns wrote: |
Bloku wrote: |
Aw come on.. it's not THAT bad, I've seen way worse... |
Some Ghias come in for a spit and polish. Some come in for a restoration. And then some, like yours and mine, come in for a resurrection.
Keep going. _________________ Festina lente - hasten slowly
cool karmann collected Samba Member
Joined: November 23, 2008 Posts: 631 Location: Oxford, U.K.
Posted: Tue Aug 12, 2014 2:10 pm Post subject: |
carl4x4 wrote: |
jpjohns wrote: |
Why don't you get R2 to help you? He looks like he could do with a job stuck all alone in the corner of the garage |
R2 would love to help but he's got to get to work on those moisture vaporators
Seriously, where did you get that and what does it do? Let me guess, you use it to serve drinks at your house parties! |
Posted: Tue Aug 12, 2014 5:58 pm Post subject: |
cool karmann collected wrote: |
We actually found him on the curb. Someone was throwing him away He is actually an ice cooler. You fill him with ice and he actually has a drain as well. He was in perfect shape.
Posted: Tue Aug 12, 2014 6:02 pm Post subject: |
jpjohns wrote: |
... We actually found him on the curb. Someone was throwing him away :evil: He is actually an ice cooler. You fill him with ice and he actually has a drain as well. He was in perfect shape.
And I thought a Teddy bear would look good in my passenger seat! _________________ Festina lente - hasten slowly
TheFop Samba Member
Joined: February 03, 2014 Posts: 302 Location: Auckland - New Zealand
Posted: Tue Aug 12, 2014 11:43 pm Post subject: |
How about mounting him on the rear like R2D2 was mounted in the X-wing fighter?
(Sorry for the crappy photo editing skills) _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car |
