truckdude Samba Member
Joined: May 01, 2014 Posts: 148 Location: Beverly Hills baybee
Posted: Sun May 04, 2014 9:38 pm Post subject: truckdude's Spatz Long buggy |
Hi, new to the Samba, just bought my first air cooled VW, a Spatz Long body on a '63 pan with a 1500 motor. I'm pretty sure it is a Spatz. Pretty much a beater right now but the pan seems solid and the motor runs. Goal is to give it a 60's look with white steel wheels and VW caps. Bought it from a super nice guy with a bunch of VW's.
I'll add some pics. |
Posted: Sun May 04, 2014 10:03 pm Post subject: |
350Z wheels on the front have to go!
Top is pretty shot
Rear wheels appear to be 15x8
Lowback seats, I have a friend who does great hot rod upholstery. I'm thinking white tuck and roll.
Back seat is funky
I will detail the engine, add some chrome, lose many lights.
14x5 bus wheels came with it and some caps. Might trade the seller back for some 15's.
New wiring harness ASAP. Probably will get a stock ivory wheel.
Cleaned a ton of crud off the front end.
I guess this is an oil pressure gauge?
Now I know why VW's float and pans rust. I dried this up.
Other projects, '27 T touring on a Model A frame, 8BA flathead, Merc OD trans and '66 Chevy hot rod pickup.
Bob Elgin Samba Member
wvbowtieman Samba Member
Posted: Mon May 05, 2014 1:06 pm Post subject: |
Bob Elgin wrote: |
well the hood is Spatz, but the body looks like a manx. |
X2
That's what I was thinking...Block sanded every square inch of a Manx II body this past weekend. Sure looks like a Manx or a Manx copy. |
Posted: Mon May 05, 2014 1:33 pm Post subject: |
Thanks for the comments, I assumed this was a Spatz Long based on what I found on DBA. The body is at least 3/8" thick in many places but if there was a logo on the firewall, it is long gone. Did the Manx II come in a LWB model?
These were the pics from DBA I used to ID this: http://s23.photobucket.com/user/dunebuggyarchives/...y.jpg.html
Bob - The rear battery area appears similar to what you have, the Manx II pics I found did not look like this. Of course it could be a clone of both. Not sure if that piece of metal is factory or not, seems like a great way to short out the battery.
frizzardking Samba Member
Joined: May 09, 2011 Posts: 575 Location: BUFFALO N.Y
Posted: Tue May 06, 2014 3:38 am Post subject: Spatz |
Here is a Spatz body I sold last year
I believe the rear was different , same battery box ,and spare area , notice badges. |
Posted: Tue May 06, 2014 8:01 am Post subject: |
The Spatz Long appears to have a few differences from the SWB model. I wonder if they made those pods for the LWB bodies?
Had to push it out of the garage, wife didn't like the fuel smell from the leaky carb. Why does every vehicle i buy leak gas? Add carb rebuild to the list, but first I have to figure out what kit to buy. |
herbsflat4 Samba Member
Joined: February 20, 2012 Posts: 159 Location: Greenville, SC
Posted: Tue May 06, 2014 12:14 pm Post subject: Spatz |
Here are some pictures of my body that I believe to be a Spatz (but I still haven't found a sticker indicating this).
I believe someone took the body (before me) and cut it in the middle to make it shorter. See picture with arrow.
You look to have a nice looking project on your hands! |
Posted: Thu May 08, 2014 12:57 pm Post subject: Re: Spatz |
herbsflat4 wrote: |
Haha, I don't think it is all that nice looking but thank you. For your car, it sure does look like someone shortened a long body Spatz and spliced it together. That will take some careful fiberglass work to fix.
I was able to confirm that Manx II's did not come in a LWB form. |
Posted: Mon May 12, 2014 10:19 am Post subject: |
I started tearing the buggy apart around 5:30 last night, this is how far I got, it really comes apart fast. body was held on by only five bolts, hood by only two bolts at the rear and the gas tank by two tiny bolts.
Anyone for spaghetti?
Body is off, just sitting there, engine out tonight. |
Posted: Mon May 12, 2014 9:32 pm Post subject: |
Made more progress on the teardown/clean up tonight. Sorry for the bad camera phone pics.
Your basic 1500 single port.
A little cleaner
Ugh, why did I start taking the tarpaper off the center tunnel, it was just fine as is. About half done.
Fiberglass repair is in my future. I'm thinking of glassing in some aluminum strips where the body mounts to the chassis. Has anyone ever done that?
Well, I have to say, buggies are easy to take apart.
Posted: Mon May 12, 2014 9:35 pm Post subject: |
I need to rearrange this an maybe make a dolly for the body, but even the LWB body and chassis fit end to end in my garage.
Posted: Sat May 17, 2014 9:06 pm Post subject: |
Major teardown done, now on to sub-assemblies.
Looks like someone showed the brakes a little love at some point.
Cleaned out the tunnel mouse hotel, how did a spark plug get in there?
Nice to have everything on wheels
This is budget build, I was too cheap to take the wheels to a tire shop so I cut them off and put them in the trash
About 3:00 AM last night:
Posted: Sat May 17, 2014 9:20 pm Post subject: |
Today I worked on the chassis, I got it pretty much cleaned up and cut some extra stuff off like the defroster tube and the jack points. I also got the factory fuel line mostly cleared, no more fuel line in the passenger compartment.
Top side almost ready for epoxy. I'm going to use Chassis Saver and over coat it with spray on truck bed liner. Then some FatMat.
Pans are in good shape except this past repair. I ground down a bunch of booger welds after this photo. I'll make it look OK before paint.
Flipside
Underside of the patch needs a lot of work. I'll use some self tapping screws to suck the metal together and then weld it. Budget, quick build here, making due mostly with what is here for now. I think I can make it look OK and be leak free with a few tricks.
I need to do a big parts order, all the basic stuff that wears out but try to upgrade for better handling and performance. |
Posted: Thu Jun 12, 2014 11:13 pm Post subject: |
I have not posted in a while but I have been working hard on the chassis.
Well, except when I got distracted by an $800 shed find '84 VF700F. Pretty good condition for the price, has not run in years so I'm trying to bring it back to life and do a restoration. Carbs are down in TX getting a rebuild so the focus is back on the '63 pan.
Welding done to secure the patch, I used self tapping screws to pull the gaps together. Lots of grinding on the old and my bad welds. Then a coat of seam sealer with fiberglass embedded in it. Top and bottom where coated with Chassis Saver epoxy and then two coats of truck bed liner. It may not win the prettiest pad award but it should last a pretty long time in a street buggy. The way it was, water was getting trapped between the path and pan and rusting.
In retrospect, I guess I should have smoothed out the seam sealer better.
Body dolly is working out well.
The power of vinegar, bottom wheel soaked for two weeks and then I just hosed the rust and old paint off.
But don't use vinegar on alloy parts! I melted away half the steering box lid overnight.
I've been cleaning and wire brushing lots of parts getting them ready for paint. I killed my old 4 1/2" grinder, bought a new 11 amp Milwaukee, so much nicer! I brought it home and started wire brushing parts, I got so into it it was 2:15 am when I stopped.
$715 parts order ready to go at cip1, I just need to hit the send key.[/img][img][/img][img][/img] |
Posted: Thu Jun 19, 2014 9:28 am Post subject: |
More progress, lots of parts cleaning, wire brushing and paint. A little more drying time and then reassembly. Three boxes of CIP1 parts are supposed to arrive tomorrow. If I get my tires, this could just be a rolling chassis by the end of June.
Garage is no longer a paint shop.
I have a custom buggy wiring harness on order, I'm starting to sort out the electrical bits to see what else I'll need.
Posted: Tue Jun 24, 2014 8:00 am Post subject: |
Yesterday was Dune Buggy Xmas!
Stayed up late, managed to get most of the front end rebuilt.
Shocks don't seem to be right, I need to call CIP1. So far their service has been great. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Tue Jun 24, 2014 8:41 am Post subject: |
That red urethane steering coupler is dangerous. They have been known to fail without warning and unlike the factory cloth reinforced rubber "rag joint" when they break they come apart completely leaving you with NO steering.
I have seen them crumble in the package while sitting on the shelf in the garage for a couple of years. Really. Get a stock one. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Tue Jun 24, 2014 8:50 am Post subject: |
Q-Dog wrote: |
I have seen them crumble in the package while sitting on the shelf in the garage for a couple of years. Really. Get a stock one. |
It came with the buggy and does look pretty flimsy. |
