D-train Samba Member
Posted: Sat Jun 14, 2014 1:18 am Post subject: |
Panels were dry. So out they came for a coating!
Then got onto fiddly bits. Door components, handles, strips, mirrors..
The clouds came over so roughly bolted them to the car to dry in the shed.
Starting to resemble a car now.
_________________ shiny paint doesnt make it worth any more |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Sat Jun 14, 2014 5:34 pm Post subject: |
I can't imagine the fun he is going to have commuting in the city traffic in this. |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sun Jun 15, 2014 5:29 pm Post subject: |
im digging the hell out of this car. im in the process of doing my 55. i need to get some more pictures, and some time into it, and i can start my own build thread.
good job _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Tue Jun 17, 2014 2:10 pm Post subject: |
Couple of hours tinkering...
Window scrapers arrived, so in they went, need to redo the quarter seals so they will go in last.
Did a lot of this, its boring..
One guard
Two guard
Green guard, blue guard!!
Haha.
The lights look wonky cause they are there for a photo, waiting on seals still.
Posted: Wed Jun 18, 2014 1:51 pm Post subject: |
Guards are now wed to the car also!
Then did some tweaking and adjustment for the decklid.
Og spring and all!
Now to do the doors, and put in the door seals so they don't push the doors open by themselves.. _________________ shiny paint doesnt make it worth any more |
Capriacci Samba Member
Joined: February 15, 2011 Posts: 298 Location: Brazil
Posted: Wed Jun 18, 2014 2:42 pm Post subject: |
D-train,
amazing job! Congratulations!
I wish I had half your knowledge and ability!
Posted: Wed Jun 18, 2014 3:35 pm Post subject: |
Thanks mate! A lot of it is just jump in the deep end an figure it out how to do it, dads played a big part years ago by throwing manuals at me an saying "u want to learn, read"
It's all fun too when I trouble shoot how to fix things.. Part of owning a vw!! _________________ shiny paint doesnt make it worth any more |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Thu Jun 19, 2014 1:40 am Post subject: |
Got a plate made for the steering.
But needed the holes, thanks to Issac for the tapered reamer, top holes done.
Perfect!
Drilled and tapped the other side..
An presto!!
Now reinstall the steering again an re-align the tie rods. _________________ shiny paint doesnt make it worth any more |
Posted: Fri Jun 20, 2014 5:21 am Post subject: |
Finally got around to installing...
One tie rod on,
An both!!!!
At full lock an no fouling on the shock!!! U can see the marks where it was hitting... The tyre hits the headlight bucket prior to the tie rod on shock cause of how low it is. Actually turns heaps more than before so I'm stoked now!
Major headache gone!!!
56bugdan Samba Member
Posted: Fri Jun 20, 2014 9:01 am Post subject: |
2 things. I'm impressed that you got that tail light housing back into the shape you did because I've tossed many of those in the scrap pile that weren't near as bad as that. Second, that threaded rod idea for that threaded mounting block is real nice but I gotta say, it gave me anxiety when I saw the pic of you pushing the block through the bolt hole. I know those bolts can be a pain in the ass to get started when the block is strapped, so I don't know you ever got them started in the past with that block floating around. I've always made a new block just like you did and cut an access so that I could weld in a new strap to hold it loosely in place. Even with that though, I think the threaded rod would make it much easier to get those bolts started. Is that Penetrol stuff just an oil or some type of clear that dries? If it's an oil, doesn't it rub/wear off? Well, keep it up and I'm sure you'll have it cruising the the streets real soon at the pace you're moving. Thanks for all the pics and info! |
Posted: Fri Jun 20, 2014 12:54 pm Post subject: |
Thanks mate, there was a near perfect set of housings that came with it that the po had but they wouldn't of looked right. And with a little thought and elbow grease a twisted one will ride again!! Looks heaps better than a good one too..
The block n rod was an idea I was wondering if it would work for ages, paid off in the end, every other time I've done a body to chassis I've struggled with that plate for ages, an cross threaded bolts too. This made it quick and painless. Was happy with the outcome of it that's for sure!
Penetrol is a oil type of stuff that dries into a flexible coating, it will need another application once a year on surfaces that see a lot of action (roof, guards, bonnet) but under where it's away from the elements as such won't as quick. I have penetrol on sections of my 57 oval an it's still there after 2years. Looks the part too without all the paint prep for a clear coat _________________ shiny paint doesnt make it worth any more |
Posted: Sat Jun 21, 2014 1:02 am Post subject: |
Putting new seals an latches in the quarters so had to make a jig..
Clamps pulled it together quite easily, just need to see how they hold over night. Not hard to pull them out n re-clamp again..
Windows in, need graphite for the winding windows tho
Only need to put in the drivers quarter still, missing the top swivel thingy....
Macca gave ma hand pushin on this..
Kind of resembles a car now..
Posted: Sun Jun 22, 2014 1:40 am Post subject: |
Little tinkering...
Front bar on.
Then trial fit the bonnet, I know it needs work so havnt touched it yet.. Doesn't sit too bad tho..
Suit it?
Posted: Sun Jun 22, 2014 5:17 pm Post subject: |
not bad for what you paid for it, I wish I could find a few for that price
please please talk him into getting some single spot headlights. (incorrect headlights are a pet hate of mine) |
Posted: Sun Jun 22, 2014 5:56 pm Post subject: |
Henry, the priority for now is rego, all that can be sorted after. Just want plates on it 1st! _________________ shiny paint doesnt make it worth any more |
berpsta Samba Member
Joined: October 06, 2008 Posts: 114 Location: West Yorkshire England
Posted: Mon Jun 23, 2014 2:43 pm Post subject: |
looks great loving the patina, please tell me the shine on the wings etc is something like anchorwax and will dull and fade in time cos it looks SHINEY like lacquer at the mo!
Sean |
Posted: Mon Jun 23, 2014 4:21 pm Post subject: |
Thanks Sean. It does dull a bit, it's only fresh still. Good stuff too, it gets into all the cracks n crevices to seal it out. _________________ shiny paint doesnt make it worth any more |
67Cabrio Samba Member
Joined: March 30, 2014 Posts: 31 Location: Everett, Wa
Posted: Mon Jun 23, 2014 7:05 pm Post subject: |
Looks great D-train! I do have a question about the penetrol tho. You mention it dulls a bit as it ages, does it retain any shine? Reason I'm asking is I have a patina'd Studebaker that I'd love to seal up, but it's mostly just worn paint, not much rust. If I could make it look like it has some sort of clear on it, that would be fantastic. Does it work well on paint, like that? |
