MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Thu May 08, 2014 7:31 pm Post subject: Am I being too picky |
Finally got my T4 case back from the machine shop from getting tank dipped to clean for $125.00. This is the second time I sent it there. The first time they guy give some BS story about aluminum being difficult to clean that it will take a bunch of elbow grease on my part to clean it. They threw it into the tank for the weekend, got it back today. Well it is within an small acceptable range of clean. Should I be finding a different machine shop. What does everyone use to tank the block. There must be an excellent aluminum cleaner available somewhere. |
1badride65 Samba Member
Joined: January 08, 2010 Posts: 64 Location: SUISUN CITY,CA
Posted: Thu May 08, 2014 7:36 pm Post subject: |
Photos would be helpful. |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu May 08, 2014 7:48 pm Post subject: |
Takes twice through the parts washer tank and a lot of elbow grease to clean some things. Do what the professional shops do. Hire a "new guy" for 8 an hour to scrub it clean.
There is no magic tank of stuff that cleans it for you, but we do make it seem like there is.
WTF is wrong with that shop? |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Thu May 08, 2014 8:28 pm Post subject: |
After lots of degreaser and a stiff plastic brush, I took my case down to the car wash. I plan on more cleaning before final assembly. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine?
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Fri May 09, 2014 5:19 am Post subject: |
I didn't take pictures the first soak because they didn't stay here long enough before they were delivered back, but will take some when I get home today of the second time through the wash.
The exterior, yeah I can accept some crud that I would need to clean up but inside the case, not so much. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Fri May 09, 2014 5:40 am Post subject: |
I took my case to the car wash and used a can of degreaser on it then power washed with soap and pretty well was wetter than the case when I got done.
I did it when it was first disassembled and then again once the full flowing was done and after I had cleaned all the oil passages with wire brushes and brake clean.
Any heavy grease and oil buildup on the outside will only come off with sweat of the brow by carefully scraping with different shaped tools to get in all the little nooks and crannies.
Once that is removed then degreaser might take care of the rest.
You can put a lot of quarters in a car wash for $125.00........ _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri May 09, 2014 6:04 am Post subject: |
clonebug wrote: |
You can put a lot of quarters in a car wash for $125.00........ |
You can also buy an inexpensive parts washer that you can continue to use _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri May 09, 2014 6:40 am Post subject: |
GUNK Engine Bright does wonderful and believe it or not biodegradable SIMPLE GREEN (full strength) works really well as second wash after degreaser........
IF you are into solvents "petroleum spirits" (paint thinner?) works well (with or with out a parts washer) but will dry out you hands really quick, use gloves and hand lotion after use...
Also pressure washer or "U-Squirt" car wash helps a lot (take rain gear) ...
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Fri May 09, 2014 6:55 am Post subject: |
I've also found oven cleaner/degreaser works well |
mark tucker Samba Member
Posted: Fri May 09, 2014 9:13 am Post subject: |
about the bestIve found comes from the dollar store,BBq grill cleaner.big bottell last for many jobs.& yes you might want to find a new shop too. carb cleaner also works good. |
Posted: Fri May 09, 2014 3:04 pm Post subject: |
Here are the pics after the second time at the machine shop. I could scrap it out from between the ribs with my finger still.
Posted: Fri May 09, 2014 3:23 pm Post subject: |
yeah, that's unacceptable for sure. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Fri May 09, 2014 3:51 pm Post subject: |
I figured for sure any machine shop worth their salt could clean them just by tanking them. They told me that is the best any shop would get them. I must be too picky |
rustybusjef Samba Member
Joined: December 19, 2011 Posts: 329 Location: EVERETT WASHINGTON
Posted: Fri May 09, 2014 4:10 pm Post subject: |
The shop I worked at would have charged about $40.00 to clean your case , heads and tins . They would of came out spotless with little paint left on the tins - - you got screwed , you are not being to picky ! Ask the "machinist" if that is clean enough for him to build an engine out of . |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Fri May 09, 2014 4:36 pm Post subject: |
You need to find a shop with a real jet wash cabinet, not a soak tank. Super hot chemicals, blasted with multiple high pressure jets and a rotating table. I haven't had a case yet the jet washer couldn't clean inside and out. It should only cost you about $40 tops.
After I get them back I still run through everything in the solvent tank with rifle brushes.
Brian |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri May 09, 2014 4:55 pm Post subject: |
You could have done a better job simply putting the case into your dishwasher at home. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Fri May 09, 2014 5:00 pm Post subject: |
I agree with all you guys, just needed some moral support for being pissed. Already used a bottle of degreaser and half bottle of aluminum rim cleaner on the one half. What really ticks me now is I ruined my best tooth brush |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri May 09, 2014 5:08 pm Post subject: washing case |
I can't speak specifically for a Type 4 case, however, I have always taken my Type 1 cases to the car wash, and used their high pressure wands. This will clean any built up grease, oil, etc, and you can also clean all the passages (remove the plugs first, of course). I've also used this method when clearancing the case for a stroker crank/rod setup (to remove shavings). _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Sat May 10, 2014 2:48 am Post subject: |
MacLeod Willy wrote: |
yeah, your meant to use other peoples _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
