Iguana Samba Member
Posted: Sun May 11, 2014 1:37 pm Post subject: Building Barbie's Tow'd |
After looking around the samba for a while there seems to be a distinct lack of Meyers Manx Tow'd and Tow'dster builds going on so I thought I might add one of our current builds for all to enjoy.
The time line on this is pretty tights with the intent of the Tow'd or Tow'dster in this case will make it depute at the Manx Club Big Bear Bash for the 50th Anniversary.
I don't own this Tow'd it belongs to a fellow Manx Club Member.
The Tow'd is in for a rebuild / reassemble and some love. It has been together in some way at some time of its life but not for a while. Lori Ann got it in bits and al lot of it is made up from bits and pieces which were picked up around the way from other buggies and shops etc.
Our Mission - Make a cool Tow'd in time for Big Bear ..
Like all our "Projects" we start by doing a layout and parts list. This helps us see what is there and work out what we need to do.
The Tow'd will be an IRS / King and Link Pin, 4 wheel Drum brakes, Type 2 3 rid transmission and 1600 TP engine. It is getting a full pull down and sand blast followed by some of our special buggy treatment.
Not much to look at yet but give her a few weeks and the boys will have it sorted.
Parts are racked and accounted for, looks like it has made a new friends all ready
From here the boys lay it out, run through it all inspecting the parts and do up a 3 stage build sheet. A 3 stage Build sheet refers to our build stages we use to ensure we don't miss something before we move on.
Stage 1 - Fabrication and Parts ordering. We do a complete dry assemble of the Tow'd. We do any fabrication, drill holes, cut fiberglass, add brackets etc and make sure it is all good to go.
Stage 2 - Strip , repair and paint. We do anything that it needs between dry assemble and final. This includes paint and repair.
Stage 3 - Assembly and mechanical. We get all the parts and put them together, we do all the mechanical, brakes, engine CV's etc and trimming as required.
Almost done
Iguana Samba Member
Posted: Sun May 11, 2014 2:17 pm Post subject: |
The Tow'd Tub is a rare example of a new tube from 1970. It has never been fitted and still has its original green gel coat.
This one is number TF849E031S
Deciphered from the archives this makes it "
T = Tow'd
F = Fibrgelass Body Tub not ABS
849 = Production Number
E = Month = May
0 = Year of Production 1970
31S = Colour = Lime Green
Funnily enough it still has the original final inspection tag on it which has a date of 3-70 so I guess the Tag matches, sweet.
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sun May 11, 2014 4:10 pm Post subject: |
Iguana wrote: |
T = Tow'd
E = Month = May
Funnily enough it still has the original final inspection tag on it which has a date of 3-70 so I guess the Tag matches, sweet. |
Very nice! Are you sure that under the smudge it doesn't say 5-3-70 |
Iguana Samba Member
Posted: Sun May 11, 2014 4:51 pm Post subject: |
BL3Manx wrote: |
Iguana wrote: |
T = Tow'd
E = Month = May
That's funny I keep forgetting dates are backwards over here. I will have a better look at it later but there isn't much there to see. I thought they might do final inspection and then tag them when they were sold so as not to have shelf stock with dates on them ?? |
Iguana Samba Member
Posted: Mon May 12, 2014 10:26 pm Post subject: |
The Tow'd came with all the parts accept the rear deck lid to make the Tow'd into a Tow'dster.
The front bar is not original but it is an acceoptable copy
Roll bar is there and a custom rear bar.
The chassis has had some additional tubes added and a front brace to support the dash.
And it has a hard mount 3 rib type 2 transmission
As it hasn't really been apart before we started off by cutting the tub to fit the new support bars.
Posted: Tue May 13, 2014 1:02 pm Post subject: |
Iguana wrote: |
As it hasn't really been apart before we started off by cutting the tub to fit the new support bars. |
That makes me sad |
Iguana Samba Member
Posted: Tue May 13, 2014 5:17 pm Post subject: |
BL3Manx wrote: |
Iguana wrote: |
That makes me sad |
Why ? Would it be better to say another body sat in the back yard rotting away while people continued to think modifying a modified car was a bad idea ?
Buggies are built to be enjoyed and if the owner wants me to cut a brand new original car in half and paint it pink I will get the grinder out if it means their dream will come true and they will feel the wind in their hair.
I cut Manxters and Kick-Outs up all the time, even got to cut an original Meyers Manx 1 up the other week. It is all part of what buggies are about. Take the outline and make it your own, there is no such this as ORIGINAL in buggy world as they were modified from day 1, heck you can't even build a buggy without modifying something. There is PERIOD CORRECT I guess but that is it. |
Posted: Tue May 13, 2014 6:19 pm Post subject: |
Its definitely more challenging to build a well designed buggy based on a vintage body without resorting to adding more and bigger holes, but I've seen it done. This guy has a full cage, reinforced frame, mid-travel suspension, a cargo rack, a solid anchor for his seat belts and the only additional holes I can see cut in the body are the two round holes in the hood. The thought and effort at preserving the body's originality along with its exceptional structural mods are very evident and definitely enhance its quality and appearance.
Iguana Samba Member
Posted: Tue May 13, 2014 6:58 pm Post subject: |
BL3Manx wrote: |
Hate to break it to you but that body was cut more than what this one will be so I guess that makes it ok. |
Iguana Samba Member
Posted: Fri May 16, 2014 6:16 pm Post subject: |
With the body in place it was time to turn our attention to a few of the add on's which were wanted.
A grab bar was one but before we could do that we needed to add the dash ( shown later), once that was done we could fit the grab bar support rail in place and get the alignment made. All tube work is done from 1020 DOM in this case 1 1/4.
Then onto the battery tray. They wanted the battery out of the cargo area, if you call the rear of a tow'd a cargo area . So it was decided it could go underneath out of the way. In this case we will be using an Odyssey 680C dry cell
The rest of the fabrication work that was done was mainly clean up and nothing really to show. But we did get out list ticked off before we called in the local car washing crew....
To keep it off the ground she got to sit on a pallet.
Then came the hose
Guess it should clean up ok ....
Anyone else want a car washed ??? |
Iguana Samba Member
Posted: Thu May 22, 2014 8:56 pm Post subject: |
With the chassis and barwork all sand blasted it was time to move it back inside and inspect to see if any issues had been uncovered.
Like most old cars it is always interesting to see what the work quality was like back in the day, in this case the Tow'd had some interesting welding in places
Just more stuff to put on the todo list I guess. Once the chassis had dried out it was hit with the first coat of etch prime, this is done to avoid the issues of working on blasted steel such as finger prints and surface rust.
Once that was done and dry and quick reassemble was needed to get the last items sorted such as indicator tab, dash bar, dash tabs, harness bar and some other weld outs.
From here we are almost ready for final clean up and etch before applying the seal coat and then beginning the reassemble. Then onto trim, re-wire and mechanical. |
manxvair Samba Member
Joined: January 11, 2011 Posts: 231 Location: Arizona
Posted: Sat May 24, 2014 12:07 pm Post subject: |
That looks like a nice project! I'll bet the owner is gonna be real happy! |
LADtowd Samba Member
Posted: Sat May 24, 2014 2:01 pm Post subject: LAD TOWD |
I recognize those parts and body, thanks for posting an update. I can't wait to see the finished product, thanks guys, Barbie aka Lori Ann |
Iguana Samba Member
Posted: Sun May 25, 2014 1:48 pm Post subject: |
manxvair wrote: |
Dunno they went off and had a holiday safe in the knowledge that some crazy Aussie could no longer hassle the owners husband about his lack of progress.
Being a long weekend ... it is currently hanging out in the paint booth after having a day at the spa. |
Posted: Sun May 25, 2014 4:24 pm Post subject: |
I'm sure the holiday was taken in the true spirit of the Manx Dunebuggy. We had a blast. I knew we left it in good hands. Paint booth??? YEAH!!! You have definitely made the husband's life a lot less stressful if you know what I mean. Barbie |
Oz Towdster Samba Member
Joined: November 08, 2004 Posts: 133 Location: Brisbane QLD Australia
Posted: Sat May 31, 2014 4:01 pm Post subject: |
Iguana wrote: |
manxvair wrote: |
It's all good , that crazy Aussie will give the owners husband a hard time at Big Bear _________________ Working at getting my Baja Bus and the Towdster back on the road |
Posted: Sun Jun 01, 2014 1:52 pm Post subject: |
Oz Towdster wrote: |
Iguana wrote: |
manxvair wrote: |
It's all good , that crazy Aussie will give the owners husband a hard time at Big Bear |
When the owner and her husband come to the land down under next January, He'll have to see if the another crazy aussie has his towdster completed! |
Posted: Mon Jun 02, 2014 12:46 am Post subject: |
I'll get straight onto Paul _________________ Working at getting my Baja Bus and the Towdster back on the road |
Iguana Samba Member
Posted: Tue Jun 03, 2014 10:04 pm Post subject: |
I'll get straight onto Paul |
It'll never be done |
Iguana Samba Member
Posted: Tue Jun 03, 2014 10:10 pm Post subject: |
With the time line getting shorter we must get moving ... the Tow'd chassis was prepped with a 2 part epoxy primer and then sprayed with Armadillo Lining with is a Poly Urethane mixed at pressure as it comes out of a special gunb setup. In bonds like glue and then sets hard but flexible. Once that was done it was onto assembly.
