Good welder?
Page: Previous  1, 2, 3, 4
theKbStockpiler
theKbStockpiler is offline
PostPosted: Mon Sep 29, 2014 8:07 pm    Post subject: Reply with quote
If you suspect a liner issue ;birdnesting the wire, push or pull the wire through the liner by hand to see if it binds. I had a roll of Hobart wire once that was wound all goofy so it would not unroll easily.
Hey ,aren't the pulse migs for welding thin aluminum or welding thick aluminum upside down? The estab one is 5k ,is it not?
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
modok
modok is offline
PostPosted: Mon Sep 29, 2014 9:07 pm    Post subject: Reply with quote
It's the little roller wheel, liner, or tip. Older miller they came with a knerled roller........which some will say is for flux core only, but will do solid wire ok if you make sure not to use excess tension. Too much tension and it cuts little teeth in the wire which makes you go though tips fast. And old dusty/rusty wire will go though tips fast too. I'm not sure what they will give you for a replacement feed wheel........but it does not really matter, both kinds work fine.
Pulse MIG for aluminum?? I really don't know.
esde
esde is offline
PostPosted: Mon Sep 29, 2014 9:24 pm    Post subject: Reply with quote
I use the pulse for aluminum when running the spool gun and aluminum wire on my Esab machine; it allows me to not have to travel so fast. If I'm doing thin steel or stainless with the standard mig torch, the pulse lets you get excellent weld penetration without a lot of heat buildup and burn through.
The Esab 260 multi master was under 2k when I bought it. Adding the pulse module and inductance control were around $240 each. The spool gun is another $400, I love it as I can have it loaded with thin wire for sheet metal and leave the 035 on the big spool. Plus it has a 30' lead, which is much easier to drag around the shop than the whole machine.
esde
esde is offline
PostPosted: Mon Sep 29, 2014 9:30 pm    Post subject: Reply with quote
On the miller not feeding, check the drive roller to see if there is another groove. Some of the 110 volt entry level machines have two grooves in the feed roller. One is for .035 and the other is for .028 wire, and you have to loosen the bolt and flip the roller around so the correct groove is getting 'traction' on the wire. Check it out. SOmetimes the paper label on the smaller spools gets bound in the tension nut too, make sure it's free and not too tight. Worst case the liner got kinked. They aren't too hard to pull out to check, I've done it and straightened one enough that it worked ok.
raygreenwood
raygreenwood is offline
PostPosted: Tue Sep 30, 2014 6:39 am    Post subject: Reply with quote
X2....the Eastwood and most of the others listed here have two grooves. They also warn against over and under tightening the drive roller.
The guys at the local Praxair dealer noted that when setting up the drive roller tension.....to leave it as loose as possible then put the gun sheath in a tight loop....not a kink but jut enough so that there will be maximum wall contact or friction against the wire inside the sleeve. Then while squeezing the trigger alternately tighten the roller until it just feeds and give it a slight further tweak.
The object being to only put a little more tension than necessary to keep from causing excessive wear to the roller.
Also.....others have noted that you should always use good well known brands/quality of wire. Using cheap or no name brands of wire you can get wire cross section that is out of spec....or has variations in it....thick and thin which can cause feed problems. Ray
Spezialist
Banned
Spezialist is offline
PostPosted: Tue Sep 30, 2014 1:37 pm    Post subject: Reply with quote
thanks a lot. Very Happy
Popcorn
modok
modok is offline
PostPosted: Tue Sep 30, 2014 5:23 pm    Post subject: Reply with quote
Sorry guys, they did not have two grooves in 1991, just one kind of roller.
The dealer may be able to retrofit a smooth roller for solid wire, they came out with em in the mid 2000's. guy at dealer may be too young to know tho
raygreenwood
PostPosted: Tue Sep 30, 2014 5:37 pm    Post subject: Reply with quote
Damn!....another beautiful theory....slain by an ugly fact. .... Wink
Ray
Kafer_Mike
Kafer_Mike is offline
PostPosted: Wed Oct 08, 2014 2:11 pm    Post subject: Reply with quote
Also, make sure the drive wheel is the right size for your wire. I assume you dropped down on the wire size when you added gas. The .028 will slip through a .035 drive wheel, be it smooth or serrated.
Kafer_Mike
Build 'em fast...or let 'em sit.
Jsg
Jsg is offline
PostPosted: Sat Oct 11, 2014 5:47 am    Post subject: Reply with quote
I have a Hobart 140 Handler and am very pleased with it. Great quality for the price. The only comment I would make is that they no longer come with a drive wheel to handle .024 wire. They used to apparently but now you have to purchase that additionally. Just a FYI for anyone purchasing one.
onehappykombi
onehappykombi is offline
PostPosted: Tue Oct 10, 2023 5:46 pm    Post subject: Re: Good welder? Reply with quote
Did the Eastwood 135 that everyone is recommending get re-branded as Eastwood 140?
I don't see a 135 anywhere in their website
'56 Early Split & '69 Early Bay
Overlanding the USA
Camper special engine build
Busstom
Busstom is offline
PostPosted: Tue Oct 10, 2023 6:42 pm    Post subject: Reply with quote
For what it's worth, I have a relatively new (3 years old) Handler in my arsenal and it does come with a multi-stage drive roll that handles .023 (.024). And it just does what it does, throws down sweet beads all day.
My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏
Page 4 of 4
