Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Sun Jun 01, 2014 7:17 am Post subject: |
MonT3 wrote: |
Looks like you got your work cut out for ya. What are your plans for your rebuild? Are you looking to pull the shell off? |
Agreed. I'd pull the body off and do some media blasting for sure. Mike might think it'll be easier to leave it on the pan, but I think you'll be further ahead pulling the body off and digging in deep. These cars have a lot of hidden areas that can try to come back and haunt you, IF you don't dig deep. Plus it allows you to get more access to some areas that are hard to get at with the pan on. Monte and Clatter have already found this out for themselves, and I've done a few of these cars (I live in the "salt belt" of the USA) to know rust can hide in various places, and how much easier it is to have the body off the pan when doing rust repair. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
260KMN Samba Member
Joined: January 17, 2014 Posts: 236 Location: Devon UK
Posted: Sun Jun 22, 2014 1:59 pm Post subject: More strip down pics |
Are these fog lamps factory or dealer installed
Bracket with Hella p/n
Right rocker looks sound with wing off
Rust in LH C pillar, mostly surface fortunately
Left C pillar is nicer
Right engine bay inner wing area shows some rot too, left hand is good though, just surface rot.
Windows all out and interior now all stripped also took the body mount bolts out today, amazingly all came out without any issues. Body coming off this week. One more pic motor with rusty bits
260KMN Samba Member
Posted: Thu Jul 17, 2014 12:23 am Post subject: Welding the 63 |
Finally got round to stripping the shell and cut the LH rocker off, its not too bad and is repairable.
The fun starts here!
260KMN Samba Member
Posted: Sun Aug 24, 2014 9:15 am Post subject: Channel repairs |
Rear Rusty, but do-able
all cut out
fronts a mess, some thinking required
First front repair section turned out ok, not quite factory but I'm happy with it
Started making some repair sections for the RH channel front and rear corners, rear not so bad, front a bit more complicated |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Tue Aug 26, 2014 6:25 am Post subject: |
Good job cutting out the bad stuff.
That vent piece looks awesome. If you can blast some of that rust away, go for it. What you have going for you is the top of your rockers looks to be saved. I just posted some pics on my thread cleaned up pitted areas. You have some of those but not sure how deep they may be. How are you going to patch up the heater tube that runs the length of the rocker? Keep at it as it'll come back together. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
260KMN Samba Member
Posted: Fri Aug 29, 2014 5:40 am Post subject: More rocker repairs |
Right rear corner inside all done
i managed to cut out the rotten heat tube and replace it back to good metal
Repaired the bracket that holds the tube at the front and then fabbed up a repair to the heat tube outer cover.
Not concourse standard but structurally sound.
Next is getting the outer rocker to line up and complete the front corner repair |
MonT3 Samba Member
Posted: Fri Aug 29, 2014 6:17 am Post subject: |
Did a really good job patching up those pieces. Keep it up and those will be closed up in no time! Make sure you test fit those outer rockers so you have the bottom lip extended to cover any gaps (should they be there). _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Fri Aug 29, 2014 6:49 am Post subject: |
WOW, that looks great. You're really moving along with it. It won't be long before it's all repaired on that side. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
260KMN Samba Member
Posted: Fri Aug 29, 2014 11:55 am Post subject: |
Thanks for the positive comments guys, keeps you motivated.
I am going to try to replicate the bottom edge on the rocker, ie folded over 90 degrees on the lower edge as per the other, good, side.
Wish me luck. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Fri Aug 29, 2014 2:15 pm Post subject: |
Lovely work.
Kudos to you for keeping on.
Watching in awe, as those channel areas are complicated beyond simple repair! _________________ Bus Motor Build
What’s That Noise?!? |
260KMN Samba Member
Posted: Tue Sep 02, 2014 12:36 am Post subject: Rocker repairs |
Finally after 100 adjustments its rocker attachment time.
lined up and ready
First welds
Lines up quite nicely if i may say so
Even managed to replicate the factory folded lower lip
Welded
Plug welded the inner face as i dont have a spot welder.
Really quite pleased with the result, just need to grind down the welds and start the next bit, that will be front inner wing. |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Tue Sep 02, 2014 2:45 am Post subject: |
Great stuff! _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
MonT3 Samba Member
Posted: Tue Sep 02, 2014 5:10 am Post subject: |
Love it! Saved yourself a ton of time test fitting the doors!!! Great job lining those rockers up and getting them in place. How did you roll the bottom-end piece? Also, did you fit the fenders over the ends to mark the mount points for the fender edges - please say yes? I welded in M8 bolts to the outer rocker skin so the front fender and rear fenders can bolt to the rocker parts that'll be covered by the fenders. Yes? Regardless, looks awesome! _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Tue Sep 02, 2014 7:03 am Post subject: |
Nice work you have going there. The before, during & after pictures are great. I am impressed with the tidiness of your work. Keep it going. |
260KMN Samba Member
Posted: Tue Sep 02, 2014 7:18 am Post subject: |
Thanks for the comments guys, makes it all worthwhile especially as i dont do this for a living, fortunately. Monte we have a folder in the workshop at work which i can use but the rocker would not go in to fold the lower edge, so i clamped it to a nice edge on my bench and hammered it over a bit at a time. I trialled the wings on a hundred times also to check location and welded M6 captive nuts into the rocker panel before installation as per the original.
Back to it tonight for more fun, grinding
It shows that with a bit of patience even those aftermarket rocker panels can be made to fit quite well. |
260KMN Samba Member
Posted: Tue Sep 02, 2014 2:03 pm Post subject: |
Just noticed the ad in Type 3 parts on here for those black rockers, ISP are selling for 200 bucks each.
They look different than the one i bought, didnt realise there was more than one supplier. The front and rear ends are quite different.
Mine was not perfect but looks better quality than the ISP ones. Mine came from CSP in Germany and was 90 Euros, about 120 bucks, if i remember. Obviously it would cost a bit in shipping to the US but is an alternate if anyone needs any. |
260KMN Samba Member
Posted: Wed Sep 03, 2014 12:55 am Post subject: More rocker repairs |
Didn't get much done last night, just grinding down the welds and fabbed up a repair for the lower inner wing corner. Still, abit of progress i guess.
Rocker just needs a skim of filler and its done. Have to finish the vent area next.
On vacation for 10 days now so no further postings for a bit.
Heres a couple of images
Rocker
Rear rocker join
Inner wing repair piece |
brimfull Samba Member
Joined: December 15, 2004 Posts: 42 Location: nottingham,uk
Posted: Wed Sep 03, 2014 2:16 am Post subject: |
Really nice work on that, you're cracking on at a good pace with it
That's how I did my drivers side cutting along the sill edge. Did you change the heater channel bottom too, I think I used a T3D closing panel for mine?
260KMN Samba Member
Posted: Wed Sep 03, 2014 4:18 am Post subject: |
I used a full outer rocker panel from CSP in Germany and cut it down, fit is ok with some fettling. Most of the channel bottom plate was ok so i have just patched the bad areas |
