Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Wed May 28, 2014 5:50 am Post subject: Diesel fuel injection pump longevity ? |
Just curious what others have experienced ? I've owned three early ( 1980 to 1991 NA ) VW diesels now but never went over 200,000 miles on any of them and never had any pump or injector problems .
Also owned 3 old Mercedes diesels with lots ( about 300K ) of miles but never any pump problems , not even sure how I would tell if pump was going bad ? _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Thu May 29, 2014 6:58 pm Post subject: |
Usually you will have rough running at idle when the pump is really worn and should be replaced. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Fri May 30, 2014 6:35 am Post subject: |
My 85 Jetta had 470,000 kms on the motor when I replaced it due to low compression and the injection pump was still working fine. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
Posted: Fri May 30, 2014 7:10 am Post subject: |
bvolks wrote: |
My 85 Jetta had 470,000 kms on the motor when I replaced it due to low compression and the injection pump was still working fine. |
Does Canada have the ultra low sulfur diesel or the high sulfur for Highway use , what we call off road only diesel ( farm use ) and how often do you change your filters . Thanks . _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
bvolks Samba Member
Posted: Sat May 31, 2014 6:25 am Post subject: |
We didn't have ULSD when the original motor was still in it. As far as filter changes, I don't know how often the previous owner changed them (I bought the car with 360,000 kms on it) but I don't believe I changed it at all in the 110,000kms I ran it.
Unfortunately, I've read that the ULSD does reduce the life of the seals in the older pumps. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1995 Golf CL
1974 Beetle
1978 Westfalia |
Islero Samba Member
Posted: Sat May 31, 2014 1:17 pm Post subject: |
Typical failure on old pumps is they start leaking in the shaft groove (easy fix) and seals, but overall very reliable |
crsmp5 Samba Member
