sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Sun Jun 01, 2014 3:10 pm Post subject: Glandnut, flywheel fitment issue. |
Alright, so was test fitting some stuff together, and the glandnut does not fit through the flywheel. Glandnut is new from Wolfsburgwest, and the flywheel is an AA 12v 200mm for the 36hp. The hole in the flywheel mic's at 1.102" and the large shoulder on the glandnut is 1.119", so .017" too large.
Wanted to see if anyone could mic a stock 36hp flywheel and glandnut for me?
Should I just have the flywheel machined to fit the glandnut?
Here's some pics:
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Sun Jun 01, 2014 4:30 pm Post subject: |
got a 36 apart right now. the gland nut is 1.119. and the flywheel is 1.134. so the sweet china flywheel is made wrong. i would machine the gland nut to fit. it's close put it on a lathe . _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Mon Jun 02, 2014 3:03 am Post subject: |
Hmm, after comparing a little more, seems as though it's not the flywheel I ordered in the first place. Has an outside diameter of 10 3/4in. Which is 6v. Gets even better as no one has the right flywheel in stock. Checked my email and I ordered the right one, but appears wrong one was shipped, I ordered this almost a year ago, company I purchased it from doesn't even list them on their website anymore.
Back to the drawing board. |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Mon Jun 02, 2014 7:15 am Post subject: |
sgmalt46 wrote: |
got a 36 apart right now. the gland nut is 1.119. and the flywheel is 1.134. so the sweet china flywheel is made wrong. i would machine the gland nut to fit. it's close put it on a lathe . |
Sounds like the flywheel bore is Porsche size. 356 gland nut will probably fit. |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Mon Jun 02, 2014 8:16 am Post subject: |
Easy problem to fix. Scat sells a very nice 356 gland nut that will fit that flywheel. As for the 6v ring gear, just buy one of the 12v starters (that are available from a couple places) that has a 6v drive gear on it. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
Posted: Mon Jun 02, 2014 9:04 am Post subject: |
Ok. Emailed concept 1 up in the great white north. They have them in stock. If it's not right, well, then porsche glandnut and hybrid starter it is. Both option look to have been the same cost from this point. Let you all know when it arrives. |
Posted: Wed Jun 25, 2014 4:28 am Post subject: |
Received, the new flywheel that is for 12v, it has same size hole for the glandnut, so ordered the scat porsche glandnut, fits great. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Fri Jul 04, 2014 10:47 am Post subject: |
sixty9fasty wrote: |
AA make a chromoly gland nut that works, part number 008-226
I have these in stock _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
