johnerkelens Samba Member
Posted: Mon Jun 02, 2014 4:26 pm Post subject: 1998 jetta diesel problems |
1.9 TDI AHU ENGINE CODE 50 AMP FUSE FOR GLOW PLUGS BLOWN AND ALL SPADE CONNECTIONS FOR THE GLOW PLUG HARNESS ARE SOLDERED TOGETHER [P.O].I HAVE NO POWER GOING TO GLOW PLUGS.HAVE INSTALLED NEW PLUGS.GLOW PLUG DASH INDICATOR COMES ON 1-2 SECONDS ONLY.PLEASE ANY HELP AT OUR WHITS END.ALSO WE NEED A WIRING DIAGRAM FOR THE SAME ENGINE THANK YOU |
vedipus Samba Member
Joined: January 20, 2006 Posts: 4 Location: Dallas and New Hampshire
Posted: Mon Jun 02, 2014 10:25 pm Post subject: |
I am not familiar with the tdi engine, but on an old vw diesel you could run a 10 gauge wire from the positive battery terminal to the glow plug bus and bypass all of the electronics. Just hook the wire to one of the plugs (which should connect them all) and clip the other end to the positive terminal. Wait ten seconds, start, remove the wire. This will get you to work until you can repair the frankenstein wiring the correct way.
As for the wiring diagram, I would suggest buying a good repair manual. Most VW folks prefer the ones from Bentley Publishers. |
crsmp5 Samba Member
71type1 Samba Member
Joined: November 09, 2009 Posts: 2 Location: Carson City, NV
Posted: Wed Jun 18, 2014 5:44 pm Post subject: Glow Plug Help |
Is your car an automatic or manual? The manual transmission cars have three additional glow plugs in the thermostat housing. |
crsmp5 Samba Member
Posted: Fri Jun 20, 2014 5:59 am Post subject: |
Wow... You need to learn where thermostats are.... Ignore the moron who has no idea... The3 are in the waterneck to help ad heat... Not starting system... And no where close to thermostat... _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
xeno Samba Member
Posted: Wed Jun 25, 2014 5:23 pm Post subject: |
Does disconnecting your tempeture sending unit allow it to start?
_________________ Currenlty Corralled:
1952 Crotch Cooler Deluxe (US specs delivered to Stuttgart, Germany GI.)
1955 Early (Competition Motors - Hollywood, California)
1974 Thing (US specs - Mexicanos)
2008 Rabbit S (Wolfsburg DE)
2012 Golf TDI Tech Package (Wolfsburg DE) |
