Islero Samba Member
Posted: Tue Jun 03, 2014 1:58 am Post subject: Quantum/Golf/Jetta digital clock |
Digital clock on my Quantum does not work, sometimes when I start the car it displays 0:00 very briefly and then fades away, should I get a new one or is it fixable?
Thanks |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Jun 03, 2014 6:22 am Post subject: |
Can you get a new clock, or would that have to be a whole new dash? Is that even available or by new you mean "new" to you?
That can't be the only clock in the car, as most radios have a clock function... |
veedubman72 Samba Member
Joined: March 08, 2014 Posts: 230 Location: United States
Posted: Tue Jun 03, 2014 10:04 am Post subject: |
If you are restoring or trying to keep the car a working original, you can replace the digital clock, but it is extremely labor intensive and you really have to know what you are doing or else you can screw up the circuit board on the cluster. You are better off just replacing the whole cluster as a unit if you absolutely have to have a working clock. Otherwise I'm with ps2375. I would just leave it and use the clock on a radio or other device like your phone.
It could also be a loose connection, but you still have to remove the cluster to find out. |
Islero Samba Member
Posted: Wed Jun 04, 2014 5:56 am Post subject: |
Ok, I will try to get another cluster and see if I can swap just the digital clock.
Thank you friends,
Danny |
