BajaLobster Samba Member
Joined: November 30, 2013 Posts: 32 Location: Southern California
Posted: Thu Jun 05, 2014 9:18 pm Post subject: Ecotec 2.4 motor swap - ordered motor now what? LOL |
So I sold my VW motor and decided to go Ecotec! First I tried to buy a turnkey package but found the overall cost although very fair and competitive , to be more than I personally should be spending.
I ordered a junkyard 2007 2.4 ecotec shipped to the house for $600. This is about $1200 less than the local yard wanted.
I have spent several weeks reading all I could find on the conversion and have a pretty good idea of what parts I need and which vendors to get them from. What I do not know much about is what I have to do to the motor itself to "convert" it for my use.
For instance, I favor the idea of a standalone harness and ecu such as available from cbm or afi, but they are speed density or do I start trying to trim the factory harness and find an ecu and tuner. I don't know any tuners and then do I keep the MAF?
What other sensors are "supposed" to stay. I know there is a water block off for the heater circulation but what about the power steering block or is there a power steering block off issue on the 2.4?
Any and all help is appreciated. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jun 06, 2014 6:05 am Post subject: |
Might want to look at Megasquirt for ECU and fab your own harness.... MS wants simple sensor systems, and they may already be on motor.... IT wants coolant temp, Air temp, MAP, TPS and OXY, and not much more... Not only does it do fuel it can do wasted spark + crank fire ignition....
http://www.megamanual.com/index.html
Graphic show it in simplest form, you can go EXOTIC from here...
https://www.diyautotune.com/catalog/index.php
http://www.shoptalkforums.com/viewforum.php?f=23&sid=42a7090c1e15cc26e5cc046132cd24db
murdoch44 Samba Member
Posted: Fri Jun 06, 2014 7:56 am Post subject: |
Where to begin? I am not an off-reader, but I have been acquiring the parts and knowledge to put a 2.4 Ecotec in my Bay Window. Some of what I have learned you might find useful. I have a 2.2 and a 2.4 up and running on engine stands in stand alone configuration. Here are some pointers to get you started: Join the Ecotec Forum for engine specific info, tons of good advice and info. I used a GM or stock computer and made my own harness. It is cheaper and not hard at all. I sourced the wiring diagram from AlldataDIY.COM. You will need to get the security codes disabled in the ECM. There are good sources for that or you can do it yourself with HP Tuners. There are also good build threads in the Bay forum and here that used the Ecotec. Most used the 2.2 motor. The 2.4 has variable valve timing so I am not sure how that will interface with a non-stock computer. It also has a drive by wire throttle body. That can be changed out with a 2.2 throttle body that uses a cable pull; however, you would have to use the 2.2 manifold. The 2.4 manifold is better even though it looks the same. The 2007 2.4 is one of the two years that used forged rods. With the right bolt on parts, turbo, headers & such you can get 260 HP, with a cam upgrade and retuning, 400 HP is possible without changing any of the bottom end because it is so strong. There are plenty of vendors for the Ecotec stuff you will need. Google is your friend. Good Luck |
Posted: Fri Jun 06, 2014 9:01 pm Post subject: |
Thank you, I have reviewed the megasquirt and it is definitely beyond anything that I care to take on myself. I will go with some version of the stock e67 ecm and harness and have no choice but to find a local tuner or drive until I find one as I will be setting up a turbo to boost at 15lbs as well. That said the le5 that I bought is 2007 for the forged internals and I intend to keep the DBW. Hopefully will find upwards of 300 hp.
Murdoch - if you have a 2.4 mockup, can you elaborate on what physical parts of the block get changed or altered for a motor swap?
Thanks |
Posted: Sat Jun 07, 2014 3:58 am Post subject: |
None are needed. The 2.4 were in cars that had drive by wire steering; therefore, no power steering block off plate needed. The heater outlet/inlet lines can be eliminated with an aftermarket milled piece, available from a couple of suppliers of off road engine stuff. There are plenty of hard points on the block for any number of mounting options. In your first post, you asked about sensors. The second O2 sensor (the one downstream for the Catalytic converter) is the only one that can be eliminated. If you are going to build your own harness and use a stock computer, get everything from a single donor car, preferably the model your motor came from. It will be the easiest. |
Posted: Sun Jun 08, 2014 7:04 pm Post subject: |
Thank you, good stuff. For a water cooled turbo, it appears there are no freeze plugs - Do you think it would be worth pursuing the heater in/out for use for the turbo cooler instead of blocking them off? |
Posted: Fri Jun 13, 2014 10:29 am Post subject: |
Can anyone tell me what this black hose is coming from the intake manifold just under the throttle body? What to do with it for my bug?
Thanks
Posted: Tue Jun 24, 2014 10:57 pm Post subject: Update |
Just to update - Steve Humphries will build a new harness for me. I have changed to an 091 trans and remounted so that the firewall does not need to be cut. Engine is mounted and cage is currently being fabricated.
Can anyone give advice on plugging the brake assist and EVAP lines coming from the intake manifold. I assume I will just cap them off?
Thanks
md perf Samba Member
Joined: March 07, 2012 Posts: 149 Location: Pinckney, MI
Posted: Wed Jun 25, 2014 9:42 am Post subject: |
do yourself a favor: get ahold of Alphafab. that's all they do is eco swaps.
http://www.alphafabindustries.com/ _________________ They've done studies, you know. 60% of the time, it works every time |
Posted: Tue Oct 07, 2014 4:02 pm Post subject: BEWARE of Steve Humphrey EFI harness |
Just thought I'd vent a bit here since its been a long time since I was actually ripped off and maybe I take it personally.
The short version is he is a really nice guy, but I am left with a worthless computer system E37 that I don't know what to do with.
I sent Steve Humphrey the following on July 15, 2014.
Description Unit price Qty Amount
2.4 ecotec system-8 wire t/b, ls alt $850.00 1 $850.00
O2 sensor $40.00 1 $40.00
Maf sensor $50.00 1 $50.00
Pedal $65.00 1 $65.00
Subtotal $1,005.00
sales tax 8% $80.40
Total $1,085.40 USD
Payment sent to stephen humphrey
Invoice ID 000112851
Since that date I have had my car running a total of 7 days. For the first 7 days everything went very well. On day #8 the motor no longer received spark. I troubleshot EVERYTHING on the motor for 2 weeks by replacing every sensor then returned the ecm to him. He kept it for 3 weeks and agreed it had failed and then sent me a "new" one, but the new one is not tuned correctly or has some other problem and the motor will now start and run but it runs very rough and therefore is not driveable.
For all of you who are thinking the obvious - maybe there is another problem...I yanked the motor this week and replaced it with another. Guess what ? Both motors run like crap in the same way. The controller is bad. Also, I actually receive a PO606 - ECM bad error message when scanning the ecm!
I have not heard from him since - he will not return my calls. I find it interesting that the reason that I went with him over some others was for the simple fact that someone posted that he was easy to get a hold of.
I am now facing having to purchase a complete new unit from CBM, but they do not deal with the E37 so unit and harness will have to go.
At this point, I have been completely abandoned by Steve. |
WrRider Samba Member
Joined: November 17, 2011 Posts: 114 Location: Hemet Ca.
Posted: Wed Oct 08, 2014 12:50 pm Post subject: Steve Humphrey Avoiding his customers |
Not really feeling any better as I found him posting 12 hours ago on ecotecforum.com. |
Posted: Wed Oct 08, 2014 1:34 pm Post subject: |
Posted: Wed Oct 08, 2014 1:37 pm Post subject: |
LOL Now I feel better. I did send him an email yesterday, but no response yet. I suspect he does not want to deal with the E37 as it is not a speed density setup - one of the reasons I did not use him originally. |
Posted: Wed Oct 08, 2014 1:43 pm Post subject: |
huh. heard nothing but good things, you should give him a call.....
sucks about your situation, sorry man _________________ They've done studies, you know. 60% of the time, it works every time |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Alpha Fab Samba Member
Joined: January 21, 2010 Posts: 59 Location: Michigan
Posted: Fri Oct 17, 2014 11:59 am Post subject: |
BajaLobster wrote: |
Which email? Send to [email protected]
I get really busy, so sometimes it takes me a day or two to respond, but I always respond.
We use the E67, however, I can help you in the current situation. If you're running a MAF, it's not a speed density system.
Steve is a stand-up guy, he would never intentionally rip anyone off. I'm unaware of this particular situation, but I'm sorry that it happened. Please allow us to help you get it figured out! We may be able to work with your E37.
ORAMGECRUSHer wrote: |
He's probably gone through all the spare POS ECMs he had laying around his shop and doesn't want to have to find or buy a new one for you. |
I can't tell if that was postured towards my business or not. I sure hope not. The off-road world is a small place - we treat everyone with dignity and respect. We expect the same. All the 'POS' ECM's we use seem to be working just fine, for 100% of our customers all over the world. In fact, I have probably 50+ 'POS' ECM's in stock for 2.2, 2.4, and 2.0 Ecotec's.
Oh, here's a video of our 'POS' ECM's making records on stock block Ecotec's. Enjoy.
Have a good one,
-AFI _________________ www.alphafabindustries.com
Specializing in EFI systems engineering, design and tuning for the GM Ecotec Platform. |
Posted: Fri Oct 17, 2014 2:23 pm Post subject: |
Hey I'm sorry I offended you. I just see a lot of that sort of thing going on with people making custom pieces. You make good with Lobster and I stand corrected. Just keep in mind a quick communication with paying customer goes a long way to avoiding these kind of frustrated reactions. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Fri Oct 17, 2014 9:06 pm Post subject: |
I'm sure no one was trying to upset you Shaun as the recent posting is about my experience with the Stand Up Guy Steve Humphrey.
It s a shame that so many threads on the internet get hijacked or turned into some ridiculous rant, but looks like this one is going that direction....
I've owned Steve's $1100 box of wires / pcm for about 90 days, of which the car ran for 3 weeks...with a lot of error codes that Steve told me not to worry about.
I'd say that since the pcm failed about 5 or 6 weeks ago and Steve has not returning my phone calls since - I've been officially ripped off.
Now that said, I'm over it and Steve. I'm only interested in fixing my car.
My "local tuner" priced me at $700, spent an hour with the car and told me he couldn't "get into it" and politely declined...didn't charge me a penny.
I mailed it to CBM. CBM turned me down and sent the pcm back to me. They were very nice, sympathetic and accommodating but said they could not service the setup as it stood and could "try" if I could get the car to them sometime towards the middle of November. They also offering me a MEFI5 solution at $1600 which is nice but I am still trying to salvage this POS setup.
Moving on to fixing my car - I need to purchase $500 HPtuners and a few different E37s, spend about 100 to 200 hours learning about tuning, start switching sensors, throttle bodies, injectors and probably in the end - motors until I get this heap running...Or of course I could just hire a professional to fix the car right?
Shaun, are you that professional? If so, I'm ready. What would you like to do? I've sent you an email with some details. Thanks |
Posted: Mon Oct 20, 2014 1:01 pm Post subject: |
Email received, good to chat with you. We'll take care of this, free of charge, as discussed.
Looking forward to hearing about the car running, not sitting.
