Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Mon Jun 09, 2014 3:59 am Post subject: |
Outside dia is 84mm on a stock cylinder that makes 2mm wall thicknes.... no "slip in" for me. |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Mon Jun 09, 2014 6:46 am Post subject: |
yes that sounds more like it... the stock hole in a case is 84mm right? with a 3.5mm wall on the stock cylinders. Or have I got that totally wrong? |
tobiasax Samba Member
Posted: Mon Jun 09, 2014 7:36 am Post subject: |
pig-pen wrote: |
The hole in the case is approx 82 mm, but the hole in the cylinder heads are 84 mm.
Stock cylinders: (82 - 77)/2 = 2,5 mm wall thickness in case end
AA cylinders: (82 - 80)/2 = 1 mm wall thickness in case end
Stock cylinders: (84 - 77)/2 = 3,5 mm wall thickness in head end
AA cylinders: (84 - 80)/2 = 2 mm wall thickness in head end _________________ __________________________________________ |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Mon Jun 09, 2014 9:20 am Post subject: |
I have a big-bore cylinderbank for an old Honda CB500 Four (from 498 up to 591ccm with 61mm bore), I measured 1,3 mm walls. That was thin! _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
Posted: Mon Jun 09, 2014 12:27 pm Post subject: |
I wrote to aircooled.net and asked about these cylinders. Here is their reply:
Hello Peter,
I was passed this email this weekend and answered it before I arrived to work today. I was unfamiliar with this product, but very familiar with 36hp engines and when I read that we were selling "slip-in" 80mm cylinders, I was a little shocked. I got out my calculator and, with a little math, found that, if we did have 80mm slip ins, the cylinder wall would be less than 2mm thick at the top which prompted my first email saying that it might not be a good idea.
When I got into work I started looking into what the story was on this. Apparently one of our new ladies inputting products into the catalog has made a mistake. These are not a "slip-in" version. They do require machining.
If you are able to do machining, this WILL be a great option because the cylinder walls ARE still thick. If you are looking to bolt something on, this is probably not what you need. _________________ http://vw-bluehats.blogspot.com/ |
Posted: Mon Jun 09, 2014 2:45 pm Post subject: |
Peter_Plade wrote: |
Hello Peter,
If you are able to do machining, this WILL be a great option because the cylinder walls ARE still thick. If you are looking to bolt something on, this is probably not what you need. |
Well that sounds good |
PANZERVW Samba Member
Joined: March 29, 2013 Posts: 44 Location: Los Angeles, California
Posted: Mon Jun 09, 2014 8:13 pm Post subject: |
As I read the discription on this product will it really be that easy of an install item for what is described as quick HP? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Jun 13, 2014 12:18 pm Post subject: |
Apparently no one did, as the last email I got from the stated that they properly wouldn't have them in stock ready to sell before the end of the year. _________________ http://vw-bluehats.blogspot.com/ |
mark tucker Samba Member
Posted: Sat Jun 14, 2014 7:39 am Post subject: |
one day I will get one of these 36ers and see what you guys are talking about.and make it biger better badder.....or just to look at. 356/912 had 85 or 86mm cylinders so why not for the 36?just wondering from a 2332+ guy. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Thu Jun 26, 2014 10:51 am Post subject: |
I asked the AA guys about these sets at the Classic last weekend. They don't exist. The gentleman said he had some calls about them recently and did not know how the rumor got started. I mentioned the advert referenced earlier.
He did say though that if the demand was there that they would make them. He did feel that this segment of the market seemed to be showing a greater interest lately so time will tell. |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Thu Jun 26, 2014 3:12 pm Post subject: |
mark tucker wrote: |
the stud spacing on a 36 is different (narrower) than a 3 piece case 356 motor. |
Posted: Sun Jul 27, 2014 11:26 pm Post subject: |
not connected to the title, but thought it would be a waste of space to start a new thread...
I have found some oversize japanese 78.5mm pistons with 38mm comp height... (but annoyingly they are 22mm pin)
this would leave me with 1.75mm wall at case end and 2.75mm at head using stock 36hp barrels.
does this sound ok? enough?
Posted: Mon Jul 28, 2014 12:36 am Post subject: |
I Think its a bit too thin, the factory had 78mm as the biggest oversice and even they are thin. |
Posted: Mon Jul 28, 2014 1:05 am Post subject: |
dammit! thought you might say that. |
Posted: Mon Jul 28, 2014 6:03 am Post subject: |
ok, so here is another question...
AA are now listing the cylinders as 356 / 36hp (not slip in) which makes more sense, but there are no pistons.
What are people using for 80mm pistons? I know the porsche will work but only with porsche rods right? due to lower compression height?
I have found some more Japanese pistons which are 80mm bore / 20mm pin / 36mm CH.
So 2mm short of the 36hp 38mm CH... would I be able to make these work?
Posted: Mon Jul 28, 2014 6:10 am Post subject: |
hmmm... so not wanting to dribble on...
but will 36mm CH work just nice with a 69.5 crank giving almost a stock width engine???
or have I got that totally wrong? |
TomSimon Samba Member
Posted: Wed Aug 06, 2014 7:58 am Post subject: |
Anyone who has played with race engines knows this: One of the things that makes building old, period correct hot-rod engines so darn frustrating is the lack of performance parts, reliable information about fitment, and reliable delivery dates of new performance parts.
For information about these 80mm P&C kits from AA, I'd email AA's general manager and VP of sales Ron Barrett directly to get the straight scoop...
[email protected] |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sun Aug 24, 2014 11:39 pm Post subject: |
Modify a set of 912 cyls., bore for 83.50 and use an Okrasa 69.5mm crankshaft gives you: 1522cc's. Install a Porsche 74mm
crankshaft and now you have: 1621cc's! If I remember correctly, the barrel thickness at the head meas. 3.5mm+
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
