matt94gt Samba Member
Joined: April 29, 2014 Posts: 245 Location: Victoria BC, Canada
Posted: Thu Jun 26, 2014 7:05 pm Post subject: |
aeromech wrote: |
Too much trouble to swap sides with the battery. Just fix it. I can't weld so once I bought a replacement tray for the right side and cut and fit it to lay over the top. Then I used a marine sealant to basically glue it in place. Sounds like a hack but actually it came out ok since I was painting the whole compartment. |
Ok I was more so just curious. Thanks! Cool Idea. _________________ 72' Sunroof Bus - Kansas Beige
http://www.vw-mplate.com/mplate-21257.htm
Build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7257521 |
RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
Posted: Fri Jun 27, 2014 6:09 pm Post subject: |
aeromech wrote: |
I'm so glad you posted this. I'm waiting for the guy who's going to swap my engine to let know me when to bring him the '73 but I wanted to replace the battery tray beforehand. Now I won't have to hire a mobile welder.
After seeing all these nice engine bays I'm going to clean mine up this weekend. Anything that shouldn't get wet? BTW there's no engine but still wires and cables. _________________ 1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/ |
curtis4085 Samba Member
Posted: Sat Jun 28, 2014 4:43 am Post subject: |
RixiesRide wrote: |
aeromech wrote: |
After seeing all these nice engine bays I'm going to clean mine up this weekend. Anything that shouldn't get wet? BTW there's no engine but still wires and cables. |
Don't get anything but the body wet.
As soon as you spray in there be prepared to replace your ceiling. Don't get any electronics wet!! Don't power wa your wires or the fuel tank. If its metal your good.
I usually clean all my wiring by hand then use a protectant on the plastic sheath then I cover it up. Then me and a hot bucket of water and purple power attack. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Sat Jul 05, 2014 7:33 pm Post subject: |
Thanks Curtis!
I'm trying to make some room so I can squeeze by arse through the hatch.
Can I remove this canister and the fan that's hanging there, and will I still need those items if I'm swapping in a 2.0 with carbs?
(sorry I don't have my manuals so I don't know what they are for). I see a lot of engine pics without them.
My ceiling is in good shape so I'm going to remove that before I clean.
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Sat Jul 05, 2014 10:43 pm Post subject: |
They are part of your emissions system to keep the fuel you paid for in the tank, instead of floating off in a fog when it gets hot out.
For the full meal deal, read this post from 5 years ago that I wrote for the Beetle. It is equally applicable (more so if you intend to sleep in the bus) for any model, and doesn't matter if you are fuel injected or carbureted.
M
http://www.thesamba.com/vw/forum/viewtopic.php?t=389074 _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Posted: Sun Jul 06, 2014 11:04 am Post subject: |
Thank you Webwalker for the link. That looks like something even I can do.
The guy that's doing the engine swap from my '79 to my '73 told me to make a list of stuff I want to strip off the '79
and I'm learning that I should strip every little knob and part no matter how rusty it looks. Don't throw anything out. _________________ 1973 Wild Westerner "Mr. Peabody"
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Tue Jul 29, 2014 7:10 pm Post subject: |
Finished the low budget refresh of my 71 Westy engine compartment...
Before:
After:
A few along the way:
_________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
airschooled Air-Schooled
Posted: Tue Jul 29, 2014 7:41 pm Post subject: |
Vee Dub Nut wrote: |
Low budget? Can't tell from here! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Tue Jul 29, 2014 7:42 pm Post subject: |
asiab3 wrote: |
Low budget? Can't tell from here! |
Haha, thanks!... It's a rattle can special (it photos well too) _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
Posted: Tue Jul 29, 2014 7:44 pm Post subject: |
asiab3 wrote: |
Haha, thanks!... It's a rattle can special (it photos well too) |
Ah- I'm planning on a similar Aerosol Overhaul when I get my engine build finished.
Unrelated- does your car stumble or bog off the line on the first drive of the day? I'm looking for preheated air OR heat risers and see neither. I needed it in Phoenix AZ, so I'm curious. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Tue Jul 29, 2014 7:57 pm Post subject: |
Keen eye... No the preheat tubes were completely eaten through and weren't able to be saved, so they were trimmed. This was a temporary solution for now to get it operational. Don't have the air preheat hooked up either, and no stumbles so far. That said, I'm in south Texas and it was 101 today. My experiences might change with cooler weather down the road.
Longer term plans are to drop in a 2176 stroker that I have complete in parts, along with dual throttle bodies and Megasquirt EFI.
I picked this westy up about 2 months ago, so for now it was clean up and refresh the existing (and apparently healthy) stocker engine. Focusing on getting it road worthy for now before I start with the upgrades. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Jul 31, 2014 9:40 am Post subject: |
Good job but sometime you should ditch that exhaust and get a bus exhaust. That one will cause headaches. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu Jul 31, 2014 9:43 am Post subject: |
Thanks! That exhaust is on "the list" of things to be attended to.
This engine overall is just temporary, and I'm just focusing right now on getting it road worthy for the time being. This bus had been off the road for the past 7 years when I got it. The remaining upgrades will follow. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Jul 31, 2014 1:37 pm Post subject: |
Desertbusman wrote: |
As far as a good detergent for decades the old powdered Tide laundry soap is about the best when used in a thick solution |
I noticed in another thread that you recommended Tide.. I thought what the heck my engine tin is dirty, I'll soak everything in a big tub of hot water and Tide.
My fan shroud is now at the powdercoat shop.. The Tide made the OG paint bubble up inside and out and the paint completely failed!
It didn't hurt anything else, just the fan shroud. Y'all gotta be careful not to leave your stuff soaking in it too long _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
COVeeDubb Samba Member
Joined: April 28, 2010 Posts: 36 Location: Colorado Springs
Posted: Thu Jul 31, 2014 9:14 pm Post subject: |
I used the power washer, simple green and purple power
Matt _________________ 1975 Bay Window |
