highlandmurf Samba Member
Joined: April 08, 2010 Posts: 296 Location: Hudson Valley, NY
Posted: Mon Jun 09, 2014 6:55 pm Post subject: Rear end vibration |
Hi all,
My early '76 has developed a vibration in the rear end.
It is present throughout the range, but seems loudest between 35-45 MPH.
From the drivers seat, I cant really tell if it is more right or left, just that it is in the rear.
It stops briefly when I jerk the wheel to the right.
Any thoughts as to what it might be?
Thanks _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Desertbusman Samba Member
Posted: Mon Jun 09, 2014 7:15 pm Post subject: |
Typical CV joint symptom _________________ 71 Superbug
71 Westy |
Posted: Wed Jun 11, 2014 5:46 am Post subject: |
Does the fact that the sound stops when cutting the wheel to the right indicate which CV or side is having the issue?
2.0 stock FI
My M-Plate |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Jun 11, 2014 6:07 am Post subject: |
highlandmurf wrote: |
Thanks |
It might but best to raise the rear, do a visual inspection for loose bolts and torn boots. From there spin each wheel while watching and listening to the cv's. The problem should become evident.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Jul 22, 2014 5:56 pm Post subject: |
OK, Getting back on this, and could use some troubleshooting help.
Here is the rundown of progress/diagnosis.
Last summer had this creaking noise in the rear end:
http://www.thesamba.com/vw/forum/viewtopic.php?t=572912&highlight=
Turned out to be the outer bearing on the passengers side.
Installed new CV joints on passenger side only while diagnosing the above problem. No change.
Changed passenger side wheel bearings. Above problem solved.
This summer developed the vibration that initiated this post.
Removed new CV joint from passenger side, replaced with former CV Joint. no change in sound of vibration
Swapped axles/ CV joints from passenger to drivers side. No Change in sound of vibration
Axle swap:
A--------B C----------D
C--------D A-----------B
80 mile road trip- Vibration is considerably louder now
Replaced Drivers side wheel bearings, No change in vibration/
sound.
Sound still cuts out entirely when the wheel is jerked to the right or going at speed around a hard right turn, as it was before the axle swap.
There seems to be no excessive play (side to side, or along the length)with the axles installed
So.... can I rule out CV joints altogether at this point?
Could it be a transmission problem?
Any insight is appreciated.
Thanks for reading through this. _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jul 22, 2014 6:07 pm Post subject: |
Try swapping the tires front to back. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 21, 2014 7:14 pm Post subject: |
And the verdict is that the outer bearing, passenger side that I replaced last summer failed with less than 2,000 Miles on it.
Actually, it probably started getting noisy after 1200 miles.
I hate re-doing things.
On the upside, I am getting pretty quick at taking the rear axles apart. _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Posted: Thu Aug 21, 2014 7:23 pm Post subject: |
Can you please tell us which brand of bearing NOT to buy? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
wcfvw69 Samba Purist
Posted: Thu Aug 21, 2014 8:13 pm Post subject: |
aeromech wrote: |
Can you please tell us which brand of bearing NOT to buy? |
x2 _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Mon Sep 01, 2014 7:25 pm Post subject: |
Bearings were PEX from Bus Depot.
However, this was my first bearing job, and I am not ruling out human error.
I thought they went in well, but am a little ticked that I pulled the drivers side bearings as well, while trying to diagnose this issue.
I guess a I will know in a few hundred miles how I made out.
Interestingly enough, the original inner bearings were stamped Hungary. So.... I guess maybe they were not the original bearings.
I bought the bus with 43,00 miles, so I guess they could have been swapped out. _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
white74westy Samba Member
Posted: Mon Sep 01, 2014 8:12 pm Post subject: |
I had trouble with the PEX bearings too. Got rid of them and replaced them with FAG bearings. The PEX were binding upon installation. They were installed properly. There was no way I was going down the road with them. Was told there hadn't been any complaints...it would seem otherwise. Just as a side, there is nothing with the Timkens that are available at your FLAPS either. |
Danwvw Samba Member
Posted: Mon Sep 01, 2014 8:40 pm Post subject: |
One of our Subaru Outback wheel bearings just went out at 51000 just out of warranty, I guess they aren't very good these days. I The early VW' wheel bearings rarely go out. I bet I have over 180,000 on my buses, and they are still fine! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Tue Sep 02, 2014 4:18 am Post subject: |
Dan,
I'll bet the Subaru wheel bearings aren't made by those pesky Germans. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
