captnslow Samba Member
Joined: September 17, 2012 Posts: 40 Location: Portland OR
Posted: Tue Jun 10, 2014 8:42 pm Post subject: Wheel Help Please!! |
Hey, so I've searched and I can't find ANYONE! running the wheels I want.
I have a 1970 Ghia that is pretty slammed in the front (stock width adjustable beam and spindles). It's about 2 inches off the ground. I have hardly any turning radius, but am planning on fixing that this summer (3 or 4 inch beam).
Stock wheels are 46mm offset according to this thread (half way down)
http://www.thesamba.com/vw/forum/viewtopic.php?t=352467
I would like to run these wheels. The're pretty cool, and no one else does.
Specs: 15x5.5 4x130 17 mm insett (the same as a + offset).
http://www.enkei.com/compe.shtml#
Question is, could I run a 3 or 4 inch beam with spindles pretty low and have pretty little fender rub? ( I was thinking 165ish tires).
Any thoughts and or experience would be appreciated!!!
Brendan |
Posted: Tue Jun 10, 2014 8:47 pm Post subject: |
These ones
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Wed Jun 11, 2014 7:08 am Post subject: |
The 5.5" will fit pretty well! You won't know about your beam width/how low/tires etc until you buy the wheels & finish engineering your suspension, but I would guess 2" narrowed would be plenty. Go for the gray & don't paint them! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
FRNKNSTNGHIA Samba Member
Joined: March 05, 2010 Posts: 411 Location: Kissimmee, FL
Posted: Wed Jun 11, 2014 11:41 pm Post subject: |
your issue wont really be the front. That can be corrected with a narrowed beam. Your issue will be the rear. Offset is way to low. Will require you to buy narrowed IRS rear spring-plates. So factor that expense in to your budget. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3480 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Jun 12, 2014 7:05 am Post subject: |
FRNKNSTNGHIA wrote: |
It's not the spring plates that are narrowed; it's the trailing arms. You will need shorter axles as well. If you narrow the trailing arms 26mm (1"), the shorter auto type 3 (driver's side?) axles are the right length. I've heard of someone narrowing their trailing arms 30mm and modifying some Empi replacement shorter type 3 axles to work. Hope this helps. Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Jun 12, 2014 5:34 pm Post subject: |
ALB wrote: |
It's not the spring plates that are narrowed; it's the trailing arms. You will need shorter axles as well. If you narrow the trailing arms 26mm (1"), the shorter auto type 3 (driver's side?) axles are the right length. I've heard of someone narrowing their trailing arms 30mm and modifying some Empi replacement shorter type 3 axles to work. Hope this helps. Al |
you are correct it is the trailing arms, I knew it didn't sound right when I typed it. But yes they will be needed. Otherwise the wheels will stick out a good .5-1 inch from rear fender.... |
Posted: Thu Jun 12, 2014 9:41 pm Post subject: |
Well that's too bad. But ok. Where do I go to get narrow trailing arms? Can I also get them with a degree or two of negative camber to pull the top of the wheel in?
Thanks
Brendan |
Posted: Fri Jun 13, 2014 9:18 am Post subject: |
oldspeed in CA builds them custom. Search for his name Here! _________________ https://imgur.com/user/FisherSquareback/posts
ALB Samba Member
Posted: Sun Sep 14, 2014 3:17 am Post subject: |
Looking good! What did you finally settle on for tire sizes? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Sun Sep 14, 2014 4:49 pm Post subject: |
I like that wheel! Any more photos? |
