luh72superbeetle Samba Member
Posted: Wed Jun 11, 2014 10:34 am Post subject: Rat rod headlights? |
I'm looking to build my bug with no fenders where can I purchase the headlights and rear lights? |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Wed Jun 11, 2014 11:20 am Post subject: |
Any Hot Rod shop could help. Speedway Motors comes to mind. Good luck |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Jun 11, 2014 1:52 pm Post subject: |
Yep.. Speedway Motors has the best deals on "Can" lights..
Just about any flavor you want.. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
rgdedge Samba Member
Joined: October 17, 2006 Posts: 862 Location: Seymour, TN
Posted: Thu Jun 12, 2014 3:47 am Post subject: |
Mooneyes
Speedway
I run the chrome dune buggy headlight housings on mine.
Tim _________________ ()o\|/o() |
65bughando Samba Member
Posted: Fri Jan 23, 2015 8:45 am Post subject: |
rgdedge wrote: |
Mooneyes
Speedway
Tim |
Tim. question.. im running KC lights on my rat but lights only come with two wires...how do i get ground on KC lights? do i have to use a relay to make them work |
Posted: Fri Jan 23, 2015 3:08 pm Post subject: |
Not Tim.. but....
What bulb does your KC light use?
Typical KC Highlites or Daylighter Use a single element bulb.. ?
One wire is power, the second is ground...
eyetzr Samba Member
Posted: Fri Jan 23, 2015 4:26 pm Post subject: |
As previous stated. 2 wire 1 beam. You could put 4 lights on the front 2 low beam & 2 for high beam. If you can fit in different bulbs change single filament to double filament. I used a daytime running light module(we need daytime headlights up here) on a buggy, with the module the high beams run 1/2 voltage, which worked fine for "low" beams, & when you switch to high beam you have regular voltage. Look up a company called "see me". I may have a spare module if you are interested pm me. _________________ I think he meant "rare", as in "not well-done" |
Posted: Sat Jan 24, 2015 6:19 am Post subject: |
VOLKSWAGNUT wrote: |
Not Tim.. but....
What he said.
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sat Jan 24, 2015 8:40 pm Post subject: |
Cheap NAPA trailer lights.
_________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Jan 25, 2015 5:02 am Post subject: |
Good suggestions already made. Other ideas are to look at aftermarket motorcycle sites. All kinds of things there as well. _________________ D-Dubya Manx clone - 63 Short pan,1914.
