EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Mon Feb 16, 2015 9:33 pm Post subject: |
Ordered the harness, so lets talk fusebox cases and switches. Feel free to post links and images I've been looking around but can't decide what size. |
Posted: Wed Feb 25, 2015 2:47 am Post subject: |
Posted: Wed Feb 25, 2015 11:44 am Post subject: |
Some unboxing
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Thu Feb 26, 2015 10:11 am Post subject: |
A little advise from what I learned rewiring my old jeep with a kit. Lay it out on the floor for how you plan on running the wires, then separate it front to rear then by where it goes. Use a couple zip ties when you need to branch it off, add a couple wires from the front to the dash area for extra lights in the future, a couple wires to the engine bay for extra guages, and a couple for rear lights. Then lay it in the car cut wires a little long. If every thing is right use some split loom and electrical tape and wrap it up for a clean and tidy install.
You should start your own build thread and put it in your signature so we can check out your project. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Thu Feb 26, 2015 10:26 pm Post subject: |
I'll do that... still trying to figure what I need to order by checking the gauges on all the wires. In any case more rain this weekend so I'll have to wait before I can tear out the old and prep with some wire wheel and Rustoleum hammered (got the idea on here) under the hood, plan on cleaning up the gas tank as well, and putting the damn hood on a hinge so I can get under it.
Please let me know if those two tools should suit my needs, for non insulated crimper and weatherpack crimper, I cant find those open barrel type terminals anywhere not even Delcity. Front and rear lights will all be weatherpack 4-pin style I believe, and standard F crimps for the dash. I had an idea of buying a roll of that tool drawer liner and cutting a strip to seal off under the dash cover so its not drafty. Two more questions... I need a little help figuring out how I'm going to wire up switches, especially with relays that were not included in the harness. Last is a ground buss bar strip terminal whatever you call it, I want one. I'm not really sure how to set it up though, but would I need more wire that the harness has? I'm taking electrical circuits but the concept of grounds is much different on paper, everything is a nice closed loop but in reality the current just flows through the car on its way back. For example, would I need to run power to the rear lights and then buy a huge spool of black wire to wire everything back through the car and up to the front somewhere? Then I read to run a fat wire down to the pan or something for a single ground.
I found some electrical boxes today. I like the non metallic flexible conduit idea not sure if 1/2" or 3"4" though, and I'll use connectors from the box. What are your thoughts on using mounting pads to organize wire. |
Posted: Fri Feb 27, 2015 7:59 am Post subject: |
It's a steel car so if you have ground straps in the factory locations there is really no bead for a grounding block. There are grounding studs at each corner for lights, at the Guage cluster. If you think about it the starter dosnt have a dedicated ground strap directly to the battery, so I wouldn't think the lights require it. Do a search on here there are some really good write ups on how to do electrical. There are factory schematics on this site. Your crimpers that you posted are fine. The strippers are good. Draw your wiring plan out decide what you want to have on relays then work on the relay circuits separate. How you want to switch them ignition power or batt power. Look on YouTube fore wiring help also. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Mon Mar 02, 2015 8:14 pm Post subject: |
Ordered some parts so I can start next week. Some metal up front has been cut away so the PO grounded stuff up front to screws that hold on plates. In the rear some stuff was grounded to the tube bumper. If I hit the front with Rustoleum will it still be reliable to use screw holes and ring terminals for grounds? |
Posted: Tue Mar 03, 2015 12:51 pm Post subject: |
Its best to have bare metal, you can paint. Just clean to bare metal so the ring terminal contacts bare metal. A lot of issues people have start with bad grounds. Burnt connectors, corrosion, dim lights, burnt switches that type of stuff. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Sun Mar 08, 2015 7:40 pm Post subject: |
I got some of these terminals on Ebay. They are Tyco ring terminals in 10-12 gauge. (Also got push on connectors of the same brand). The ratcheting crimper I bought from Del City doesn't seem to work with these properly. The crimping area on the terminal is wider than what the crimper can do in one pass, so it mashes up whatever doesn't fit. I've seen people use one hand to crimp with the tool, I can barely finish a crimp with both hands. Was not expecting it to be that difficult. My question is what terminals do I need and where can I buy the open style, rings and push on connectors, I can't find them anywhere in small orders. To clarify, I'm using this tool. _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
dustymojave Samba Member
Posted: Mon Mar 09, 2015 3:00 pm Post subject: |
The crimper I've used for a few decades now is a Belden. But they don't show it in their catalog anymore.
https://edeskv2.belden.com/Products/#s=crimp%20tool&r=1
It's a common sort of plier type crimper. Something like this
But vastly better quality. all those years ago, they cost me nearly $30.
It includes wire cutter; strippers in sizes from 22-10 stranded and 18-8 solid and another male/female crimp zone for 22-10 non-insulated; crimp zones for 22-14 and 12-10 insulated and for ignition cable ends; and screw cutters in 5 sizes. _________________ Richard
SoCalBajas Member
Posted: Mon Mar 09, 2015 7:44 pm Post subject: |
Well, I bought the wrong type of connectors. The push on are too small and the rings are too big, both I destroy trying to crimp. The tool was 30 dollars also so I just need someone to point me in the right direction for terminals. I need some for 18, 16-14, and 12-10 gauge in both push on and spade. Dale M recommended the tool from DelCity. Is there a store that sells these, or do I need to look here? http://www.qualitycycleparts.com/Motorcycle_Electrical_Connectors_wire_and_terminals_s/7240.htm _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Sat Mar 28, 2015 8:35 pm Post subject: |
Got everything up under the bonnet painted.
Stupid brake light switch started leaking this evening at the rubber part. Glad I wasn't out driving it. _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Mon Mar 30, 2015 12:29 am Post subject: |
Looks WAY better than last week when I saw it in person.
It was good meeting you and your dad. Sorry we didn't have more time to hang out and talk more. And sorry too that my wife was feeling grumpy and not sociable and never got out of the car to meet you.
I've had good results from the master cylinder and switches I got from AutoZone for $17 about 6 years ago. They've been pissing me off about other things lately though. _________________ Richard
SoCalBajas Member
Posted: Sat Apr 04, 2015 8:27 pm Post subject: |
Thanks for dropping by!
Been a minute since I posted, so here's an update. Got the fuse box wiring routed in the box, mounting location, etc. I separated the front and rear harnesses to run tomorrow. Got a lot to do.
Posted: Sun Apr 05, 2015 7:56 pm Post subject: |
More progress. Ran the rear harness into the car, which was not easy. I also ran the front harness which I did after taking the picture.
Posted: Sun Apr 05, 2015 7:59 pm Post subject: |
You know what I just thought, how the fuh am I going to get the speedo cable up. _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Tue Apr 07, 2015 4:24 pm Post subject: |
Looks like you have the speedo cable blocked with the electrical box. _________________ Richard
SoCalBajas Member
Posted: Wed Apr 08, 2015 2:41 pm Post subject: |
What is this? It's next to the starter. Also, it seems the main fused batt + goes to it over the Trans. That and the reverse light switch wire go through the little hole to the right of the shift linkage plate. Anything else goes through the main harness exit correct?
EDIT: After today I'm also unsure of where the purple IGN SW START goes to and how to route it. I rain it through the rear and its too short to go anywhere.
warwgn Samba Member
Joined: November 18, 2014 Posts: 260 Location: central Mississippi
Posted: Thu Apr 09, 2015 5:36 am Post subject: |
looks like a remote solenoid, lot of chevy guys run them with headers so when the starter gets hot you can still start the vehicle. Not sure why one would be on the bug though? I would say you can ditch it. |
