EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Mon Aug 24, 2015 8:05 am Post subject: |
Didn't have one, didn't need it. _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2647 Location: West Coast (Michigan's)
Posted: Mon Aug 24, 2015 11:39 am Post subject: |
EnjoyNukaCola wrote: |
Well here it is. I painted it up, greased the steering box and put on a new coupler. I installed it on the car by rolling it out on a dolly and setting it on a wheel, then raising it up with blocks. I still have to finish the brakes (one of the calipers is rubbing) and setup the steering and alignment. Overall, I'm quite happy with how it turned out and can't wait to use it. |
looks good, good job brudda _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Sun Aug 30, 2015 6:47 pm Post subject: |
Got the steering and brakes setup. Fixed the rubbing by choosing the best caliper for each rotor and placing the curvy washer between the backing plate and caliper, there is now just a hint of drag. I did a vigorous bleed procedure, first bleeding the front calipers passenger side then driver side from the top screw. Then went to the rear passenger side and driver side for good measure. Back to the front again this time I bled both screws with an adapter on my bleed kit, passenger side then driver. Spent over an hour doing this clear fluid in all lines. Took it for a spin while holding the brakes for a bit then did a couple hard stops. There's some funny pedal travel but I am able to lock up the fronts with some effort. I think it has to do with the rears being out of adjustment already. Alignment tomorrow! _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Mon Aug 31, 2015 4:14 am Post subject: |
I made a brake bleeder out of a garden pressure sprayer. It works great on my tube frame buggy with the aftermarket reserviors. I'm not sure if it would work with the stock remote reservior system but ,man it sure makes things easy - maybe if you didn't go crazy with the pressure. Just find a duplicate res cap and put a barb on it to attach the sprayer tube and pump it up and let the pressure push the fluid through. It's great when you just want to clean out your lines too. Cheap to make and takes one man to operate. _________________ Brian H.
HERC Samba Member
Posted: Mon Aug 31, 2015 7:05 am Post subject: |
That thing came out boobies. I'd take it in the house, knock all the shit off the fire place mantle and put that up there instead.
That way, visitors can admire your work, instead of potpourri jars and candles. _________________ Herc |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Mon Aug 31, 2015 7:34 am Post subject: |
With a light coat of WD40 for fragrance, the cologne of real men. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
HERC Samba Member
Posted: Mon Aug 31, 2015 1:13 pm Post subject: |
Now yer talkin. Couple of pistols to book end it. _________________ Herc |
Posted: Sat Sep 12, 2015 10:38 am Post subject: |
Stupid question, but what could possibly be squeaking in the front end being all new? Lower shock mounts? _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Sat Sep 12, 2015 1:03 pm Post subject: |
Probably your delrin or urethane beam bushings. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Sep 12, 2015 1:05 pm Post subject: |
Wait a second, you're driving it & haven't posted pics?!? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Sep 12, 2015 1:38 pm Post subject: |
TDCTDI wrote: |
Wait a second, you're driving it & haven't posted pics?!? |
Posted: Sat Sep 19, 2015 9:00 pm Post subject: |
Update on stuff. Got the old stereo working again. Got some keys made so I can lock my doors now. Been busy so I haven't had time to take it out for some fun. I think I want to swap out the new KYB in the rear for the same Bilstein set because when I go over speed bumps fast (its fun) the rear end hops like its too stiff compared to the front. It handles great for the most part, sometimes it gets a little bouncy coming to a stop. And its running decent a little on the rich side, but I get some sputtur/ bucking at times. The motor is pretty strong so I think it might be something with the trans.
With that being said, what's the consensus for Wright gearbox vs Rancho? Also are these guys any good?
http://losangeles.craigslist.org/lgb/ptd/5175362051.html _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Sat Sep 19, 2015 9:17 pm Post subject: |
Oh, ask and you shall receive
HERC Samba Member
Posted: Mon Sep 21, 2015 7:00 am Post subject: |
That thing looks awesome. _________________ Herc |
Posted: Fri Sep 25, 2015 1:19 pm Post subject: |
I tightened the trans strap down last weekend, and its starting to shake in 1st worse than ever. I think the stuttering/ bucking is also the trans in 2nd and 3rd shaking back and forth. I don't think its the motor it runs fine otherwise it might just be jerking the throttle around. _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Fri Sep 25, 2015 2:25 pm Post subject: |
Check your CVs, old or insufficient grease can cause the CVs to bind, so can too much lift in the rear. A transmission that starts making vibrations usually makes a bunch of noise first. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Sep 27, 2015 9:35 am Post subject: |
Short tearing the CVs out, can I jack the rear just off the ground and run it through 1st? Any binding should be apparent. It's not lifted in the rear to my knowledge. And the trans is VERY vocal lol. _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Sun Sep 27, 2015 10:45 am Post subject: |
Drain the gear oil, check for metal, if you've got chunks then you'll need a trans, if not, you can fill it up & you might be able to get a can of spray chain grease, slip the little red tube that comes with the can between the CV boot & axle & inject some grease into the joint (not ideal but cheap/easier & will give you quick results to let you know if that's your problem) _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 28, 2015 9:45 pm Post subject: |
IIRC some bits and shavings came out when I flushed it, that was about 6 months ago.
Last Friday it started bucking at the top of 2nd and going into 3rd. It's like I'm like I'm mashing the pedal while in gear. When that happens its hard to get into third like something is blocking it from engaging I cant cross over to 3rd, then it grinds when it engages. I was driving on flat ground and it did it, getting into third and pulling up to speed makes it go away. Then I was driving uphill and it did it again, but I couldn't find 3rd this time and had to go back to 2nd and ride to the top at like 25mph in a 45. I clutched in and revved the motor and the bucking stopped immediately so that's why I think its the trans. It used to get bad when I drove it for a while, but now its bad right out of the neighborhood. It's been a real drag to drive lately especially uphill which there are a lot of here. Then there's also the shaking out of 1st gear which has gotten so bad the bolts holding the steering wheel on the hub starting loosening up, no joke. It's been getting progressively worse so I'm going to get a new trans while this one is still good for a core and redo all the rubber mounts and straps.
I'm considering a Rancho, Wright, or Jeff Fields type 1 with a 4.37 or 4.12. Transaxle Eng is pretty close but I hear he's $$$. Not against a pro street or close ratio 3rd/4th either but I'm liking the 5yr stock warranty. It's got 235/75R/15s on now but I might bump it up to a more aggressive 30" tire. What do I plan on doing with it? Probably 15-20% dirt 80% street and highway. I'd rather have the right trans with a stock 1600 more than anything because I'll be driving it several hours in any direction when I transfer colleges or go on trips so highway is important (loaded with stuff of course). As for motor, if its geared right a 1600 should do fine but I'd like enough power/gearing to spin the tires a bit that is all _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Sat Oct 03, 2015 4:08 pm Post subject: |
Should I try switching to an electronic ignition module if it's something like the condenser?
EDIT: Seems to be the condenser, swapped it out and it runs tits now. I would not have looked to it since its relatively new, but my neighbor got me on that one. (He has that TR6)
This was after timing and before condenser.
https://www.youtube.com/watch?v=gv-2Z1tdqOw _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
