Dodesvw Samba Member
Joined: July 26, 2012 Posts: 32 Location: Los Angeles, California
Posted: Sat Jun 14, 2014 2:11 pm Post subject: Weber North America carbs? |
I recently received my order of dual weber 40idf carbs with linkage and manifolds to go on my 67 bug. The engine is a 1915 dp with a mild cam and stock heads. I ordered "genuine" webers but since then I have done some research and learned that the weber name is being licensed out to various manufacturers including China. The carbs I got are NOT stamped at all on the actual casting. The only thing that says weber on it is the metal plate on the front and two round stickers that say "weber north america serial #49730 warranty void if removed". Is there any way to tell where these carbs are made? Are they junk compared to Spanish webers? Just looking for people who have ran these webers what are your experiences. I will return these if there is a big difference in Spanish webers and these North America webers. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sat Jun 14, 2014 2:33 pm Post subject: |
North America licensed Webers "Made In USA" have a flat section where the set screw that holds the venturie in place.
Real genuine Webers from Spain have "Made In Spain" cast in the base.
EMPI HPMX carbs are Chinese copies.
Decade carbs are Chinese copies.
I would return the USA Webers and get the real "Made In Spain" Webers. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sat Jun 14, 2014 2:40 pm Post subject: Re: Weber North America carbs? |
The "Flat Back" IDFs are made in China, but assembled in North Carolina. They suck. Get Spanish ones. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Sat Jun 14, 2014 2:52 pm Post subject: |
They aren't the flat back idfs. Not empi's either. So the general conclusion is that these are junk? I'm having an experienced builder/tuner set them up for me FYI. Anyone else use these? |
mark tucker Samba Member
Posted: Sat Jun 14, 2014 3:05 pm Post subject: |
are they junk...are they on your car? can you tune them?? do they work?? everybody knows the empi hpmx carbs are junk...but I didnt get that memo and have over 11 years on mine&they run great on my daily driver with well over 90000 miles on them. |
Posted: Sat Jun 14, 2014 3:15 pm Post subject: |
mark tucker wrote: |
They aren't on my car. I just opened the box and I'm considering returning. Them if they aren't quality carbs. I'm having someone set them up for me that knows what they are doing but I just wanted some opinions on here first |
Posted: Sat Jun 14, 2014 3:33 pm Post subject: |
quality cna be the instalation or lack there of. a lot og very good quality parts have been turned to poop in a hurry by many.and the same quality parts have given others thousands uppon thousands of happy fun miles with out any issue's.so unless a part is made rong/out of spes.damaged etc it's kinda hard to say it's junk...well there is some real junk stuff out there, it's all the latest rage.....well I havent seen it all,but plenty still the same. I had thought about getting some of those cheep $100. china webblers to stick on spair/old parts motor but havent done it yet. |
Posted: Sat Jun 14, 2014 6:33 pm Post subject: |
That makes sense. Thanks! I'll probably hang on to them and see what my engine guy thinks of them |
Dale M. Samba Member
Posted: Sun Jun 15, 2014 6:50 am Post subject: |
That's BS I have set of 44 HPMX carbs on street engine (2084) and they perform just like "Genuine Webers" and after 6-7 years not a problem one.... In fact a really gunky set of Webers where removed and replaced by the HPMX carbs.... And to top it off, the HPMX carb where recommended to me by a WEBER DEALER as a cost savings.......
Posted: Sun Jun 15, 2014 11:06 am Post subject: |
might want to read all of what I said dale....... |
Posted: Sun Jun 15, 2014 6:01 pm Post subject: |
Yeah, and you might quit the act, use proper spelling and invoke spell check, so what you write is readable....
And also I didn't get past the "junk" statement.... My fault that I did not read the whole comment and I over reacted to soon to the junk part of statement...
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sun Jun 15, 2014 6:03 pm Post subject: |
Then there are the really real ones...
Made in Italy _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sun Jun 15, 2014 7:43 pm Post subject: |
udidwht wrote: |
Made in Italy |
The Webers made in Spain are real Webers made by the real Weber company. They are made with the same dies and tooling. Weber stopped carb production in Italy and transferred it to Spain. Same company, same tools, same dies, just a different location. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sun Jun 15, 2014 9:10 pm Post subject: |
vwracerdave wrote: |
udidwht wrote: |
Made in Italy |
The Webers made in Spain are real Webers made by the real Weber company. They are made with the same dies and tooling. Weber stopped carb production in Italy and transferred it to Spain. Same company, same tools, same dies, just a different location. |
With one other crucial item...human element. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Mon Jun 16, 2014 12:41 am Post subject: |
it just sounds cooler to say you have Italian Webers _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Mon Jun 16, 2014 1:12 am Post subject: |
I had used Italian Webers. Some things on them were jacked up a bit and they didn't have vacuum ports, and auxiliary ventures were different from the common ones I can buy. The Spanish ones I have now are better IMO.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Mon Jun 16, 2014 8:39 pm Post subject: |
stan_tichomirov wrote: |
Stan |
My Italian made Webers came with vacuum ports and required nothing more than a simple cleaning then final jetting to be made to run awesome. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Mon Jun 16, 2014 9:27 pm Post subject: |
Weber made many different versions of the IDF carbs for lots of different production cars. I believe the version the VW crowd uses are originally from a Fiat. Weber never made carbs for VW engines. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
56bugdan Samba Member
Posted: Tue Aug 12, 2014 8:45 am Post subject: |
vugbug68 wrote: |
it just sounds cooler to say you have Italian Webers |
Haha! I'm sorry but he's right! People like to say they have the originals. I have a set of 40s that are at least 25 years old and I couldn't tell ya where they were made because I've never looked. I just know that once I put em on and syched em I never had to touch them again. IMO the originals aren't always the best you can buy. Later models (not just carbs) tend to have updates and the "bugs" worked out. As far as the HPMXs go I have no experience with them but I'm sure in the right hands they are good carbs. I think it's more of an EMPI thing that puts people off. Believe me I've had some experience with some sub standard EMPI products but I hesitate to claim it's all crap. Truth be told, given the current cost and quality of the new Webbers, I'd buy a set of the HPMXs if i needed new carbs. Just my opinion.
Posted: Tue Aug 12, 2014 9:55 am Post subject: |
[/img]
Sorry these pics are so huge! Not intentional but at least you can see what's stamped on em. They've been sitting for years so their dirty as hell. Don't know if their Italian or Spanish but these are the only markings I could find. These 40s came off of a Porche that was scrapped and I got em over 22 years ago, rebuilt them and ran em on my 67 bug with a 1915 for years. Sold the car but kept the engine and carbs. Just putting new Total seal rings in the engine and we're good to go. Italian or otherwise, they always ran great. My 36mm Dells are Italian! Haha |
