Fuel pump, carb, or neither? |
Fuel pump |
60% |
[ 3 ] |
Carb |
0% |
[ 0 ] |
Other |
40% |
[ 2 ] |
Total Votes : 5 |
Bughaus Samba Member
Posted: Mon Jul 14, 2014 1:21 am Post subject: |
Was it the Pertronix coil or the other one that was acting the fool? _________________ Eric
http://www.Bughaus.com |
AkioOhtori Samba Member
Posted: Mon Jul 14, 2014 6:35 am Post subject: |
Bughaus wrote: |
Was it the Pertronix coil or the other one that was acting the fool? |
Pertronix, for better or worse. Certainly has shaken my confidence in them.
You may have swayed me to the side of the Bosch Blue. |
Posted: Mon Jul 14, 2014 11:18 am Post subject: |
I can honestly we've never had a bad Bosch Blue Coil out of the box and have never had a return on one after 20 years of doing this. Everyone has an opinion of what coil is best and I have no interest in getting into that fray, but the Bosch Blue Coils are all we run in our VWs and we're happy which is why it's all we carry. _________________ Eric
Mrav8tr Samba Member
Joined: March 18, 2009 Posts: 187 Location: La Quinta, Ca
Posted: Tue Jul 15, 2014 3:04 pm Post subject: |
I'd go with the Carb float. If set too low the carb will run out of fuel at high RPM, full throttle.
Anyway, hope it's gone! _________________ " Life begins at the end of your comfort zone " |
ChrisRheinschild Samba Member
Joined: September 24, 2007 Posts: 81 Location: Clemmons, NC
Posted: Wed Jul 16, 2014 1:53 pm Post subject: stalling |
I am following this thread. I have a similar problem with my 74 Super convertible. I removed the tank. There was no screw on filter like on my older cars. There was just a nipple for the fuel hose. I gently used my air worm to blow through. Seemed clear. Next some welding wire through the front to back metal tube. Sprayed a bunch of brake cleaner from both ends. Next the air worm. Seemed clear. I cleaned up the tank vent connections. It had seemed to drain well prior to my fixes. I put my filter (metal) up front, clamps, new hoses etc.
I had previously raised the float, changed fuel pumps, coil, reset points, timing, checked manifold connections.
Just returned from a test drive of about 2 miles. It runs great.
This form has been a great help. |
Posted: Thu Jul 17, 2014 8:09 am Post subject: Re: stalling |
ChrisRheinschild wrote: |
Thank you for the update! Sounds like I have quite a bit more work to do!
Right now I am waiting on testing the new ignition/ coil to see if that has fixed the problem. I am sort of burnt out on trying to fix the problem, but might take another swing this weekend.
Thanks for the info! |
Posted: Sun Jul 20, 2014 6:26 pm Post subject: |
Interesting development. Turns out I had a bad chassis ground this whole time. I don't know if that will fix this problem, but it certainly wasn't helping!
http://www.thesamba.com/vw/forum/viewtopic.php?p=7292799
Still haven't gotten up the courage to check... |
LeeVW Samba Member
Posted: Mon Jul 21, 2014 10:47 am Post subject: |
Could be, could be!
Lee |
Posted: Sun Jul 27, 2014 3:51 pm Post subject: SOLVED |
Well I put on my big boy pants and took the Buggy for a jaunt on the motorway today. And... *drum roll*
The chassis ground *appears* to have been the problem.
I had a good headwind that kept me nice and bogged down and had no problems. Not 100%, but I am tentatively calling this one done.
Now to but 1000ft of green #10 and make the buggy look like a mad spagetti monster. (Not really... conductive grease, some more polish on the metal, and maybe a battery-to-engine dedicated ground...) |
LeeVW Samba Member
Posted: Sun Jul 27, 2014 5:11 pm Post subject: |
That's fantastic! Thanks for the update. Electrical issues can be a real pain to diagnose. It sounds like you gave your fix a very good test run. Fingers are crossed that it stays fixed. There's nothing like re-gaining confidence in your ride.
Lee |
