vwkever68 Samba Member
Posted: Fri Jun 20, 2014 8:46 am Post subject: Fram oil canister sealing/gasket problem |
Hi!
I just finished installing a Fram oil canister last weekend on my Judson supercharged 1300cc engine.
The problem I have is that the oil canister is leaking a lot. It comes all around the cover. I bought the items as NOS, but the rubber sealing was dried out. So I thought it had something to do with that rubber sealing located at the cover. I used some sealing compound all around it (as you can see on the picture) but it is still leaking.
I have seen other members here who are using this kind of oil filter, how do they seal the top cover? Can I order somewhere a new gasket or is it another problem ?
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Jun 20, 2014 9:09 am Post subject: |
it has been my experience from many years past, you need to use a rubber gasket in the top. maybe your local auto parts store or tractor supply will have a rubber seal ?
Make sure there is no dried seal or sealer in the groove.
I remember fighting them back in the 70's and was glad for the spin on filters _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Fri Jun 20, 2014 2:33 pm Post subject: |
Thanks! I already went to the local part store, but they don't have a sealing for it. I can order online a O ring that will fit but I am not sure it will work since the origional one is flat and I only can order the regular O ring which is round.
I checked https://www.sierramadrecollection.com thanks! Do you maybe have a spare set so you can measure the inner size of the sealing for me? I would be happy if it fits but I have to make sure since shipping to my country costs 22USD so I will order directly some spare sets. |
Posted: Fri Jun 20, 2014 2:54 pm Post subject: |
Kjell Roar wrote: |
You should use hoses with bigger ID on the return side than the pressure side.
Do you? |
On both sides I use the same size, I will explain it below:
The oil canister does the following standard connectors: 2X 1/8' for the inlet and output line. I have discussed it with a hydraulic proffesional and he recommend me this:
Use an adapter to convert the 2 1/8' to 1/4' NPT, so there can be used a 3/8' PTFE hose with Stainless steel. At the other end of the hoses we used also a 1/4' NPT which goes directly to my oil pump.
The oil pump does have an output and a input 1/4'.
If it is not clear I can post some pictures.
I understand your opinion but does that mean I have to change the origional thread in the oil canister? |
Posted: Fri Jun 20, 2014 3:06 pm Post subject: |
It can be that the inlet's are to small for this setup, I thought about it before. I will do some calculations to check the pressure inside the oil canister, Maybe I have to place a pressure relief valve on the inlet line but then the idea of full flow filtering is gone
I will think about it and let you guys now. |
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Fri Jun 20, 2014 4:04 pm Post subject: |
These are bypass filters and are intended to have a small orifice on the inlet side so as to not take too much oil away from the engine. I don't recall the orifice size to be used but it is small, maybe around 0.040 inches. I think this has been discussed at length on this forum, try searching for Fram filter. I like the rubber gaskets that come with the Fram c-3P filters, but there are fiber gaskets out there that can be used also. Try Stoddard for the fiber gaskets.
In re-reading your posts I am thinking maybe you are trying to use this as a full-flow filter. If this is so what model Fram filter are you using and is it intended to be used as a full flow installation? Also where are you returning the oil to after it leaves the filter? |
D-train Samba Member
Posted: Sat Jun 21, 2014 3:09 am Post subject: |
i had the same probs, order a new one from Klasse 356, havnt had a prob since. _________________ shiny paint doesnt make it worth any more |
Posted: Sat Jun 21, 2014 3:26 am Post subject: |
You are right. The filter is installed as a full flow filter this can be the problem.
I think I have a fram CP4 filter installed right now (have to double check, but I think it is a bypass filter) the first step I will make is to get my hands on another filter and a good sealing at the top. Hope it will work
I will let you all know! Any suggestions for the filter I should buy? |
Posted: Sat Jun 21, 2014 3:28 am Post subject: |
You mean ordering a new sealing? I can not find it on their website, should I sent them an Email ?
D-train wrote: |
i had the same probs, order a new one from Klasse 356, havnt had a prob since. |
Posted: Sat Jun 21, 2014 4:00 am Post subject: |
https://klasse356.cloudsites.gearhost.com/catalog/showItems.asp?Category=EOS
No13.
Also check u have the inlet to the canister as a smaller hole than the outlet otherwise the canister will pressurise and blow oil
I actually found a seal from a truck oil filter to be the same size as this seal needed, but taller. So when it tightened on the seal, the seal popped inside the unit causing it to do nothin but leak oil.. _________________ shiny paint doesnt make it worth any more |
Posted: Sat Jun 21, 2014 10:04 pm Post subject: |
If you have a fram c3 or c4 filter those are both bypass units and I don't believe they can handle the pressure that you will see if you plumb them as a full flow filter. A full flow filter runs at the oil pressure output of the pump and all the engines oil goes through the filter. It is plumbed between the pump out and the case oil passages to the engine oiling system.
A bypass filter is plumbed with a small orifice to limit the amount of oil it robs from the engine oiling system, this bypass oil is then simply returned to the engine sump. If you plumb a bypass filter with large lines it will bypass way too much oil and starve the engine as well as pressurizing the filter to an excessive pressure. |
Posted: Mon Jun 23, 2014 11:24 am Post subject: |
Indeed, I think it is the problem that I am using the wrong filter.
The filters mentioned by D-train and Erik G both are full flow filters ? I want to make sure that they are, and will fit since I will order some more (5pcs or so) since the shipping is expensive to my country. |
Erik G Samba Member
Posted: Mon Jun 23, 2014 12:14 pm Post subject: |
I see. I would like to start by trying to use it as a full flow filter just with installing a full flow filter without modifying the housing. If that does"t work (if the resistance of the filter is too high) I would like to try to make a sort of bypass inside the filter by drilling a hole through the filter.
Now is the question where can I get a full flow filter that would fit my housing.
I got standard 1\8" fittings, but as you can read above I use bigger lines not sure it would help a lot. |
Erik G Samba Member
Posted: Tue Jun 24, 2014 10:47 am Post subject: |
I saw that you replied to the other post and recieved the filter number. I would just add, you run a very high risk of loosing oil pressure on your return, thus starving your bearings if you are not very careful. Notice how much work he put into bigger fittings, different center "pole", etc. |
Posted: Tue Jun 24, 2014 1:29 pm Post subject: |
Erik G wrote: |
Yes I noticed. I would be very careful, but I do not have the same standard center pole. The one I have does have already some extra holes.
First I will try it without an filter, If that works I will place an full flow filter. When that fails, I think I will make the return port bigger and if that isn't working I will change the pole.....
Thank you all for your help. I will post the results here. |
baroach Samba Member
Joined: July 29, 2013 Posts: 1 Location: Vancouver, WA
Posted: Fri Jun 27, 2014 11:06 am Post subject: Same Setup |
I have the same Fram bypass on my 36 with Judson SC and use the WIX equivalent filter (too hard to find the Fram ) the WIX # is a 51010 and comes with a gasket that seals my fram can perfectly as long as you get it good and tight |
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Fri Jul 11, 2014 7:22 pm Post subject: |
I had a problem with a rebuilt filter assembly that I bought. Someone had powder coated the canister and cap. I tried several gaskets, rubber and paper, without success. I finally decided to use valve lapping compound to lap the cap to the canister. It didn't take long to realize they had powder coated over a paper gasket. Once I got the old gasket removed, and lapped in the mating surface's, it has sealed without issues.
_________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
