67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Jun 27, 2014 7:12 pm Post subject: Suggestions needed on how to get to bare metal |
'67 bug.
Primer, zenith blue, primer, darker blue, primer.
5 coats of paint!!
I started by sandblasting the fender wells and, although it worked pretty well, I read some articles about sandblasting heating up the metal and warping the metal.
I called around about soda blasting but no one does it around here. I used a wire brush on my grinder and it worked, but heated the metal too and was
S L O W!!
What to do?sandblasting get sand everywhere!!!
Btw: bug is in good shape with hardly any rust. |
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Sat Jun 28, 2014 5:08 am Post subject: |
Try Aviation Stripper. Apply with cheap brush, cover with thin painters plastic, let sit for a while until surface lifts, then scrape off. Chances are you may do this a few times but the first time is the most effective. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Sat Jun 28, 2014 8:22 am Post subject: |
vaughn bros. wrote: |
If you go that route, rinse it really well, or it might lift the new paint. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jun 28, 2014 10:04 pm Post subject: |
I used the aviation spray and let it sit for a few hours. It bubbled right up but still looks like I'll need to wire wheel. Seemed to work okay though?!
I'll let you know tomorrow!! |
BeetL62 Samba Member
Joined: January 05, 2005 Posts: 146 Location: Pottstown, PA
Posted: Sun Jun 29, 2014 11:38 am Post subject: |
Well it just took me about 3 hours to do most of one fender with a wire wheel attachment on my angle grinder. It came off pretty well and didn't gouge the actual metal once I got down to it. I'm afraid of sanding discs-don't wanna scratch up the metal.
What grit are the sanding discs? |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Mon Jun 30, 2014 6:05 am Post subject: |
I go with 80 grit on a rotory buffer. Pretty much tears paint and bondo off but the grit isn't so course as to ruin the metal. Filler need 80 grit to bond properly anyway, so you can go to epoxy right after this step after working the metal the way you want it. If there are deeper dents get the filler out with the wire wheel. And go from there. |
Posted: Tue Jul 01, 2014 7:54 pm Post subject: |
Bought the 80 grit discs but what speed would you recommend? My friend said kinda slow-if you go too fast it "melts" the paint instead of ripping into it. The wire wheel worked okay, but was S L O W!
I brought the body home tonight and it's on a roll around cart I made to wheel out of the garage on nice days.
I think the first step would be to wire wheel the bottom of the heater channels and apply por-15 to them and the lower parts of the rocker panels?
What do you think?
The chassis turned out amazing with the por-15!!! Very happy!! |
kman Samba Member
Posted: Wed Jul 02, 2014 5:43 am Post subject: |
Start slow. Can go faster as you get more confident. Don't angle it much, you will dig a hole and gouge the metal. I'm sure por-15 is ok for the bottom of the rockers. I've used it a couple of times and it seems to be strong stuff, but a bit expensive and goes bad quickly after opening. I'm a fan of epoxy sealer/primer then paint. |
Posted: Wed Jul 02, 2014 7:12 pm Post subject: |
Thanks for your help! I have two threads going on about bodywork now....sorry, I was just excited!
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Wed Jul 16, 2014 9:53 am Post subject: |
I am currently using the aviation stripper and I find if you don't use alot and cover it with plastic it dries out and stops working. The key is covering it to keep it wet. It takes off the 3 layers of paint on my 68 down to the factory primer. I usually need one more coat to remove the primer down to bare metal. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
RLFD213 Samba Member
Posted: Fri Nov 14, 2014 4:51 pm Post subject: |
I have been using paint stripper on my 69 bug. It is a lot easier and cleaner then sanding. I use a paint brush and brush it on heavy and then wait. Then I use a razor blade and scraper and it comes off super easy and just gets swept up or vacuumed. No dist and no noise. All I have to do is sand the rust spots afterwards and do my filler and priming. |
BerylGreen63 Samba Member
