1962 356 cabriolet ..should it have wood floor under mats?
lmc
lmc is offline
PostPosted: Sun Jun 29, 2014 8:15 am    Post subject: 1962 356 cabriolet ..should it have wood floor under mats? Reply with quote
Do all 1962 Porsche 356 cabriolets have wood floors under the front driver & passenger areas?. I have seen with or without What's correct? Thank you.
MMW
MMW is offline
PostPosted: Sun Jun 29, 2014 9:29 am    Post subject: Reply with quote
I believe the only wood on a 1962 B body should be the pedal board which is the semi vertical pc. behind the pedals & in the same location on the passenger side. The actual floor is steel.
I think that the early cars, pre A, had a wooden board over the top of the metal floor in addition to the pedal board but not positive on this.
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
Danwvw
Danwvw is offline
PostPosted: Sun Jun 29, 2014 10:03 am    Post subject: Reply with quote
My 1956-57 A had one of these: http://www.sierramadrecollection.com/store/cart.php?m=product_detail&p=2469 Made from about 5/16" 6 or 8 ply plywood and painted black, I think cars were all a little different!
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Sven Stark
Sven Stark is offline
PostPosted: Sun Jun 29, 2014 3:05 pm    Post subject: Reply with quote
That is correct. It means that the floor in a pre A is flat - the floor is on the same level as the top of the tunnel. The clutch cable is also routed across the floor, which looks very strange if you do not have the floor boards in place.
lmc
lmc is offline
PostPosted: Mon Jun 30, 2014 5:06 pm    Post subject: Reply with quote
Thanks for everyones help.
