vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Jul 07, 2014 7:27 pm Post subject: |
What other photos would be more helpful? (Besides the mentioned cylinders and pistons photos.)
I have certainly implied that I want to "slap it together" and probably said as much.
That said, I also feel like it would be a waste of money if "slapping it together" would result in a motor that wouldn't run well for for very long.
The title says "rebuild/repair" for a reason:
If everything else checks out as usable and this seems to have been some kind of freako thing, then a "repair" would be reasonable. "Repair" defined as replacing the cam, the bearings, and seals, and maybe any other parts that clearly need replacing.
If everything is on the edges of wear tolerances, or indicates the need for major refurbishment, well, then we're in the realm of "rebuild and I'll really have to rethink what I do. At this moment, I don't have the cash for a total rebuild and may have to go a different direction for getting the bus on the road.
I've said a few times here and there that I would like to look at some kind of engine conversion (and for the record, with this one I would only do it if I can make it totally reversible). That said, if the engine goes together decently I can certainly envision enjoying driving an aircooled motor.
Hopefully that clears up my aims with this project a bit. Maybe not, I dunno.
So, to get/keep this thread on track, I need to determine if the motor needs a "repair" or a "rebuild." _________________ Dave Cook
1973 Wild Westerner
My Thing |
CraigTee Samba Member
Joined: March 09, 2014 Posts: 12 Location: SouthWestern Oregon
Posted: Mon Jul 07, 2014 7:39 pm Post subject: |
busdaddy wrote: |
One thing I keep seeing is the chew marks on the edges of the teeth are not shiny and new like the gouge where it dug into the oil pump, could something like a dropped bolt have been down in the gear chamber rolling around binding against the cam and eventually propagating the crack later? How about some better pics of the case surrounding where the cam gear goes? |
Yes! Good eye! I thought I saw the same thing... but I can't remember the placement of the oil pump... wouldn't the rivets have been the part that hit the pump?
David.... please re-inspect every tooth on that CRANK gear.... you'll be looking at the back half of the teeth... the area closest to the crank's bearing journal. Imagine putting a gear puller on that gear to blast it off... then look for any flattening of the teeth on that back side.
I STILL believe that the failure was caused by me missing some clean up after that amateurish gear swap. That was the last time I used that machine shop. It was just plain sloppy work.
OK... sigh... this deserves more explanation... here it is. A day or two prior to me dropping off those cranks to get the gear swapped... my dad passed away. There was probably a period of time that I should not have been working on that engine. My dad and I spent more time together pulling and rebuilding motors than anything else. No sympathy cards please... just let this go... it was a long time ago... but thanks for your thoughts.
Anyway.... if there is ever a horrible time to do sloppy work, it would be when you are putting that case back together... and that's when my mind was not as clear as it should have been.... and I may have missed some teeth on that crank gear. That's my best guess.
David... check the crank....
The teeth marks I'm seeing in those cam gear pictures make me very suspect that you'll discover the reason for that cam gear failure.
Again, just my thoughts.... |
chazz79 Samba Member
Posted: Mon Jul 07, 2014 7:40 pm Post subject: |
Do the quickie bechtop leak down check of your valves. You might be able to avoid a trip to the machine shop there.
Buy a cam
Pull your lifters apart and clean them. It's tedious but a spec of metal might keep one from pumping back up.
Mic the rods and crank journals.
Machine if necessary*
Buy appropriate bearings
Buy gaskets.
If you can avoid machine work you can do this much for @500.00. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
Posted: Mon Jul 07, 2014 7:56 pm Post subject: |
chazz79 wrote: |
Buy a cam
Buy gaskets.
If you can avoid machine work you can do this much for @500.00. |
and listen to Chazz79! He says much of what I said... just more succinct. I totally forgot about the "leak down" valve chamber test. Great place to start.
Mike out that extra cam I sent you. If it mikes out clean, you can save some money there with just a clean up.
I would still add a set of rings... but that's just me. Also, place the rods on a flat surface and check for twist. The rods were purchased (rebuilt) at time of rebuild. My donor 2L had exploded and put one through the side of it's case. I didn't trust any of them and changed out all 4 rods along with a reground crank.
If you don't find any damage to the valves, pistons, or rods... then all you have to do is repair/replace the damage caused by the cam gear and associated flying parts.
I would do all new bearings too... shouldn't cost much and worth it. Check clearances... plastigauge or "slow fall" method.
and let me know what you find on that crank gear... or you might very well be posting another set of pics like these in 20K miles.
Best wishes David. |
Posted: Mon Jul 07, 2014 8:00 pm Post subject: |
Replies, comments, and questions bolded throughout.
CraigTee wrote: |
Hey David... noticed your post trying to figure out how far to take this build after I got done going ballistic.
Here's my two cents... and this is if it were me doing that engine again:
I forget how many miles I put on that build... was it like 20K or so?
This is why I am trying to avoid a full, total rebuild! I simply can't imagine it is necessary. I want to get it going by replacing what needs replaced, but it seems wasteful to throw extra new parts at it when that isn't needed.
Anyway... dropping that engine out takes maybe what, an hour or so on the outside? No big deal... For me, the big deal is in splitting that suitcase open. That's when things get labor intensive and time consuming... not to mention monetarily taxing!
Anything INSIDE that case would get number one priority.... either new, rebuilt, or machined. (Except rods, they would just get checked for any twist and miked for oblong stretching and pin fitment) Anything that might affect the health of anything inside that case would receive the same priority. Everything else would get miked out.
This certainly makes sense.
I wouldn't swap jugs without cause... but certainly a good clean up and new rings. Again, everything would get miked. I'd take the heads into a REPUTABLE shop for inspection/rebuild. Perhaps they only need a good clean up.
I need to go back and look more closely, but I did take a peek and the cylinder showed clear cross-hatching which certainly is a good sign.
I wasn't pleased to see evidence of blow by on the heads. I did re-torque after an initial period but perhaps should have gone back in a third time. That kinda made me sad to see....
New gaskets (duh), and I would REALLY give that oil pump the thrice over. In fact... if I could replace it, I would. It would bother me knowing that it was in there. A little bit of JB weld on that cam gear should do the trick.
I was thinking duct-tape...
You mentioned carbs... when I got that bus, somebody had pulled the idle circuit hoses off. Instead of messing with it, I just bought that progressive Weber since everybody was ranting about them back then.... especially since there were questions about the original carbs feeding the additional 300 CC's of the 2.0L. It might be worth cleaning up that Weber....
Either way, either (set of) carb(s) will need rebuilding. The Weber is all gunked up from nasty old gas. It almost looks like they gas in the carb evaporated and gunked it up, and then that allowed more gas to slowly leak down and out of it. Its pretty nasty!
I know from reading some here on the Samba that some don't like the Weber Progressive any more, but I also know that a lot of people have run them with no real issues, while others experience icing due to the long intake manifolds.
Can anyone comment on whether the stock carbs can feed the 2.0 OK?
As far as the past history of that engine and everything that got put into it? You have the receipts, you know. If others wish to guess what or wasn't done, let them... then go to your receipts and see for yourself. You also have that "to do" list I made up after doing my homework on the suitcase engine. That might be worthwhile to go over prior to your build and to see what was done on my build.
I forgot about the to-do list! I will have to go back and take a look at it too.
Trying to guess the reason for an engine failure is always entertaining, and sometimes even helpful to avoid the same problem on future builds. However... again... it's only guesses. Two professionals (paid for their services) might well offer two totally different scenarios. A wise man will listen to BOTH and make sure he addresses BOTH possibilities on his next build.
Oh... a note about those discussing riveted cam gears... the Robert Bentley VW Official Service Manual for these buses discusses both the 3 RIVET and the 4 RIVET camshafts... stating the 4 Rivet cam is used with the later buses. The OEM VW cams gears were riveted.
For those wondering about original cam lash setting, here's the answer:
It was a new cam and new bearings, hence new thrust surface. The clearance was within .000 and .002". The play permitted by the thrust bearing was between .002 and .005". The cam didn't lift from it's bearings when the crank was turned backward.
Now... how do I know this? From memory? Nope... it's because there's pencil checkmarks in my Bentley manual which meant "Done! Next?" LOL!
The rebuild was done with a LOT of outside help, the Bentley manual in my right hand and the John Muir's timeless novel in my left (the updated version that included the pancake engine). Yes... I cranked the wrenches with my toes... I'm that good.
Yes... it was my only air cooled rebuild... but I recognized that fact going in and was smart enough to know there was going to be some differences... so I took nothing for granted. If it wasn't obvious, and Bentley nor Muir offered me any guidance, I checked with the experienced pros in the area until I was satisfied with an answer.
So... I've landed as requested... perhaps not as quietly as I could or should have... but am here to answer any additional questions anybody (especially YOU David) may have about the original rebuild. Please don't let my previous rant dissuade you from asking. I just got irate when somebody told me that something hadn't happened when I knew for a fact that it had.
David... you don't want to short yourself on the build... it's what you rely on to get you from point A to point B. On the other hand.... a lot of that stuff is still new.... the parts that haven't rusted out in the last 10 years or so... and I WOULD re-use them. Put those original carbs in a box and save them for the restoration. Clean the Weber and check the rubber parts... they might be shot... rebuild if necessary (it's a simple carb) and reinstall. I think I could do that engine here for under 5 bills pretty easy... maybe far less if the heads still look good.
Again, I didn't imagine it really had tons of miles on it, so I don't want to throw parts at it unnecessarily. I have noted zero rust anywhere. (I don't think there is much in there TO rust, but I have seen zero inside the engine.) If nothing else, there must have been enough oil film to protect the internals.
Somebody mentioned a bent valve... wasn't aware that this was an interfering engine but look at the pistons... if the tops are unmarked you're probably good to go. Just ask the machine shop to double check.
I've never thought this was an interfering engine either, are we incorrect, or could something else have happened to cause a bent valve? But in peeking at the pistons, no evidence of contact was noted.
Take your time... do it yourself... and learn to know your rig. |
1973 Wild Westerner
My Thing |
Posted: Mon Jul 07, 2014 8:36 pm Post subject: |
When I CC'd and then shimmed the heads for valve combustion chamber clearance/compression ratio... I shimmed for the LOWEST compression ratio recommended. I didn't want pinging and didn't mind sacrificing a little power. That also would allow for the MOST piston/valve clearance.
If you don't see marks on the tops of any pistons (and I didn't see any on the valve pictures), I think you're good to go... unless somebody with more experience on these engines knows of another way to bend a valve without contacting the piston.
Some people will replace everything all new every time they pull an engine. I'm not going to say they're wrong because it's the safest way to build. I've done a lot of engines and my buddies have often teased me about over replacing also.
Nowadays, I use a mike and dial mic. a whole bunch....
I think it's a clean up and replace the affected parts if that's your desire. At least plastigauge the rod bearings tho... ok?
(Grin!) |
Posted: Mon Jul 07, 2014 8:47 pm Post subject: |
vwwestyman wrote: |
The bearings are still attached to the crankshaft on either side of the middle bearing, so I can see the dowel holes, but no dowels. |
I don't know what happened to the dowels...
but if you can't find them, they're 79 cents apiece:
http://www.busdepot.com/111101123 |
Tcash Samba Member
Posted: Mon Jul 07, 2014 8:54 pm Post subject: Broken Cam Gear |
Cannot remember on the type4's but sometimes they machine the roll pin holes in both cases. Look under the bearings on the other side and see if the roll pins are located there.
CraigTee bummer sorry for your loss.
Do you remember setting up the backlash on the cam gear? The reason I ask is the wear on the leading edge of the cam gear leads me to believe it was tight. Did you hear any gear wind?
vwwestyman
I would replace the crank gear as well as.
Cam and lifters, cam bearings by the looks of it.
Oil Pump
Oil Cooler
Check that none of the valves are bent
Have the case oil plugs removed and case cleaned.
Good Luck |
Posted: Mon Jul 07, 2014 9:34 pm Post subject: |
CraigTee wrote: |
vwwestyman wrote: |
At least they are inexpensive!
Who knows where they went. I checked the area where I split the case but didn't see anything. I didn't pull the crankshaft out until I went to wash up the case and never noticed them. I guess they must have stayed with the case and then were "washed" away. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Jul 07, 2014 10:09 pm Post subject: |
What is the part number on the cam timing gear? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Tue Jul 08, 2014 1:33 pm Post subject: |
Oh.....one defect I totally forgot about that you can look for that comes from the factory (when it happens....and it is rare)......and I say this because you noted that in the last build that you replaced the crank gear.....but did not mention why.....
Is....that on some cranks, the boss that the timing gear is pressed onto is machined out of concentric with the centerline of the crank. When I found this on a totally pristine standard/standard 1.7 crank....I thought I was losing my mind. I spoke to Jake Raby about in passing when I was picking up a crank from him........and he noted that while its not everyday common.....when you work with a lot of cranks like he does.....you see a few this way. He noted that since undersize gears are not available, unless you want to weld, grind annd then nitride or re- case harden there is nothing you can do really.
It causes not adverse running but it does cause an oscillation that at really high milage will show up as a lopsided wear pattern on the softer cam gear.
Because we cant get anything other than a "0" gear anymore....if your lash is excessive and you have a heavily sprung valve train it can cause problems.......that is not your problem here....
But.....if you have any other lash issues or say....a cam gear out of plane for any reason... . It can cause a failure.
I found this problem on the engine that I wrecked that had not enough clearance and was knocking the oil pump bolts. I only found it because.....oddly.....the crank gear no longer fit. It had either vibrated or been wrung hard enough by shock to be .015" oversized.
I measured the boss anx it was perfect. .....which was when I noticed the boss was out of center. I have found one more crank like it since. From the side you can literally see that it was machined out of center.
I still have the crank. I will see if I can unpack it and get a pic for you. Its worth checking. Ray |
Posted: Tue Jul 08, 2014 1:40 pm Post subject: |
raygreenwood wrote: |
Well that is pretty crazy! Certainly something to look at.
He replaced the crank because he built is as a 2.0, and used a 2.0 crank as a part of that. (This is a '73 and was a 1700? originally.) _________________ Dave Cook
1973 Wild Westerner
My Thing |
SGKent Samba Member
Posted: Tue Jul 08, 2014 2:16 pm Post subject: |
it is a magnesium gear (B). They fail at a higher rate than the aluminum(C) ones.
The lifters cannot be reused without resurfacing. When using a new cam it is best to get new lifters from the same source.
The gear came loose and impacted the oil pump. When the pump is opened up it is likely to have scoring in it from the debris, making reusing it unwise.
If there is no smack mark on the pistons they did not hit the valves. However it would be foolish to not send them to someone like Adrian or Len to look over and check for flaws before the engine is rebuilt.
The rods should be checked for both small and big end sizing. You may be able to polish the crank but it should be put on a run out gauge to be sure it runs true. It only takes a small microscopic bend to put wobble into the cam gear.
The brass and small gear that drives the cam should be replaced.
Clean up the cam gear with solvent and look for a number on the outside ring. Try to find a good used aluminum (C) gear that has that same number. Start checking lash there and go up or down based on that.
Take your time and do it once. |
Posted: Tue Jul 08, 2014 8:31 pm Post subject: |
The cam Craig included has an aluminum gear, marked C at the end of the otherwise same part number.
I had a few minutes to spend with the parts and camera tonight. Here's what I found.
Marks from the gear inside the block. Are any of these a problem with using the block?
There is some roughness on the drive gear. Guess that means for sure it needs to be replaced.
Pics of the valves. I remembered seeing a couple places here where it was recommended to place a straight edge across the valve stems to see the difference. Most of mine were all slightly shy of the top of the springs. Here is a couple pics of the differences. This is the 1/2 side.
Pitting on the stem of the 1 exhaust valve. Set too loose?
Similar (though worse) pitting on the stem of the 3 exhaust valve.
Pistons. No indications of valves contacting them whatsoever.
Cylinders. You can see the line where the bottom of the bottom ring bottomed out. I can feel the difference in texture, but cannot catch my fingernail or anything here. In the area where the carbon has come off at the top, there is a bit of a catch, sort of. Barely perceptible. This is consistent between 3 of the 4.
This one has a few spots of pitting or something going on.
Where does this info put me on what I might need to do/spend to get it going? _________________ Dave Cook
1973 Wild Westerner
My Thing |
SGKent Samba Member
Posted: Tue Jul 08, 2014 8:46 pm Post subject: |
I think the case marks you can just clean up with a small flat file if there are any burrs.
You do need all new bearings. Look at the saddles and back of the bearings closely. If they show signs of being really shiny in spots, they will have been working. If the backs are just blackened, matte in finish then they have been sitting solid in the saddles and the main bores are probably Ok. You can also feel for a ridge where the edge of the bearing was to see if the saddle is showing signs of sinking.
If someone gave you a used cam, the lifters have to go back on the same lobe or be reground first. The are not flat but have a slight crown to them so be careful if you have them resurfaced. Many of us here have been burned by reground camshafts and lifters. It isn't like that 454 where you can pull a timing gear cover off, the gears, the intake, rockers and pull out the cam to swap it. The whole VW engine has to come back apart so think carefully about the cam. I use a Webcam 142 grind new, and pass smog easily - and the engine will pull to 5K+. The 142 profile is from the 2.0L 914 T4 95 HP engine used in some Porsche motors. More than a bus needs.
Personally I find it easier to buy new Mahle cylinders and pistons than rering them. Sometimes it can be really hard to find rings that will fit the ring lands right. You can bottle brush it and re-ring it if you want to save that money.
I would send those heads to Adrian in San Diego County to be rebuilt. The valve stems are worn. From the depth, it may be that the keepers are pulling through - or they may have been tipped a few times already and are shorter. If you want to save on that get some lash caps and run those until you can afford to have the heads done.
Just my 2 cents worth
Posted: Tue Jul 08, 2014 9:54 pm Post subject: |
SGKent wrote: |
I would send those heads to Adrian in San Diego County to be rebuilt. The valve stems are worn. From the depth, it may be that the keepers are pulling through - or they may have been tipped a few times already and are shorter. If you want to save on that get some lash caps and run those until you can afford to have the heads done. |
He could also get some Porsche swivel foot adjusters and run then in lieu of lash caps. |
Posted: Wed Jul 09, 2014 8:11 am Post subject: |
Don't be too quick to get rid of the main crank gear. That damage is out on the edge. The crank gear is steel and the cam it it drives is aluminum. As long as the steel gear has no high spots and basically full tooth contact and no missing teeth....it should cause no wear to the cam gear.
Put the crank in a makeshift V-block set up...like two pieces of wood with a "V" cut in each and covered with a simple sheet of plastic bag in each V with some oil. Set up a dial indicator.....and check that the crank gear is round.
Take a needle file and/or dremel and carefully remove the burrs from the edge of the gear. They need to be lower than the surrounding gear surfaces that touch the cam gear. You will note that the crank gear is wider than the cam gear. You dont need all of the gear area.
Your gear could be just fine. I say this...because unless somebody knows something newer than I do....they do not make type 4 crank gears any more so all you will find is good used ones....of which you should acquire a spare anyway before they disappear.
Its also odd....but not really...that the damage is on the backside of the gear. Usually in a cam gear damage scenario involving striking the oil pump and grenade-ing....the damage is on the pump side of the crank gear...not on the crank side.
Question: is it only a couple of teeth on the crank gear that are bad or is it all the way around? If its just a couple of teeth....most probably it was a rivet head or piece of debris that caused this just in teh last couple seconds...either way it had to be steel and not aluminum to do that damage.
Another note....or possibility.....that may have caused this whole thing. If a nut or piece of debris somehow fell into the case through the oil fill chimney....and jammed the cam gear between gear and pump....it could have caused this.
I say this because of the type of damage I saw on the engine I cratered.
Yes...the root cause was because of inadequate pump to cam gear bolt clearance.....but the final damage was caused by one of the oil pump nuts coming loose from 89,000 miles of knocking.....and landing in a tight spot between cam gear crank gear and case. It stripped most of the teeth from the cam gear...and did crank gear damage to all teeth just like in your picture....but on the cam gear side.
Just some thoughts. Ray |
Posted: Wed Jul 09, 2014 12:21 pm Post subject: There's Your Answer |
(This is way too long but had lots to say and explain)
David... you have the reason for the camshaft gear failure is in that picture of the CRANK gear.
When the shop removed that gear, it wasn't done per the manual which calls for a mild application of heat (heated oil comes to mind... but I can't swear to it) and gentle persuasion. Instead, he simply hooked up a gear puller and blasted it off the 1.7L and back on to the 2.0L crank. I was NOT happy.
Like I mentioned earlier... it was not a time that I should have had my fingers into a rebuild. My mind was not on my project. It was one of those things where I started fixing the damage, got distracted, went back and did some more polishing, got distracted... and, at the end of the job, I was scratching my head, asking myself... "Did you ever finish cleaning up that gear?"
Obviously I hadn't. Your picture of the backside of those crank gear teeth show what I've pictured in my nightmares ever since that engine failed. Oh well... it got you a cheap Wild Westerner and me out of yet another project at a time I'm trying to downsize.
However, it's like I told you in the beginning... I truly believed that (if I HAD neglected to finish polishing that crank gear) the damage was going to be limited to a stripped cam gear.... and of course the associated clean up. I had no idea that the pounding on the cam would result in thrust bearing wear, causing the rivets to impact the oil pump like that. What a mess.... but certainly not catastrophic.
You're getting lots of good advice on the build... to me, some of it kinda goes beyond and above what may be necessary, but you are the one with the engine in front of you... so ultimately it's how far YOU want to take it. If it were me, I'd just be really diligent on the clean up side and inspecting everything under magnification... TWICE!
I saw a question I'd answered in an earlier post on the original build cam settings, but here it is again.
Quote from a previous post:
End Quote
Thinking back... that may actually have been partially the reason I got stupid and neglectful on that crank gear clean up... got prematurely involved with cam lash and clearance settings... just a thought. When I see something like that I just can't kick myself in the pants quite enough...
I think it was Ray that suggested you consider finish cleaning up that crank gear (like it should have been cleaned 20 years ago!) and run with it. I think that's a wise suggestion... at least to try it. A file, elbow grease, and investment of time can go a long way there. If you can't get it mirror polish smooth, maybe grab a buddy or shop to finish it off for you. Those ridges need to be gone and I hang my head in shame that I neglected to do it.
Ray also told you how to dial mic that crank. If you use that cam I sent you, do the same thing with that and also check the lobes. Mic out all your journals... and purchase bearing sizes as needed. If you're not comfortable with mics and dial mics, get some help on that.
Bearings are cheap, rings are cheap, I sent you a replacement cam that is probably good, the crank has 20K miles on it (if I remember right, you got the book on that), the jugs were new and as you mentioned, still have the hash marks on the cylinder walls. I'd be willing to bet the heads and valves are fine, requiring a clean up.
You pictured some valve stem pitting. The first set of push rods I got were soft and mushroomed on me. He replaced them for free even though I didn't ask for that. He said he'd been having problems with them. It's possible that pitting that you note came from that period of time. Also possible that some some of the metal fragments floating around in that engine may have helped...
In the specs, there is a specified length and limits for valve length. I'm sure you can polish those and still be within those limits if the valves are otherwise sound. Any "sunken" valve needs to be pulled for seat inspection.
The carbon ring you noted is standard. There's a tool for removing it. I was taught to always remove it to prevent possible ring damage (I guess if the "replacement" pistons have a ring set a little higher on the piston). Anyway, borrow a ridge reamer if you don't own one.
That cylinder pitting? No clue.... I've seen it on water cooled and always attributed it to water damage. Perhaps rust from sitting and then getting "cleaned up" by the rings when you turned the engine over? Just a guess.... Anyway... too deep to hone out from the looks of it. Bottom line? Jugs can be replaced without splitting the case. That would by MY determining factor... but that's ME.
You got a lot of advice on this and a lot of ways to go. People are going to make suggestions based upon their philosophies on builds. No two will probably be alike, and very few, if any, will be absolutely wrong. Appreciate ALL the advice offered, it's given from good hearts... then pick and choose what makes sense to you to develop YOUR OWN philosophy on this build.
Do you own the Bentley Manual? It's invaluable if you want to check specs on anything in that engine.
Thanks for the pics. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Sep 29, 2014 10:13 pm Post subject: |
What did you finally do about this camshaft problem? |
Posted: Tue Sep 30, 2014 5:50 am Post subject: |
For the time being: Bought a Vanagon engine...
A couple reasons:
First, it popped up and the price was right, and I can sell some of the parts I won't use for the Westerner (sold fan shroud, still want to sell heat exchangers and Vanagon transmission) to make the overall price significantly lower.
Second, I realized that taking the time to build the engine correctly would take a lot of time and money and I'm impatient to get this thing driving again. I had thought about slapping it together with another cam and cleaning up the cam gear, but I don't really want to do that.
Third, honestly, I'm a little intimidated with rebuilding the engine properly. Going this route, I can take my time (maybe over the winter?) and really do it right, while (hopefully) getting to drive the bus around. At that point, I'm confident I can sell the Vanagon motor for what I'll have in it.
So right now, the engine repair project is on pause. _________________ Dave Cook
1973 Wild Westerner
My Thing |
