EverettB  Administrator
Joined: April 11, 2000 Posts: 41918 Location: Phoenix, AZ
Posted: Thu Jul 31, 2003 1:36 pm Post subject: How to post photos/How to post a photo in the Forums |
Need help resizing photos?
See this thread
Need help posting from an iPhone/iPad?
See this thread
Using TheSamba.com Gallery to post a photo:
(VW/Porsche photos ONLY in the Samba Gallery)
(Preferred rather than using another external image hosting service like Photobucket, which can disappear)
- Go to the Gallery
- Click "Add Photo" and fill out the form there. Or CLICK HERE
- Click browse to select the picture from your computer hard drive
- Submit your photo to the Samba Gallery
- Click on "View All" in the header to see your new picture
- Click on your new photo to enter the Photo detail screen, now you will be at something like:
- Click on the box marked Forum Code:
- Right click on the Forum code text and select copy:
- The link is now on your clipboard.
- Create a new Forum post or reply to an existing thread
- Paste (Edit -> Paste from the menu or Ctrl+V or similar) the web address you copied above from the Gallery
- You link should look something like this:
- You are done! Add some comments and press Preview to make sure your photos are working before using Submit to post your message.
Posting photos from an external image hosting service:
(Photos hosted elsewhere, especially non-VW photos)
- Determine the internet address of your photo, for example my '63 Squareback is located here:
http://www.thesamba.com/vw/scrapbook/63variant/63front1.jpg
Save this address to your computer clipboard using Copy from the Edit menu of your browser or Ctrl+C (copy) or something similar
- Create a new post in the Forums or reply to an existing thread
- Press the img button you see above in your new post, then paste (Edit -> Paste from the menu or Ctrl+V or similar) the web address you copied above
- Press the img button again to mark the end of your photo. It should look like this:
When posting photos, PLEASE consider posting the photos in the Samba Gallery instead of just posting links to some picture hosting site.
If you post it elsewhere, the photos often become "dead links" after a certain period of time, which ruins the thread where you posted the photos. If you post them in the Samba Gallery they are here forever. Not only that, but in the Gallery users can search for photos so much easier than they can in the forums. It's worth it.
Posted: Mon Aug 27, 2007 7:56 am Post subject: |
Picasa short version from Adam:
In Picasa, right click on the picture and click view image in your browser. Next, paste the address in between the [Img] tags in the Samba post message window.
Picasa short instructions from user tardigrade:
Find the photo in your library and double click on it to see it in Viewer.
Click "File," then "Export Picture to Folder."
Use "Browse" to select a folder for the photo. Otherwise, Picasa will create a folder named "Picasa" with a folder in it named "Exports."
Move the slider to reduce the pixel size. 640 is about right.
Click on "Export."
You're now ready to follow the directions above
Longer tutorial on posting photos from Picasa, thanks to Samba member Orbitron:
When posting images from Picasa, simply using the img button and copying the text from the address bar will not work. It is kind of complicated so if you can use another program other than picasa, it may be adviseable.
The result of highlighting the address bar and using the img button would look like this:
[img]http://picasaweb.google.com/giantjoe/VWStuff/photo#5102650326655584354[/img]
Not a picture right? You must use a web address that has .jpg at the end of it. Some programs have that in the address bar, Picasa doesn't. The ultimate goal here is to obtain a code that looks exactly like this: | Code: | | [img]http://www.webaddress.jpg[/img] |
Note that there are no spaces, nor quotation marks. That is important to remember.
If you get the basic idea of coding you can probably stop reading here, but if you requre further instruction, here is the correct way of inserting a Picasa image into the bulletin board interface:
Find the image you wish to post in the Picasa interface. You must use the "link to this photo" module on the lower right hand side of the page to get the code required for making an image. See below:
Using the drop down menu, select the size of picture you wish to post, I usually select 800px. Highlight the text in the "HTML to embed in website" box and copy it. Unfortunately, you cannot simply paste this into the bulletin board interface, or you'd end up with something like this (minus the bold formatting):
<a href="http://picasaweb.google.com/giantjoe/VWStuff/photo#5102650326655584354"><img src="http://lh6.google.com/giantjoe/RtBBb-VWSGI/AAAAAAAAAWg/q5W1MYXgLqc/s800/picasa.jpg" /></a> Quite a mess isn't it? All you want to use is a web address that ends with .jpg to be surrounded by the bulletin board tag for images.
Follow closely:
Go to picasa and get your image code as described above. Navigate to The Samba and post a reply. Click the img button in the Bulletin Board interface Paste the Picasa stuff after the code. Remove all the text except for the bolded stuff from above. Make sure your code looks like this:
| Code: | | [img]http://lh6.google.com/giantjoe/RtBBb-VWSGI/AAAAAAAAAWg/q5W1MYXgLqc/s800/picasa.jpg[/img] |
Post your reply. Here is the result of using the exact code from the last point.
Well, that's it. Hopefully you can understand what I have said thus far and if you have any issues, you can always ask for help from any The Samba members, they are usually quite good about helping. _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
Posted: Sun Jan 20, 2008 6:01 pm Post subject: |
Mach4 on the site made this video with detailed instructions on how to post content in the Forums.
Check it out _________________ How to: Post Photos | Search
"Water is the only drink for a wise man" | "Communication prevents complaints" |
