1953Volks Samba Member
Posted: Sat Jul 05, 2014 5:12 pm Post subject: 1950 carburetor? |
What is the correct carb for my June of 50 split? 26 or 28? _________________ 1950 Hoffman 11 G 1-0174999
1953 11G
1955-6 GHIA 1-0925660
1962 DOUBLE CAB
1957 11G
1958 Single cab
1967 camper bus
1959 ragtop 2226460 (in Japan)
1964 Karmann Ghia
1964 Cadillac coupe De Ville (a.k.a. Husslah) |
volksair Samba Member
Posted: Sat Jul 05, 2014 6:11 pm Post subject: |
I`m compelled to say 26 is correct. |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
roymartian Samba Member
Posted: Mon Jul 07, 2014 6:05 am Post subject: |
26
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Mon Jul 07, 2014 10:13 am Post subject: |
Don't pay big bucks for one that doesn't have the band around the bowl.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Jul 07, 2014 4:26 pm Post subject: |
Hi John,
Can you explain more about the band around the bowl thats recommended |
Posted: Mon Jul 07, 2014 5:05 pm Post subject: |
Pics above have the banded carb. Correct for split VWs. Casted "band" around the fuel bowl.
Unbanded carbs may have been used on industrial engines and other cars. They are much more prevalent, but not completely "correct".
http://www.thesamba.com/vw/classifieds/detail.php?id=1582798 _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Jul 08, 2014 4:13 am Post subject: |
Phew thanks John |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Tue Jul 08, 2014 4:26 am Post subject: |
with /with / without "band"
_________________ Master of my domain! |
Posted: Fri Jul 18, 2014 6:46 pm Post subject: |
usariemen wrote: |
So the one on the right is the correct one? And another question , how does the manual choke cable attach? How much is a fair price?And thanks a bunch who responded to educate me. This is my first split and I want to do it correctly. _________________ 1950 Hoffman 11 G 1-0174999
1953 11G
1962 DOUBLE CAB
1957 11G
1958 Single cab
1967 camper bus
1964 Karmann Ghia
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Jul 18, 2014 7:40 pm Post subject: |
1953Volks wrote: |
usariemen wrote: |
So the one on the right is the correct one? And another question , how does the manual choke cable attach? How much is a fair price?And thanks a bunch who responded to educate me. This is my first split and I want to do it correctly. |
Nope the one on the right is NOT the correct one. The left and center ones have the horizontal band on the "bowl" portion.
The cable runs thru the chassis tube by itself, no sheath until it reaches the engine, the carb has a few feet of sheath from the carb back thru the fan shroud and stops above the transmission.
The choke cable sheath is tightened in that clamp you see on the band (right one is missing this clamp and screw, center and left ones have a bolt) and the wire cable itself attaches to the barrel clamp on the throttle linkage (which is seen only on the center carb) |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
coolparts Samba Member
Posted: Sun Jul 20, 2014 7:01 pm Post subject: |
What's the correct needle valve size ? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Mon Jul 21, 2014 5:43 am Post subject: |
Whats difference with the 'S' |
Posted: Mon Jul 21, 2014 7:59 am Post subject: |
Mika, your chart saids 26 vfis 1.2 on the needle valve? what happens if I change it to a 1.5 from a 1.2 ? |
