AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1067 Location: Massachusetts
Posted: Sun Jul 06, 2014 1:45 pm Post subject: Generator identification? |
I came across this early style generator yesterday. It fits in a 36hp generator mount, looks 6 volt. It has no holes to mount a voltage regulator, though. I guessed it was an older 356 one due to the elaborate clamp and nut but could be wrong? I searched the gallery and found similar ones listed as 356, but don't see a voltage rating on this. It has:
LJ/GEG200/6/2600L19
BOSCH
then some German I can't make out
406
Maybe the '6' up top is the voltage?
Here are bad pics:
I'm sorry if this is posted in the wrong section, it just looked about the right era? Thank you to anyone who can help identify this thing. |
Robert Chambers Samba Member
Posted: Sun Jul 06, 2014 3:59 pm Post subject: |
Looks like an early Bus generator. The regulator was mounted separately on the side sheet metal of the Bus. _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Mon Jul 07, 2014 3:45 am Post subject: |
Ah ha! Thank you Mr Everett! If it's from 64 would that make it a 12V one? |
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Mon Jul 07, 2014 4:22 am Post subject: |
I agree that it is from a 356. It is a 6 volt unit. The 6 in between the back slashes denotes that. 6 volt = /6/ , 12 volt = /12/ Here is a link to a Bosch chart for Porsche.
http://derwhites356literature.com/BoschParts3.JPG _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
James Davies Samba Member
Joined: September 24, 2013 Posts: 141 Location: Baltimore, USA
Posted: Mon Jul 07, 2014 4:24 am Post subject: |
The model number is LJ/GEG 200/6/2600 L19, which means it's a 6 volt generator that produces 200 watts at 2600 RPM. |
Posted: Mon Jul 07, 2014 5:13 am Post subject: |
Thank you very much guys! Well now I know what it is! I had hoped it was a 12V one. But thank you. |
Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Mon Oct 06, 2014 5:08 am Post subject: |
Sorry to reserect an older post- BUT
I have an identical generator - including stamped numbers "200/6/2600" but without dust cover - and it is 12v, I am running this on my 36hp in my early ghia.
Could this have been a 6v generator converted to 12v or is it a 356 12v generator ?
I am interested to understand what voltage regulator should be used 30 or 38 amps? _________________ -------------------
All of 30 horses ! |
Posted: Tue Oct 07, 2014 9:08 am Post subject: |
With a 200/6/2600 model number, it was originally a 6v generator, 200 watts. Sounds like it has been converted to 12v, which is a pretty simple operation apparently. Lots of shops who repair these do it. |
