Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Posted: Mon Jul 07, 2014 8:25 am Post subject: Should my Oil pressure gauge read 80 psi at Idle ? |
I have a question
My car at Idle at the stop light reads between 80 to 100
at 40 MPH it reads 40 to 60
It is a VDO gauge with a sending unit.
My motor is a 1641cc with Engle 110 cam
I installed Scat HD Dual Oil Relief springs
I also have a full flow oil pump with remote oil filter under the rear fender
Here is a pic at Idle.. traffic light
Here is a pic at 40 MPH driving it reads 50 to 60psi
Here is the HD full flow oil pump
You can see the oil pressure sending unit
Hydraulic Lines used for the oil lines
Remote Oil filter
_________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon Jul 07, 2014 8:31 am Post subject: |
Lose the scat springs, the fram filter, and the blue distributor cap. The springs are part of the cause, if not all of it. The filter is not going to last long at that pressure, and Fram is not a good filter these days. The blue cap is just garbage too, and will leave you stranded... |
Posted: Mon Jul 07, 2014 9:03 am Post subject: |
What oil are you using with that huge pump? _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Goshen Samba Member
Goshen Samba Member
Posted: Mon Jul 07, 2014 9:31 am Post subject: |
Change to 0-30 or 5-30 and your pressures will behave a lot better. _________________ It's just advice, do whatever you want with it!
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Mon Jul 07, 2014 9:33 am Post subject: |
A few years ago the Fed Gov't changed the specs for all diesel engines and the Diesel motor oil should no longer be used in any gasoline engine. You need to change it. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Jul 07, 2014 9:49 am Post subject: |
Thats one of those 30mm in/out oil pumps. X2 on the oil change to 10-30 and either find softer springs and/or swap the "champagne glass" relief galley plug with a stock one. I think youll def need to do both. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Mon Jul 07, 2014 10:09 am Post subject: |
Is it just me or doesn't it seem strange the oil pressure goes down with increasing RPM? Wouldn't that possibly be a faulty reading, perhaps a gauge that is wired incorrectly? _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
esde Samba Member
Posted: Mon Jul 07, 2014 10:48 am Post subject: |
Juanito84 wrote: |
Is it just me or doesn't it seem strange the oil pressure goes down with increasing RPM? Wouldn't that possibly be a faulty reading, perhaps a gauge that is wired incorrectly? |
I saw the same readings too, using the HD springs; high at idle and lower at 2-3k. The idle pressure is high, and I suspect the forward relief valve is closed. As RPM increases so does pressure, the valve opens and pressure drops. On my engine I figured that the volume of oil flowing past the relief valve at that point was enough to hold it open until the engine was brought back to idle. At least that's what we thought, putting a stock spring solved the issue. 25 years ago and I had bought a 30mm pump, HD springs, the adjustable relief plug,and then was stumped when it blew coolers and filters on a weekly basis. Took an old German mechanic to set me straight, I was so mad to be removing $30 worth of new parts to make the thing run right, but that was the solution |
Posted: Mon Jul 07, 2014 11:02 am Post subject: |
Ok, that makes sense.
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Mon Jul 07, 2014 2:19 pm Post subject: |
While it is known the scat springs are too strong, 30mm is larger than most need, and diesel oil is not well suited to our engines, I too suspect there is a problem with the sender. 80-100 at idle would seem suspiciously high even with cold 50 weight! _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
57 Rag Samba Member
Joined: October 24, 2006 Posts: 1145 Location: Paradise
Posted: Mon Jul 07, 2014 2:37 pm Post subject: |
My question is.... how long has the motor been running when it reads 80-100? Does it stay like that through out the drive?? Im running 20-50 and when i first start it she will have about 75 psi and it slowly comes down as the engine warms up. Before you know it, whats its warmed up its down to 20-25ish.
If your running 80-100 after shes warmed up, simply switching to 10-30 aint gonna help much. But like Dave said switch it. For me... just the fact that its "Diesel oil"...nuff said. Definitely go with the stock spring first and see what happens. I still dont know how you didnt already blow filter on that Fram POS. Ive used those just on breakins here and there and let me tell you, aside from the chance of screwing up your motor, theres nothing worse than throwin oil all over your engine bay and garage!!! Good luck and keep us posted. _________________ 57 Ragtop
84x94 86C
IDAs |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Jul 07, 2014 2:38 pm Post subject: |
little mouse wrote: |
80-100 at idle would seem suspiciously high even with cold 50 weight! |
Really? What does your crystal ball, *cough* I mean science book have to say on the subject? 30mm pump+15-40 oil+HD springs absolutely equals that much pressure- THE PROOF IS STARING YOU IN THE FACE. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
esde Samba Member
Posted: Mon Jul 07, 2014 2:57 pm Post subject: |
I remember the 30mm pump with 10-30 and the HD springs pegging the 80psi gauge at idle. I never got to see how much it would have dropped when the oil warmed up, as it always blew the filter or cooler seals first.. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Jul 07, 2014 6:38 pm Post subject: |
Had a front relief stick once and it alone went to 100 psi and instantly blew 2 filters be fore we got it figured out- then we were asked to leave.
By the way- you can get 30 feet out of a blown filter. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Goshen Samba Member
Posted: Mon Jul 07, 2014 9:03 pm Post subject: |
Fluid dynamics-- is there a doctor in the house.
think they have solved your problem- now go find those old springs. _________________ some days I get up and just sit and think. Some days I just sit.
Goshen Samba Member
Posted: Mon Jul 07, 2014 9:22 pm Post subject: |
esde wrote: |
Juanito84 wrote: |
I have already blown two oil filters at the rubber seal of the filter where it mates with the spin on oil bracket. I had to rush over to WalMart to buy more oil.
The mechanic suggested i use Fram HP1 because its stronger.... So far so good. He also suggested that i replace the HD spring with stock ones. _________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
