STLCAR Samba Member
Joined: April 24, 2010 Posts: 108 Location: St Louis, MO
Posted: Mon Jul 07, 2014 9:49 am Post subject: Now I have 2 Things (STL)!!!! |
I found another 73 Thing for sale locally that I convinced my wife to let me get. The PO bought it and was hit on the driver fender and never got around to fixing it. He bought all the sheet metal (new) to replace any damaged areas as well as the rust on the rocker panels. Also came with 2 sets of curtains, bottom windshield metal, original engine (in addition to whats in the car-not running)... My other (74) Thing is going to be a bigger project than I intended so I am hoping to get this one up and running fairly fast and have time to drive around this summer. Let me know your thoughts on it.
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Mon Jul 07, 2014 11:25 am Post subject: |
By the looks of that 3rd and 4th picture, it doesn't look like there was very much "convincing" required. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
GodJockey Samba Member
Joined: April 03, 2007 Posts: 240 Location: Lehigh Valley, Pa
Posted: Mon Jul 07, 2014 11:32 am Post subject: |
77kafer wrote: |
By the looks of that 3rd and 4th picture, it doesn't look like there was very much "convincing" required. |
I'd have to agree.
That Thing looks to be in excellent "barn find" condition! |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Mon Jul 07, 2014 12:10 pm Post subject: |
It looks like you scored! Any trouble opening or closing the driver's side doors? Another area to check is the front of the pan and the beam. Sometimes with a front impact, they will bend. An easy way to check is to measure the wheelbase on both sides. |
strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Mon Jul 07, 2014 12:30 pm Post subject: Re: Now I have 2 Things (STL)!!!! |
[quote="STLCAR"]I found another 73 Thing for sale locally that I convinced my wife to let me get. The PO bought it and was hit on the driver fender and never got around to fixing it. He bought all the sheet metal (new) to replace any damaged areas as well as the rust on the rocker panels. Also came with 2 sets of curtains, bottom windshield metal, original engine (in addition to whats in the car-not running)... My other (74) Thing is going to be a bigger project than I intended so I am hoping to get this one up and running fairly fast and have time to drive around this summer. Let me know your thoughts on it.
[URL=http://s20.photobucket.com/user/billyhendrickson/media/20140706_114121_Android.jpg.html][img]
Wonderful! Congratulations! I need a barn find like that! _________________ L'audace! L'audace! Toujours l'audace! |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
babyshots Samba Member
Joined: May 24, 2006 Posts: 104 Location: Cincinnati, Ohio
STLCAR Samba Member
Posted: Tue Jul 08, 2014 8:35 pm Post subject: |
That's still sitting out there. I have been trying to get a hold of the guy but haven't had any success. |
STLCAR Samba Member
Posted: Wed Jul 09, 2014 8:14 am Post subject: |
On the EGr setup I have a green hose coming off of it that is just sitting in the engine bay. Can you tell me where this connects to? If you look at my pics in the thread its the 5th one down and you can see the green hose coming out of the back. Thanks for your help. |
GI Joe Samba Member
Posted: Wed Jul 09, 2014 6:01 pm Post subject: |
You are talking about the green hose in this picture? Near the crank pulley?
Maybe the Domeck Brothers' picture will help?
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Thu Jul 10, 2014 9:50 am Post subject: |
Green hose connects from the dist. to carb to make the dist advance. Should be a port on your carb and it looks like there is one with a cap. On my engine you will see were I am talking about |
STLCAR Samba Member
Posted: Thu Jul 10, 2014 10:16 am Post subject: |
I saw yours but mine has a plug in that port. Do I need to take the plug out? It looks like the PO just put in a metal plug. |
Posted: Thu Jul 10, 2014 3:05 pm Post subject: |
I will let big brother take over to tell were to pull vacuum from |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Jul 10, 2014 3:26 pm Post subject: |
The green hose is for vacuum retard, when using the stock DVDA distributor. If you're using something else (or would rather run your DVDA as an SVDA), you'll want to plug the port on the carb. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Thu Jul 10, 2014 4:29 pm Post subject: |
here is a couple of carbs with different ports you need the big port for the green line for the retard part of the dist I am Rons brother 1 of the Domeck Brothers
Turk.380 Samba Member
Posted: Fri Jul 18, 2014 9:10 am Post subject: |
So I stopped by STLCAR's place last night and we got his Thing fired up! Well, poorly.. but it did run.
Plug wires were crossed up and timing WAY off.. I'm not familiar with how to set timing on the dual-vac dizzy so I just set it at TDC as a starting point to see if it would pop.
Couple of observations:
As noted, his current carb body does not have any Vac ports on the rear (rear is rear), just the one on the side where the Advance vac line is attached. Also, his carb as-is has essentially zero accelerator pump action.
He has another PICT-3 body with the proper ports. I advised taking the best of the 2 and making one that works with the 2nd body, making sure to have good accelerator pump action.
I was also unable to keep the engine running w/out some choke engaged. Open the choke fully: engine dies.
There's oil PUKING out of his breather port on the filler. I've never seen anything like it. But thinking back, I may have a hypothesis: Maybe there's no foil screen bit under the stand? There was also oil leaking around the base, so this could indicate a lack of both gaskets and the foil bit. eh?
He's got a busted exhaust stud on #2 creating a hellatious exhaust leak. My opinion is to pull the motor so that it can more easily be drilled out and re-studded.
I didn't notice if there were flaps / thermostat /etc (missing is very common in this part of the country) but pulling the motor would also allow easier replacement of the generator stand gaskets, allow for the stud repair, and allow for replacing any missing thermostat bits as well.
All the spark plug grommets that seal the tin were melted or missing.
He only had 3 new spark plugs which we gapped and installed. old ones were quite oil fouled. 4th was an old W8AC he had, which I cleaned up and stuck in temporarily.
In all not too bad for about an hour's worth of work. He's well on his way! _________________ Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista |
STLCAR Samba Member
Posted: Sun Jul 20, 2014 6:05 am Post subject: |
I swapped carbs and got the correct ports hooked up. Will be changing out the plug wires today. Take a look and let me know if you see anything out of place.
Posted: Sun Jul 20, 2014 11:00 am Post subject: |
I would install the heat hose on the right it send heat to the air cleaner and to the carb
STLCAR Samba Member
Posted: Sun Jul 20, 2014 11:10 am Post subject: |
Got a new heat hose in just didn't take a picture with it in. On your oil bath it looks like you have 2 vac lines coming off, where does the gray line go. |
