356 A vs B,C muffler
cab66
cab66 is offline
PostPosted: Tue Jul 08, 2014 11:40 am    Post subject: 356 A vs B,C muffler Reply with quote
Hello, I am installing a hotrodded 616/33-1 industrial engine into my 63 bug.
Does any of you 356 folks Know if the repro A type muffler flows as well as the later B or C type?
I was hoping that I could fit an A muffler as the outlets seems to match the beetle apron, but i it can't support around 100hp I'll have to modify a later style muffler.
If anybody has pics of a 356 to bug engine conversion please post.
Thanks Peter,Denmark
ottovu
ottovu is offline
PostPosted: Sun Jul 13, 2014 5:12 pm    Post subject: Abarth muffler Reply with quote
Peter,
I have a nice useable ABARTH Peashooter muffler for $950 shipped to Denmark If you are interested. Keith
cab66
cab66 is offline
PostPosted: Mon Jul 14, 2014 1:52 pm    Post subject: abarth muffler Reply with quote
Hi Keith, I don't think I could bring myself to cut up an ABARTH muffler.
Peter
MoPor
MoPor is offline
PostPosted: Wed Sep 03, 2014 6:02 pm    Post subject: Reply with quote
I doubt there is any difference. You could always buy a Bursh unit too.
Matt
'58 356A coupe
'00 Boxster S
Jacks
Jacks is offline
PostPosted: Sat Sep 06, 2014 9:02 am    Post subject: Reply with quote
No stock 356 muffler will fit in the exhaust area of a bug without significant modification. Probably the only thing that will even come close to being "bolt on" will be the most inexpensive aftermarket, non Bursch, header system that looks very similar to a common old school VW header. For the engine surround tin, use 912 side pieces trimmed down to fit, and VW 36hp breastplate over the exhaust, with only slight trimming, mostly around the dipstick area. 912 tin for the opening between the engine and trans. Trim radius to fit. Cool
Jack Staggs
Actual name
cornemuse
cornemuse is offline
PostPosted: Sat Oct 11, 2014 7:57 am    Post subject: Reply with quote
I once had a '65 C motor in my (still have them both!) '56 bug. I bought (in the early '70's) an 'EMPI' exhaust which was built for just this purpose.
That VW went like a BOH, never new how fast it went, speedo only went to 80 mph. What mph you get at needle pegged?? haha! I have managed to control (pretty much) my crazyness in my old age. -corne-
dsrtfox
dsrtfox is offline
PostPosted: Sat Oct 11, 2014 10:27 am    Post subject: Reply with quote
I did the same thing in the 70's. 64 bug and 62 KG. Used the cheap extractor exhaust on both, and yes they did go like a BOH. I think it was the short VW gears.
I still see the cheap extractor's advertised new but don't remember where, check all the California warehouse sellers...
Jacks
Jacks is offline
PostPosted: Sat Oct 11, 2014 4:23 pm    Post subject: Reply with quote
It's been a bit of time but this will work, and it's in your neighborhood.
http://www.thesamba.com/vw/classifieds/detail.php?id=1678454
Jack Staggs
Actual name
dsrtfox
dsrtfox is offline
PostPosted: Sat Oct 11, 2014 6:50 pm    Post subject: Reply with quote
A blast from the past That looks exactly like the one's I used. Even the tapered tip which I thought looked really cool...
Jacks
Jacks is offline
PostPosted: Sat Oct 11, 2014 7:23 pm    Post subject: Reply with quote
This might work. Spendy though. The French, hey? I think I have a couple in the rafters.
http://www.thesamba.com/vw/classifieds/detail.php?id=1572177
Jack Staggs
Actual name
cab66
cab66 is offline
PostPosted: Sun Oct 26, 2014 1:31 pm    Post subject: Reply with quote
modified a stock 912 muffler,a lot of Work. Pics added to gallery
Peter
