Poraga Samba Member
Joined: September 19, 2013 Posts: 128 Location: australia
Posted: Tue Jul 15, 2014 7:01 am Post subject: If my beetle is making 146 hp atw How much is that at the |
If my beetle is making 146 hp atw How much is that at the engine and is us hp different to Australia hp? |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Tue Jul 15, 2014 7:10 am Post subject: |
You should be about 158 at the flywheel.
I do not know if the translation is the same over there in Austraila. You might need to look that one up. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
mark tucker Samba Member
Posted: Tue Jul 15, 2014 7:12 am Post subject: |
it's a little more at the flywheel,but kinda hard to drive ir with out the trans. |
Poraga Samba Member
Posted: Tue Jul 15, 2014 7:19 am Post subject: |
Ok cool the guy who built me the engine siad it would be 180 hp at the engine why i was double checkin as it didt sound right |
Poraga Samba Member
Posted: Tue Jul 15, 2014 7:21 am Post subject: |
Sry he said 146 atw is 180 at the engine? 25% slipage? |
Posted: Tue Jul 15, 2014 7:25 am Post subject: |
Poraga wrote: |
They might be right if they were running it through a V8 automatic transmission but not a tiny Type 1 4-speed. _________________ -John Cox
Anvil Samba Member
Joined: September 28, 2009 Posts: 248 Location: Golden, Colorado
1 Horsepower is 1 horsepower the world over. If you were converting horsepower to kilowatts, then there'd be a difference. 1-hp is about 3/4-kw. _________________ A man with any character at all must have enemies and places he is not welcome—in the end we are not only defined by our friends, but those aligned against us. |
Posted: Tue Jul 15, 2014 7:26 am Post subject: |
Poraga wrote: |
It's not slippage. It takes HP to turn the gears and moving parts. It is more with an automatic. _________________ -John Cox
Poraga Samba Member
Posted: Tue Jul 15, 2014 7:27 am Post subject: |
Jesus ans this is Australias best vw engine builder |
gt1953 Samba Member
Posted: Tue Jul 15, 2014 7:30 am Post subject: |
Also something to consider is the elevation. Have the vehicle on a Dyno for sure, I did. This was at 5000 feet and you will loose power at elevation.
https://www.thesamba.com/vw/gallery/pix/1209317.jpg _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Anvil Samba Member
180 at the crank and 146 at the rear wheels on a chassis dyno sounds about right to me. _________________ A man with any character at all must have enemies and places he is not welcome—in the end we are not only defined by our friends, but those aligned against us. |
Poraga Samba Member
Posted: Tue Jul 15, 2014 7:33 am Post subject: |
So its possible to be 146atw to bw 180 hp at the crank? It has a wegdemated crank if that makes a deffence ? |
74 Thing Samba Member
Posted: Tue Jul 15, 2014 7:41 am Post subject: |
There is loss due to brakes dragging, tranny, and tire friction on the dyno roller. 20% loss is not uncommon. That would put you close to your 180 figure. |
Posted: Tue Jul 15, 2014 7:45 am Post subject: |
146/.85=171
146/.80=182
So, 170-180 is very close. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Tue Jul 15, 2014 9:51 am Post subject: |
Anvil wrote: |
1 Horsepower is 1 horsepower the world over. If you were converting horsepower to kilowatts, then there'd be a difference. 1-hp is about 3/4-kw. |
SAE gross HP? SAE net HP? DIN HP? I'm sure there are others that don't immediately come to mind. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Anvil Samba Member
Posted: Tue Jul 15, 2014 10:11 am Post subject: |
Towel Rail wrote: |
Anvil wrote: |
SAE gross HP? SAE net HP? DIN HP? I'm sure there are others that don't immediately come to mind. |
IIRC, horsepower is an exact standard to measure work performed over a period of time, but yeah, there are different protocols for measuring it. _________________ A man with any character at all must have enemies and places he is not welcome—in the end we are not only defined by our friends, but those aligned against us. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Tue Jul 15, 2014 10:37 am Post subject: |
This is a no frills way to explain hp:
http://auto.howstuffworks.com/horsepower.htm
Here is another:
http://www.viewamerica.net/art/en-horsepower.html
There is really no way to give an exact or just reasonably exact estimation on flywheel hp out from wheel hp. The variables are way too many.
Tire size, tire type, tire pressure, gear ratio, drag in transmission and rpm. The number can vary from approx 15 - almost 30% a rule of thumb is 17-20%
From that John C´s calculations are about right.
T |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Jul 15, 2014 11:24 am Post subject: |
Forget numbers. Too many times, people get caught up on numbers. I always estimate on the low side when giving an estimate to customers. Short of something obviously wrong with the engine and its output, its time to enjoy the engine. 150 hp is a lot in a vw engine and for a street machine. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Tue Jul 15, 2014 1:39 pm Post subject: |
A 146 RWHP on a calculated 180 flywheel is pretty good. 20% losses is a pretty commonly accepted fudge factor for VWs. A lot can vary according to the fudge factors added in by the dyno operator as well. The difference the OP is probably thinking of is the old SAE vs DIN figures, where different operating conditions such as removing all accessories made for different figures. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Tue Jul 15, 2014 1:47 pm Post subject: |
Poraga wrote: |
Huh? That'd be me......oh wait....no, Im Australia's SLOWEST engine builder. Close.
If it's the guy Im thinking of, how did you ever get off the phone? _________________ "...swingaxle...transaxle...same diff." |
