Kiptere Samba Member
Joined: February 13, 2013 Posts: 419 Location: Houston
Posted: Wed Jul 16, 2014 1:02 pm Post subject: Generator pulley gets really hot |
So hot I can't touch it. I've recut the threads on it twice. Can my bug catch on fire because of this? It's too hot in Texas right now to replace the whole generator. _________________ 62 Bug
70 Bug
68 Bug
70 Bug Vert |
talljordan Samba Member
Joined: January 10, 2012 Posts: 954 Location: San Francisco, CA
Posted: Wed Jul 16, 2014 1:05 pm Post subject: |
Post a photo, are the cooling vents orientated correctly? _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Jul 16, 2014 1:18 pm Post subject: |
Is the belt slipping? Is it tight enough? Supposed to be around 1/2" deflection possible at the centre of the span. _________________ 1958 Karmann Ghia owner |
TheAmazingDave Samba Member
Joined: April 11, 2013 Posts: 788 Location: San Jose, CA
Posted: Wed Jul 16, 2014 2:12 pm Post subject: |
I'm interested in reading your responses. I have the same issue. Belt set for correct tension, generator is mounted properly for cooling air, and I even bought replacement brush covers to help direct airflow through the generator properly.
To be fair though, everything in my engine bay gets hot to the touch after a good drive. |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Wed Jul 16, 2014 3:12 pm Post subject: |
I just replaced my pulley as I was going through belts and couldn't figure out why they were hot and disintegrating so quickly (1 per month or so).
Turns out the front half of the pulley had worn a groove in the back half of the pully at the shaft so the two pulley halves were spinning independent of each other and wearing out the belts. |
Posted: Wed Jul 16, 2014 4:37 pm Post subject: |
I've got 5 shims in there and the belt still seems a little tight. The back half of the pulley is stock, the front half chrome. This may raise some red flags but it previously worked fine. No heat. I should probably remove the belt and see how freely it turns but I have red loctite on the nut now and that will be a problem. I'll post a pic. _________________ 62 Bug
70 Bug
68 Bug
70 Bug Vert |
Posted: Wed Jul 16, 2014 4:46 pm Post subject: |
70 Bug
68 Bug
70 Bug Vert |
jwold Samba Member
Posted: Wed Jul 16, 2014 5:23 pm Post subject: |
I can't quite tell from that angle, but it looks like the belt is riding pretty deep in the channel. |
Posted: Wed Jul 16, 2014 6:19 pm Post subject: |
Would that cause the heat? I noticed the five shims I added had almost no effect of the loosening of the belt. _________________ 62 Bug
70 Bug
68 Bug
70 Bug Vert |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Wed Jul 16, 2014 8:04 pm Post subject: |
Yeah, that belt looks like it's far too deep.
Is it the correct belt?
I only have two shims left in my pulley. The belt's original from the PO when I bought the car in Oct. of 2012.
Tim |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Wed Jul 16, 2014 8:58 pm Post subject: |
Straight edge the face of the crank pulley and gen pulley,a belt will run hot of the pulleys aren't on the same plane.. |
Posted: Thu Jul 17, 2014 3:04 pm Post subject: |
OK. I found a belt that doesn't ride so low in the pulley and installed it. The pulley still gets super hot. Back to my original question - can this situation catch my bug on fire? _________________ 62 Bug
70 Bug
68 Bug
70 Bug Vert |
smokey503 Samba Member
Joined: October 01, 2010 Posts: 713 Location: Ridgefield Washington
Posted: Thu Jul 17, 2014 7:28 pm Post subject: |
Most likely seize your engine if the belt snaps and you don't notice the light in time. _________________ If a car travels the speed of light, would the headlights work? |
goober Samba Member
Posted: Thu Jul 17, 2014 8:22 pm Post subject: |
With the belt off, does the generator spin freely?
And, unless it's stamping marking on the pulley, it looks like oil or grease radiating from the center. Grease from the bearing? Oil from behind the crank pulley? Is the belt dry and free of oil? |
Brian Samba Moderator
Posted: Thu Jul 17, 2014 8:34 pm Post subject: |
How hot is hot?
the backing plate might be upside down _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
jwold Samba Member
Posted: Fri Jul 18, 2014 12:07 am Post subject: |
I don't think it will catch on fire, but somethings not right. I'd suggest getting the correct pulley and fixing it right. I'd also suggest that you not get a chrome pulley, get something stock. |
Posted: Sat Jul 19, 2014 2:00 pm Post subject: |
Well, I switched back to the stock pulley. Tested it without the belt on (it moved freely). Straight edged it to the crank pulley (it was in alignment). Fixed it so the belt didn't ride so low in the pulley (it lines up with the top of the pulley). It still gets hot as hell. Did a websearch for info on the subject. Found a snipit of info at aircooled.net on the subject but couldn't get into the actual article. All I get is a parts page. if anyone can get into the article, please send me a link. This is the link I found When I google "generator pulley gets really hot vw bug"
VW Alternators, Generators and Related Volkswagen ...
vwparts.aircooled.net › Electrical
52 products - When this happens the generator will get so hot, the soldering will come off the ....
At the website:
http://vwparts.aircooled.net/VW-Alternator-Volkswagen-Generator-s/339.htm
When I click on that website, all I get is a parts page. _________________ 62 Bug
70 Bug
68 Bug
70 Bug Vert |
Fab4Fan Samba Member
Joined: June 17, 2005 Posts: 703 Location: Claremont, So-Cal
Posted: Sat Jul 19, 2014 2:12 pm Post subject: |
It's not an article, it's a description to a regulator
http://vwparts.aircooled.net/Bosch-Voltage-Regulator-12-Volt-Generator-Models-p/30-019.htm
Quote: |
New Bosch 12 Volt voltage regulator for VW Beetle, Ghia, and Bus. Generator output is over 14 volts, and regulators charge the battery when it needs it, and more importantly doesn't when it's fully charged! Overcharging will overheat and destroy your battery! When this happens the generator will get so hot, the soldering will come off the armature destroying the generator too!
I guess If this can be the case you should check the charging voltage on the battery. _________________ -LeoDogg |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Sat Jul 19, 2014 4:47 pm Post subject: |
Are you throwing any metal shavings?
Once I had a really hot generator pulley problem. Turns out I pinched the belt between the pulley halves when I installed a new one.
Try reinstalling the correct sized belt by tightening the pulley half while making sure the belt is turning at the same time. As it turns, it will ride up where it's supposed to be instead of getting pinched. Whenever I put a new belt on, I make sure the belt moves with each turn of the wrench as the bolt's being tightened. _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
goober Samba Member
Posted: Sat Jul 19, 2014 4:58 pm Post subject: |
If you have a heavy electrical load on the generator and the belt continually slips, the pulley will probably get hot.
If you turn the generator pulley with a wrench, can you turn over the engine by hand without the pulley slipping to much? |
