I Ride Sand Samba Member
Posted: Thu Jul 17, 2014 9:00 pm Post subject: So I Noticed Something |
While recording a few shots for a video I made, I noticed that the engine in my rail is moving quite a bit, and is solid mounted. Is this what is causing my wheel hop issues on full throttle launches? would a couple support rods from the rear main hoop down to the frame horns solve this or is it a sign that something is amiss? It is moving about an inch up and down. The last two (other than the mid engine) rails I had didn't move this much... |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jul 18, 2014 5:52 am Post subject: |
If you have solid mounts, a inch movement is indicating something is wrong, check frame horns for cracks or fatigue, or any other structural problems.... And a set of braces to frame horns from cage assembly probably would not hurt...
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Posted: Fri Jul 18, 2014 7:44 am Post subject: |
watch from 0:39 to about 1:15. you can see how much it moves
in the hard launch in the corner there is wheel hop, not too bad, but it is there.
i will go tear out the passenger seat and see what i can see. |
HERC Samba Member
Posted: Fri Jul 18, 2014 7:55 am Post subject: |
with everything going on back there, it almost seems deceptive in a way. Hard to say.
I'd get back there, grab the motor and dead lift it a little bit to see if I could feel something flexing
Maybe the whole torsion housing is flexing _________________ Herc |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2647 Location: West Coast (Michigan's)
tsj5677 Samba Member
Joined: December 12, 2012 Posts: 126 Location: Springfield MO
Posted: Fri Jul 18, 2014 10:32 am Post subject: |
yeah it was fun making it, but no more riding for me for a couple of weeks... on that first puddle in the vid, i screwed my back up. it has been sensitive to shock and quick movements for a couple weeks. when the rear wheel hit, it caught the edge of the puddle, and the rail went fro moving down to up really quick. so, i will fix some issues while waiting, this flexing being one of them... |
Posted: Fri Jul 18, 2014 10:35 am Post subject: |
IF you have POLY SEATS, get rid of them, they will hurt you, spend the bucks and get full suspension seats, your back will love you....
Posted: Fri Jul 18, 2014 10:37 am Post subject: |
I Ride Sand wrote: |
Sorry to hear about your back. Instead of trying to man handle to find the flex with a sore back. You could remove your engine skid plate/rear cage (if you have one) and put a block of wood under your engine and slowly floor jack it up a little to see if something is loose or cracked. _________________ Saturn engine swap
http://www.thesamba.com/vw/forum/viewtopic.php?t=540476&highlight=saturn
Slammed street rail
http://www.thesamba.com/vw/forum/viewtopic.php?t=596645&highlight=lowered |
Posted: Fri Jul 18, 2014 10:42 am Post subject: |
Dale M. wrote: |
IF you have POLY SEATS, get rid of them, the will hurt you, spend the bucks and get full suspension seats, your back will love you....
Dale |
i've been looking but so far everything i find are too wide. i am seriously considering building another frame, and if i do, they will be suspension seats. that hurt, and i don't want to be a hobbled over old man when i'm 40. |
flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Fri Jul 18, 2014 12:14 pm Post subject: |
use "searchtempest" to do a wide area craigslist search for Mazda Miata seats. I went from poly seats to Miata seats and it was night and day difference. $100 for really nice leather with only one scratch, another $29 for waterproof covers from Cabelas and I couldn't be happier. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Fri Jul 18, 2014 12:17 pm Post subject: |
how are they on height? I went with the poly just because i had them and built the mounts to fit, but i could just barely get them low enough. another inch taller and i will be banging my helmet on the cage. another strike for a new chassis... |
Posted: Fri Jul 18, 2014 12:25 pm Post subject: |
It may be easier to raise the roof and cross brace this chassis and build it to fit you, vs a new chassis, which you also may have to alter for height. A suspension seat will require about 4 inch additional ht than a poly seat, unless the existing seats are mounted on rails. _________________ rant _ classified ads with out pics are almost worthless |
Posted: Fri Jul 18, 2014 1:03 pm Post subject: |
I've actually built one from scratch before, you can see it in my gallery. it really isn't a much bigger project to build another chassis vs. rebuild the cage on the old. plus, i could start with the irs torsion i have, make it wider for better seats, taller for headroom, fix the engine ground clearance issue, and have a straight frame (this one is twisted)... but i just got this one going...
maybe this winter.... |
Posted: Fri Jul 18, 2014 6:09 pm Post subject: |
They are actually a bit shorter than the poly seats by about a 1/4" butt height from floor, and a full 4" shorter from the top of seat to floor. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
Posted: Fri Jul 18, 2014 6:30 pm Post subject: |
Yes, but when you sit in the suspension seat the bottom springs down another 3 1/2 + inches, at least my 200 lbs does on a Beard seat. _________________ rant _ classified ads with out pics are almost worthless |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Jul 22, 2014 6:53 am Post subject: |
Wow you are right, it looks like those frame horns are dancing around quite a bit back there! I'd tie them into the rear cage and stiffen it all up. Last thing you want to happen is they crack and the engine starts sagging out the back. |
Posted: Tue Jul 22, 2014 8:17 am Post subject: |
Well, I think I found the problem. The welds on top of the end castings on the torsion tube that connect the roll cage are broken. Only 3 welds are keeping the torsion in the buggy. I will have to fix that... |
