satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Fri Jul 18, 2014 5:19 pm Post subject: Idle Adjustment |
My '73 914 2.0l is idling a little high. Where do I adjust It?. My manual is useless. I picture would be great.
Thanks
Dave _________________ DDC racing |
Bleyseng Samba Member
Posted: Sat Jul 19, 2014 1:36 am Post subject: |
The air bypass screw on the throttle body is where you adjust it. First, lube the AAR valve by shooting some PB Blaster into as it rusts and sticks causing high idle. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sat Jul 19, 2014 9:39 am Post subject: |
Thanks
I know it's on the throttle body but where? Do I have to remove the air cleaner? if so won't that effect the idle speed?
raygreenwood Samba Member
Posted: Sat Jul 19, 2014 4:03 pm Post subject: |
It should be fairly easy to see and yes you can remove the air cleaner trunk.....it is a slottrd screw with a spring underneath it and protrudes from the throttle body about 5/8".
Uh.....your car is still fuel injected right?
Ray |
Posted: Tue Jul 22, 2014 5:31 pm Post subject: |
Thanks
pretty obvious after I took off the air cleaner.
