roadkingdoc Samba Member
Posted: Sun Jul 20, 2014 5:05 am Post subject: 40 hp big bore |
what carb and distributor are most of the 40 hp big bores running? is there a consensus best combination? thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
Posted: Sun Jul 20, 2014 5:07 am Post subject: |
Dual Kadrons and a 019 distributor.
Or if you can find a vintage dual carb setup and a 019.
_________________ Glenn
Member #1009
#BlueSquare |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Jul 20, 2014 5:34 am Post subject: |
I am running an 010 with a rejetted 28PICT1 - car runs awesome. _________________ D-Dubya Manx clone - 63 Short pan,1914.
philermonic Samba Member
Joined: November 09, 2010 Posts: 361 Location: Orange County, California
Posted: Wed Aug 20, 2014 11:31 am Post subject: |
I have 30pict carb & a Big Cap (I don't know what one) Distributor.
Runs great! _________________ "A camel is a horse designed by a Committee" |
Harris Samba Member
Posted: Thu Aug 21, 2014 6:43 am Post subject: 40 hp Big Bore |
Running orig big cap ZV/PAU 4R and a Solex PICT with a PICT-1 top and choke. 125 main and 130 air correction. Runs great. |
1960vw Samba Member
Joined: May 05, 2008 Posts: 212 Location: tax everything, liberal ca
Posted: Mon Aug 25, 2014 7:56 pm Post subject: |
Dual webers 34 ICT and German 009 |
Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Tue Aug 26, 2014 10:27 am Post subject: |
dual 28PCI's and one of Glenn's rebuilt 010's _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
Flycast47 Samba Member
Posted: Tue Aug 26, 2014 5:01 pm Post subject: |
Well, back in the late '70s we used a Zenith 32NDIX and an 010 Dist. on a 1385 cc in Funco buggy with great success. Today I would be tempted to try a Weber DFAV/EV progressive if you can find a manifold for it. I would try to use it with SVDA distrib if you can get the vacuum signal correct. |
Mildoval56 Samba Member
Joined: August 17, 2011 Posts: 16 Location: Australia
Posted: Wed Aug 27, 2014 2:13 am Post subject: |
If I can get it set up right I will be running this with a Bosch 019.
Ken Virgin (Australian Made) 40HP twin carb setup. |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Wed Aug 27, 2014 4:57 am Post subject: |
a big bore 40hp with those and the sonic/lukey exhaust is going to make for an awesome Australian period performance motor. love it. |
Posted: Thu Aug 28, 2014 3:18 am Post subject: |
i am running a 010 and a 30pic 1 with doghouse air.. it runs great |
Harris Samba Member
Posted: Sun Aug 31, 2014 1:57 pm Post subject: 40 hp Big Bore |
Apologies. I actually had a 122.5 in the 28 PICT. Not a 125. Noticed this weekend that it was runnimg a little hot in 100 degree weather. Could not hold the dipstick. Put a 127.5 in and it is running very well and I can easily now hold the dipstick after a hard run. May go back to a 125 later if I see I'm running too rich. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Sun Aug 31, 2014 5:56 pm Post subject: |
Glenn wrote: |
That's a very nice set-up for 40hp, carb orientation, linkage, air filters. Can you tell more about it? I don't think I have ever seen Kads on 40hp heads. _________________ Jack Staggs
Actual name |
Posted: Sun Aug 31, 2014 6:04 pm Post subject: |
I am running a big jet in my 1200 big bore with a 28PICT1. Pretty sure its a 127.5 main and this was dialed in on a chassis dyno. Works very well. I do have the compression around 8.1 or 8.2 (without running down to check my build notes). 019 distributor is timed at either 28 or 30 max. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Glenn Mr. 010
Posted: Sun Aug 31, 2014 7:41 pm Post subject: |
Jacks wrote: |
Glenn wrote: |
That's a very nice set-up for 40hp, carb orientation, linkage, air filters. Can you tell more about it? I don't think I have ever seen Kads on 40hp heads. |
They're not Kads, some old school German setup. _________________ Glenn
Member #1009
#BlueSquare |
bug_65 Samba Member
Posted: Wed Oct 01, 2014 3:32 am Post subject: |
My bigbore setup is twin solex 28pci with home made manifolds, jets mains 125 idles 45, air 180 dist 009
Angus Dowrie Samba Member
Joined: March 07, 2005 Posts: 341 Location: Kangaroo Point, Australia
Posted: Wed Oct 01, 2014 3:40 am Post subject: |
Jacks wrote: |
Glenn wrote: |
It is a Riechert kit, period German set-up |
