Jerry39218 Samba Member
Joined: June 23, 2014 Posts: 182 Location: Brandon, MS
Posted: Mon Jul 21, 2014 9:10 am Post subject: |
lil-jinx wrote: |
I recently replaced my link pin bearings,here are the parts numbers I used,30304 J2/Q SKF and 30305 J2/Q SKF both are roller berings and were avail at a local bearing supply outlet'cost little over $50 dollars for both.I would think they will cost less in the USA.I have a 1961 pan as per serial number. |
just picked them up.
30304
30305m
and the seal.
hope they fit |
Posted: Mon Jul 21, 2014 10:53 am Post subject: |
Dont tell me I have to have the races pressed out and new ones pressed back in?
Posted: Mon Jul 21, 2014 6:01 pm Post subject: |
yay, got the bearing and races in... used the trick with the old races, worked like a charm.
(patience is required in getting the old ones out tho)
Now, I have another question... check the pics below and notice the stress fractures in the space between the inner and outer bearings in the drum.
I take it this is a bad thing? I reinstalled the drum as I don't have another..I'm just wondering HOW bad this is? Drum fly apart maybe?
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Mon Jul 21, 2014 6:26 pm Post subject: |
If they are cracked you should be looking for another drum,that line in the top picture looks to be a mark from the sand casting when they made the drum. |
Posted: Tue Jul 22, 2014 3:52 am Post subject: |
lil-jinx wrote: |
I agree, that's the casting line, but there are numerous cracks all around that center area.
Time to replace the drums now I guess.
thanks to all who helped in this little project |
azspeedbuggy Samba Member
Joined: June 20, 2006 Posts: 226 Location: Tucson Arizona
Posted: Tue Jul 22, 2014 11:14 am Post subject: |
Nice looking buggy! _________________ AZSpeedBuggy
aka the Bullit
green Meyers Manx dune buggy...since 1975
Chenowth 2 seat rail with 1641 VW power
Tucson, Arizona |
vincent9993 Samba Member
Joined: November 09, 2006 Posts: 2025 Location: Montreal
Posted: Tue Jul 22, 2014 12:08 pm Post subject: |
Not to hijack the OP's thread but since my question is related, I thought I'd ask it here.
I've been going through front wheel bearings like crazy. We run a B/J spindle and disc brake setup on the Kick-Out-S.S. and just before the ECVW trip, I swapped them out with new FAG brand bearings and brand new grease. The rollers in the bearings were pitted. I also replaced both races.
Half way on our 7,700 mile trip, I had to replace both bearings again with badly pitted rollers.
Could a bent spindle be causing this problem? I know the outter spinle shaft is undersized by about .005 and I tried the center punch trick but it's still a litle loose.
We never overtighten and always clean and use new grease when changing the bearings. As I got home, I could tell that the bearings have started to go bad again but I have not yet pulled it off to check.
What else could be causing premature and frequent bearing failures?
Thanks. |
sandhopper Samba Member
Joined: December 13, 2004 Posts: 453 Location: Norwalk Ca
Posted: Tue Jul 22, 2014 1:57 pm Post subject: |
With it beeing both sides and only the outers , I would not think bent spindle
Maybe bearing quality , but I thought FAG was good
Front wheel off set / load ?
Type of wheel grease ?
Good luck on finding this one |
Posted: Wed Jul 23, 2014 4:02 am Post subject: |
After the drive in to work yesterday, I noticed now my front brakes catch momentarily to the drivers side...but not every time.
Best I can recall I did nothing to the brakes, except take off the plate hah.
VW gremlins, I remember those from years ago also |
