Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Thu Jan 22, 2015 6:59 pm Post subject: Question |
Can you elaborate on the phrase "4 lug drums drilled to Porsche pattern" please. I've never heard of this drum drilling. Are the drums the wheels or brake drums? Pretty clueless over here! |
twistedbug Samba Member
Posted: Thu Jan 22, 2015 7:43 pm Post subject: |
The rear brake drums are for the 1968 bug transaxle, they were drilled to a 5 lug Porsche pattern and studs were installed, that way no adapters were needed to use the fuchs. Most machine shops can drill out your drums to fit other lug patterns as long as there is enough area, my Baja bug has jeep/ford pattern on the disc brake rotors |
Posted: Thu Jan 22, 2015 7:58 pm Post subject: Thank You. |
Thanks for the info. I learn something new every time I get on the site. |
Posted: Thu Jan 29, 2015 9:36 am Post subject: beam out |
got the beam out, started the clean up underneath. wire wheel/ air sander, cleaned up pretty good.
Posted: Fri Jan 30, 2015 5:13 pm Post subject: rust treatment and paint |
Posted: Tue Feb 03, 2015 6:50 pm Post subject: |
got the beam disassembled, rusty greasy nasty, shock collars were rusted onto the trailing arm shock mount, heat and pb blaster to get them off, degreased and painted the trailing arms today. still have to clean cut and drill the spring pack for the beam.
Posted: Sun Feb 08, 2015 5:52 pm Post subject: a little before and after |
wired wheeled, air sander, rust converter, primer and paint, a lot of work for parts you wont see unless you lay under the bus
next is the spindles |
maddog125 Samba Member
Joined: December 24, 2008 Posts: 42 Location: California
Posted: Tue Feb 10, 2015 12:42 am Post subject: |
Those innards are cleaning up real nice! Are you planning on leaving that og swr untouched?
Those first pics of your bus reminds me of a 23 I saw cruising around San Fran a few months back (maybe someone knows whose it is):
Posted: Tue Feb 10, 2015 7:27 pm Post subject: |
stripping it back to OG paint and trying to blend in the bad areas, that's my plan. |
Posted: Wed Feb 11, 2015 3:12 pm Post subject: |
Hell yeah |
Posted: Thu Feb 26, 2015 10:45 pm Post subject: |
got the spindles cleaned flipped and painted
Posted: Fri Feb 27, 2015 7:19 pm Post subject: |
a little more work today, nasty greasy spring pack removed and cleaned, still need to drill the holes for the grub nuts and cut the spring pack to legnth
we finally got RAIN!!! had to pack up everything and get it in the garage fast |
Posted: Thu Mar 12, 2015 6:18 pm Post subject: |
got it on all 4's again, still more to do, I have to run the hard lines for the brakes, m/c and im sure another dozen things before a test drive
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Thu Mar 12, 2015 6:41 pm Post subject: |
Looking good. _________________ and take the kids for instance "Are we going in the Volkswagen bus?" and they say "Yay!" and clap their hands and if it's a glorious day you can slide the sunroof back and let a little of the glory in and all of a sudden, it stops looking funny.
-Volkswagen ad |
Posted: Tue Mar 17, 2015 9:58 am Post subject: |
back in the garage, all 4 up off the ground, did the axle boots, throttle cable, clutch cable and M/C, now on to the hard brake lines, this bus is rusty underneath and I didn't like how the brake lines looked, they had clean fluid in them, looks like a brake job was done right before it got parked. All new brake components front to back now.
Posted: Tue Mar 17, 2015 6:01 pm Post subject: |
The new rear brake lines were to short, had to find a set off a donor bug, new parts for vw's are hard to find in a small town. The axle tube boots I got from cip1 were fine but the hose clamps were junk, the nut and bolt package was missing 1 washer and the nuts wouldn't fit into my nut driver, Little things just slow me down and piss me off, the boot kit said made in Germany. just saying, put the m/c in, ran all the new hard lines (pain in the ass bending the lines, not like I do this all the time, realized I didn't have the soft lines for the front so had to go get them couple towns over, tightened everything up, hope it doesn't leak
Posted: Mon Mar 30, 2015 5:48 pm Post subject: |
Gas tank in, now onto the electrical, its a mess and wiring is not my friend. Funny thing is by trade I was a electronic/electro mechanical tech. auto electric seems over engineered to me,
Posted: Tue Mar 31, 2015 10:01 pm Post subject: |
put the stationary glass and jail bars in today, took off some more primer and horrid red oxide paint, exhaust showed up today with some other small parts, ordered EIS front safaris today also, another Grand this month into it.
Posted: Thu Apr 02, 2015 4:34 pm Post subject: 64 21 window build |
Safaris showed up today, I had to clean up around the windows before they go in, did a little more work on the nasty oxide red paint on the front roof section, I think it looks better.
Posted: Sat Apr 04, 2015 4:40 pm Post subject: 64 21 window build |
finished up the safari's, im happy with them, will be ordering wolfgang seals, eis seals don't let the window close all the way easily, I was worried the glass was going to break. couldn't blend the paint around the front windows as well as I would of liked to, had to just use primer, looks good enough for me, now onto the engine. I got the starter hooked up to the key on the first leg of the electrical chaos .
