darg Samba Member
Posted: Mon Jul 21, 2014 4:05 pm Post subject: 009 dist 180 o out |
I have a 73 type one engine , bought from a previous owner that I could not get started. I read on the forum about someone switching plug wires, so I reversed 1&3 @ 2&4 and it started up . I guess the dist drive gear is out 180.
Question is , will it hurt to run the engine like that ? How is the best way to adjust the valves? It has the 009 dist. The engine came with the bug un installed.
thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Jul 21, 2014 4:27 pm Post subject: |
Flip the drive on the bottom of the 009. Then #1 will be where it should.
Valve adjustment is same as always. _________________ Glenn
Member #1009
#BlueSquare |
Danwvw Samba Member
Posted: Mon Jul 21, 2014 5:40 pm Post subject: |
It's a bit harry because of those two distributor gear drive washers and the distributor drive spring in there but I would pull the distributor drive gear and set it correctly. You will need one of these: Puller. If the washers come out with the drive gear good, dry them and grease them to stick to the drive gear with some axle grease and put it in correct. If they don't come out but stay in place, no problem but if they slide out of place down in the engine, use a magnet wand to remove them then clean and install on the drive gear using the axle grease. Be gentle re-installing it. Don't force it down into place and don't turn the engine over by force before it drops into the full seated position. Turning the engine over by hand tends to push the drive gear and the distributor back out of the case when not fully seated. Be Gentle!
(Personally I have never been able to get that pin in my distributor drive out of any of my distributors to switch it on the distributor.) It is fine just to leave it the way you have it too. Not necessary to change the drive gear 180' On the 009, I don't think there is any retard on #3. Any 1971 and later model vw type 1 engines it does not matter if it's backwards at all. It's just confusing to future mechanics that work on it.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Mon Jul 21, 2014 9:03 pm Post subject: |
For what it's worth you CANNOT put the drive gear spacers on the gear as they would hit the BRASS gear on the crank.
The spacers have to be installed carefully with some grease via a long thin screwdriver and then the drive gear in the position desired.
(VW mechanic retired) |
Danwvw Samba Member
Posted: Mon Jul 21, 2014 11:25 pm Post subject: |
That could well be, Seems like I did use a push rod on my last engine to stick in the hole and drop them in. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
darg Samba Member
Posted: Tue Jul 22, 2014 3:13 am Post subject: dist out 180 |
Thank you guys for the help. I think I will leave the dist. as is . At sometime I would like to get the correct dist .
Can some one tell me what the timing should be at idle with the 09 and the pict 34carb.? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Tue Jul 22, 2014 4:31 am Post subject: |
If you set max mechanical at around 28-32 (which is how you are supposed to set it), your idle will be somewhere around 10 degrees give or take a couple degrees. Your concern is max timing, idle is where ever it ends up at.
And I am assuming you are aware of the various workarounds for the 34 PICT/009 flat spots. There are probably 100 threads on that subject. _________________ D-Dubya Manx clone - 63 Short pan,1914.
HRVW Samba Member
Posted: Tue Jul 22, 2014 8:35 am Post subject: |
Ho Hum...Flat spot problems blamed on the poor 009 dist when it actually is the Carb that needs the proper adjusting.
Decades ago when doing Engines played around and discovered a solution.
After that never had any complaints of any 009 complaints from customers.
Could say what the solution is but don't like any debates with many that have not worked on engines for a living and a shingle over the doorway.
Stop and look at the dist and carb functions as they work independently.
(VW mechanic/engine builder/parts house owner of 28 yrs) |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Jul 22, 2014 2:33 pm Post subject: |
HRVW wrote: |
Decades ago when doing Engines played around and discovered a solution. |
Some may call it a solution but most call it a hack.
A hack just so you can run a cheaper distributor instead of the correct more expensive one.
Blaming the stock carb for a flat spot when fitting a 009 is like fitting a cheap Chinese chrome tinware and blaming the engine now running hot on global warming. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
darg Samba Member
Posted: Tue Jul 22, 2014 3:22 pm Post subject: 009 dist. |
Thanks, On the 10 degrees , is that before or after TDC. I do not know if the carb has been corrected or not. I am still restoring our 70 bug. Hope to get the body back on next month. : |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Tue Jul 22, 2014 5:05 pm Post subject: Re: 009 dist. |
darg wrote: |
Thanks, On the 10 degrees , is that before or after TDC. |
Not trying to offend but you need to follow directions better. andk5591 didn't say YOUR idle timing should be 10deg. The variation in tolerance between the different 009 distributors is large. Setting the max advance with a strobe timing light is the safe way to make sure it doesn't over advance at high rpms. Some 009s when set to 30BTDC will idle at TDC (0 deg), others will idle at 15BTDC. So setting your 009 timing at idle without checking the max advance and you could easily hit 40BTDC when you rev your engine and it will donate!
Follow the instructions for setting your timing at max advance. Once you know it will not advance beyond a safe limit (28-32BTDC) you can take an idle timing reading and use that for future tune ups. That will be the specific idle timing for your 009 and not anyone else's. _________________ AshMan40
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Glenn Mr. 010
Posted: Wed Jul 23, 2014 7:16 am Post subject: |
Hyperspace wrote: |
The pin comes out if cradeled in a vice (not clamped) and hit with a punch and BFH. Don't try to use the little hammer you use for nailing stuff down. |
Remove the wire retainer, clamp it tight by the tabs. Use a punch and a BFH and drive out the pin. Rotate the shaft 180* and reinstall.
You're making this harder than it needs to be.
Member #1009
#BlueSquare |
darg Samba Member
Posted: Wed Jul 23, 2014 4:32 pm Post subject: 09 dist |
On the 10 deg.what I was asking was that at 10deg was that BTDC or ATDC.
Thanks for the reply also. |
HRVW Samba Member
Posted: Wed Jul 23, 2014 4:44 pm Post subject: |
If you were to look at a clock 12:00 would be TDC
Engine turns to the right so 1-2 o'clock etc would be BTDC
10-11 o'clock would be ATDC
If you wanted the timing mark (cyl firing) at 7.5 degrees it would be to the right of TDC or BTDC
If you wanted the timing mark (cyl firing) at 5 degrees it would be to the left of TDC or ATDC
The 7.5 degree is basically for the Single Vac dist
The 5 degree is basically for the Dual Vac sdist |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Thu Jul 24, 2014 12:19 pm Post subject: |
Glenn wrote: |
Valve adjustment is same as always. |
That worked on mine!! |
darg Samba Member
Posted: Thu Jul 24, 2014 3:58 pm Post subject: 09 dist |
Thanks for the replays. On one of the post some one said to flip the drive . -by knocking the pin out. I will try that when I get a chance. |
