peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Posted: Wed Jul 23, 2014 8:24 pm Post subject: |
matt94gt wrote: |
Thanks for sharing those pics, I always saw schematics of that filler hose, but its good to see actual photos. Is there anyway to remove the rear panel to just take a peek at this without pulling the entire motor? |
It will be tight I think, but you should be able to get the firewall screws out and peek behind (don't quote me though, I've never done it).
The one I would be shooting for would be the filler hose. That's easily seen and replaced on a Regular Bug, but I'd guess it's almost never replaced on a Bus. Even if you can just sneak a peek with a Mirror and a flashlight just to check. _________________ My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189 |
Mike C Samba Member
Joined: September 18, 2008 Posts: 303 Location: Albuquerque
Posted: Wed Jul 23, 2014 9:06 pm Post subject: |
Thanks for all the info. _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
[quote="1977_L63H_P27"]As mentioned before, it's a 9-passenger Deluxe. The true "station wagon" of buses. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Jul 23, 2014 11:07 pm Post subject: |
peteandvanessa wrote: |
Fuel line brand, size, and age?
All the soft fuel lines were replaced from the Fuel tank to the Carb, I also relocated the fuel filter to under the chassis, well away from the heat exchangers and header. The fuel lines were brand new.
I purchased two sizes of fuel pipe from my local Flaps store (I think it was around 5/16" and 1/4" or there abouts. I initially put on the larger diameter pipe, but after fitting I wasn't happy with it, it was a little loose, so I removed the larger fuel pipe lines and installed the smaller diameter fuel pipe which fitted well. The fuel pipe was the Non-Braided type.
Clamps? What kind?
I used the screw type clamps
So you don't think at all that the SAE hose on metric fittings could have caused this?
If you've ever tried to remove the good braided hoses from the flared VW fittings, you'd know how much better they fit than ANY crap you can buy at AutoBone. That is, if you've converted to 1/4" fittings all around than you would have been ok. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
wcfvw69 Samba Purist
Posted: Thu Jul 24, 2014 6:00 am Post subject: |
asiab3 wrote: |
Clamps? What kind?
If you've ever tried to remove the good braided hoses from the flared VW fittings, you'd know how much better they fit than ANY crap you can buy at AutoBone. That is, if you've converted to 1/4" fittings all around than you would have been ok. |
I wish whoever makes the good, German braided fuel hose re compounded it to work with the current fuels on the market. It doesn't last very long at all with the Ethanol in the fuels these days. It's also known to dry up and crack after only a couple of years. I bought some fuel line that's rated for todays fuel from Autozone for my bus. I can't recall the actual size of the hose but it fit fairly tight on all the fittings. Each fitting also had a good hose clamp installed.
Until I hear otherwise, I'm not using the German braided fuel line anymore, even though I'm a purist. I don't want to keep changing fuel lines every couple of years due to the hose/rubber not holding up to today's fuel. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Jul 24, 2014 6:27 am Post subject: |
wcfvw69 wrote: |
asiab3 wrote: |
Clamps? What kind?
I agree. The fuel lines I fitted were just off the shelf non-braided fuel lines. The smaller fuel hose I fitted was up to the job, fitted tightly, and had a hose clamp. I checked them after fitting for tightness and also checked for leaks, they were fine. I seriously doubt that the SAE hose on metric fittings fuel lines were the problem. _________________ My 1974 Standard Build Thread:
Posted: Thu Jul 24, 2014 6:57 am Post subject: |
wcfvw69 wrote: |
asiab3 wrote: |
Clamps? What kind?
I agree. The fuel lines I fitted were just off the shelf non-braided fuel lines. The smaller fuel hose I fitted was up to the job, fitted tightly, and had a hose clamp. I checked them after fitting for tightness and also checked for leaks, they were fine. I seriously doubt that the SAE hose on metric fittings fuel lines were the problem. |
I don't think that was the problem either, especially if you had clamps on them that were tight.
The above picture was of the fuel line coming off the gas tank nipple on my new to me 70 bus. I had just bought this bus and am/was going thru the systems. You can see the drip on the fuel line. I have no idea how old this fuel line was but when I removed it, I bent it and it cracked in half, it was so dry. _________________ Contact me at [email protected]
Posted: Thu Jul 24, 2014 8:14 am Post subject: |
So what if I told you that there was a VOLSKWAGEN-made 5mm braided line? Oh wait, it's not readily available online so the collective group thought here won't get off their computers and go look for it.
Here are two lines, one brand new and one with over 12,000 miles on it.
I poured (according to my notes) over 600 gallons of the cheapest 87 ethanol fuel through these lines. Most of the time it was 10% but in the counties where they serve up 15% that went in with a smile.
I'm not going to blame the ethanol because it's easy to blame or any other crap excuses.
Here you go- guess which is new and which lines got me accross the country and back two and a half times?
VW/Audi- made for their air-cooled cars.
I won't tell you which hose is new and which is used. My only caveat is that I drive my bus 360 days a year. So I don't let the fuel sit and rot, which esentially turns the ethanol into a molasses-y candybar soup.
Posted: Thu Jul 24, 2014 8:57 am Post subject: |
Thanks Robbie for your insights into the different types of fuel hose.
With respect though, we are drifting off topic.
The bottom line is:
1. There was a fire in the engine compartment
2. The real cause will probably be unknown
3. I suspect it might have been related to the fuel tank (if I find out any more, I'll report back here)
4. I am satisfied that the replacement fuel hose was adequate and up to the task and it was fitted securely and correctly
5. The carburetor inlet barb might have pulled free, but with the carb being destroyed in the fire we cannot definitively prove that, that was the cause.
Onwards............... _________________ My 1974 Standard Build Thread:
Last edited by peteandvanessa on Thu Jul 24, 2014 12:35 pm; edited 1 time in total |
Posted: Thu Jul 24, 2014 11:10 am Post subject: |
asiab3 wrote: |
Robbie, you had me at hello!
That's great information that this hose is available from VW vs. the aftermarket. Have you done any research as to what it's rated at (fuel wise) and how long VW recommends this hose to be used before being changed? I ask this question due to the recommendation that the current braided hose is not known for it's longevity. Many veteran VW folks changes there every year or two which you don't have to do with the modern fuel hoses sold at the local FLAPS location.
Did you purchase it from your VW dealer or online? _________________ Contact me at [email protected]
timvw7476 Samba Member
Posted: Fri Jul 25, 2014 9:41 pm Post subject: Phoenix - A 1971 VW Westie returns from the Ashes |
Looks like some kind of cosmic nascar team at work there,
once they get baptized they usually turn to the pre-christian
god Pan, the one of the forest & fertility.Prepare yourselves. |
Posted: Sat Jul 26, 2014 8:43 pm Post subject: |
Work continued on the engine tear down.
Bob, Dan and Dewey started the tear down of the engine to a Long Block.
They also have another Motor in a 70's Bug to get donor parts from(awesome when you have a donor car just lying around in the yard), Dan started pulling the donor parts, which was slow because some of the screws and bolts were rusted on and had to be busted off.
Tranny area clean up
Time to pull it apart:
Down to the long block:
Donor Parts:
Rear Flywheel:
Heater Boxes:
More pics will follow tomorrow _________________ My 1974 Standard Build Thread:
Tcash Samba Member
Posted: Sat Jul 26, 2014 9:09 pm Post subject: |
Good going.
Vacuum advance has a rubber diaphragm inside that may have melted. Test and make sure it holds a vacuum.
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
Posted: Sun Jul 27, 2014 5:37 pm Post subject: |
So we all met Sunday today to start the strip down. It was a messy task. The window rubbers had melted into a sticky goo. Yuck and really hard to get off.
What we do know is that it WASN'T the Gas tank that caused the fire, the Tank was protected by the firewall and nothing was out of place when we opened it all up. We are now pretty sure that it WAS the carb inlet barb that caused the fire.
Here's the tank after we pulled the motor and fire wall:
The 1971 filler hose was intact and NOT leaking (it's wonky in the pic since I unfastened the clamp to inspect the hose, it was fine and un-cracked):
The vent lines were in pretty good shape too, even the rubber connector hose was good too.
Time to start cleaning:
Bob - Do you think it's going to get that BAD?
Pressure wash time, get to it people and wash that Bus
Bubble Power:
Time to feed the hungry crew:
All clean:
The only thing left is to go for a cruise:
Slow down Dan, we don't have seatbelts yet!!
Bob didn't come on the cruise, he had to empty this:
Sincerest thanks to Kim, Bob, Dewey, Cody, Oscar, James, Weslee, Mike plus all the other people I might have missed, without you it would still be a burn't out smokey Bus. Now she's much cleaner and sweeter smelling. _________________ My 1974 Standard Build Thread:
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Jul 28, 2014 8:15 am Post subject: |
So many helpful people. That is just awesome! _________________ 1976 Westy
1966 Beetle |
JDub113 Samba Member
Posted: Mon Jul 28, 2014 12:38 pm Post subject: |
That is so cool that you got an awesome crew that are willing to jump on it like that! Good work guys. Those are some good friends there. _________________ 84 Wolfsburg Edition Westy |
Banjoben Samba Member
Joined: October 02, 2011 Posts: 220 Location: Finger lakes Region N.Y.
Posted: Mon Jul 28, 2014 1:41 pm Post subject: |
That's a dedicated crew of true friends there. I worked on a burned out Porsche 356 once. I can almost smell that Bus from here. Here's hoping you can get that stank out of it eventually.
Keep up the good work! _________________ 1974 VW Westfailia Campmobile Deluxe (Clementine)
1970 VW Type 3 fastback. (Abby Normal )
2008 Passat Turbo Wagon Lux
ASE Certified Advanced Level Master Tec / Toyota Master Diagnostic Tec.
Head Boffin of the legendary(does it really exist?) Stray Cat Vintage and Custom Garage. Home of "The Bomber Squadron" |
rwflyboy Samba Member
Joined: April 06, 2014 Posts: 21 Location: United States
Posted: Tue Jul 29, 2014 8:00 am Post subject: |
Looking great.. a lot of hard work so far.. going to be nice seeing it getting back on the road when you are done. This may help. http://cleveland.craigslist.org/pts/4583186153.html _________________ Randy
1976 Westy Raby type 4 Camper Special
purch 5/3/14
1982 Vanagon Westy Diesel 1.6NA
purch 4/3/15
1987 Doka Fire Truck
purch 4/1/16 |
