peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Posted: Sun Sep 28, 2014 7:33 pm Post subject: |
Dan and the boys were busy over the weekend.
New sliding door handle:
New rear lights installed and wired up:
Temporary driver and passenger seats installed (well how will we get to the brake and light inspection without seats)
New windshield installed:
New seals on the quarter vents:
The hideous wiring that the previous owner installed was burned away, and replaced with some patch wires:
Rear lights wired up and functioning:
Planning on the brake and light inspection to get the Bus back on the road. It's getting closer. Then Dan can at least drive it again.
Also have an original German carb refurbished by volksbitz coming next week. Don't want another fire and he produces quality carbs. _________________ My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189 |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Sep 29, 2014 9:51 pm Post subject: |
where did you get the windshield from? i see no blue tint strip...me likey! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Oct 06, 2014 6:58 am Post subject: |
Went down to help my Son on Sunday to install some Windows and trim:
Installing the passenger side window trim, seals and glass:
Driver side done:
Passenger side done:
Mirrors installed:
Sourced a good used rear door to replace the one that was buckled in the fire. Bob and his Son got the door, seal and glass installed. The Bus is now weather tight!!!
Rear door and glass installed:
The Bus passed it's lights inspection earlier in the week. Had a small issue with one of the rear brake drums, finally pulled both rear brake drums off and found one of the brake pistons was leaking and the brake shoes were worn unevenly.
The star adjusters were stuck fast, so Bob freed them up. Decided to replace the brake pistons on both sides and cleaned it all up.
Just waiting on some new brake shoes, which will get installed this week. Then it's back for it's final brake inspection.
Planning on getting the brake testing done early this week, then down to the DMV to get the registration and paperwork completed. Then the Bus will be back on the road. _________________ My 1974 Standard Build Thread:
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Oct 08, 2014 6:07 am Post subject: |
Seriously impressive recovery!
Where did you source your front door window seals? |
MrDblCab Samba Member
Posted: Wed Oct 08, 2014 11:05 am Post subject: |
I was not ready for the after fire picture at the start of this thread. Really made me cringe.
Amazing restore from the ashes, a true Phoenix!
Now I need to go check the fuel system on the DbCab and the bug for the 100th time. Never gets old.
Best of luck on your continued restore.
Matt |
Kudagra Samba Member
Joined: March 22, 2007 Posts: 105 Location: Baldwin City KS. Just a wee bit South of KC
Posted: Mon Oct 13, 2014 7:12 am Post subject: |
So whats the little cog pulley for?
_________________ But Mom...it followed me home! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6986 Location: Durango, CO
photoboy52 Samba Member
Joined: September 24, 2010 Posts: 15 Location: SoEast Texas on the Gulf
Posted: Mon Oct 13, 2014 3:35 pm Post subject: |
Amazing! Just read all and wow what an amazing group of people, lots of dedication there _________________ Current
1972 Sierra Yellow Campmobile
1.7L (rebuilding)
'97 Geo Metro 3 door 1L
Tin can on a skate
(Did engine rebuild my self)
Past
1961 Bug Sedan
Thrown Rod (Recently found it still at home now need to get from Nor Cali to SE TX!!) |
Posted: Mon Oct 13, 2014 5:02 pm Post subject: |
richparker wrote: |
Kudagra wrote: |
I'm gonna say an AC compressor. |
Not sure, although we do know it has some engine stamps that marked it an industrial engine originally, so who knows what the cog was for.
We do know that before this motor, the P/O installed a larger motor and cut out the air cleaner stand and clamps. They also cut out the engine compartment tin and then pop riveted it back in which contributed to the spread of the fire.
Now, it's back to a daily driver, and Dan is driving it around to various body shops for quotes for metal work repairs. Still can't believe that the Bus is now back on the road and running after this short period of time.
Hat's off to all that helped to pull it all back together!!! _________________ My 1974 Standard Build Thread:
Posted: Sat Oct 18, 2014 5:52 pm Post subject: |
Got the clutch adjusted this morning, it was alittle too tight, so I just backed it off a couple of turns.
Cleaned up the rear of the Bus, and also cleaned up the front cab, then installed a really nice rubber mat:
Re-installed the roof rack after painting the brackets:
So while I was at it, I cleaned up the rear tail gate and painted it blue, just to save it from rust while we get someone to do the body work.
This baby is cleaning up nicely:
More work tomorrow and more pics as well _________________ My 1974 Standard Build Thread:
Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Sat Oct 18, 2014 6:19 pm Post subject: |
richparker wrote: |
Kudagra wrote: |
it was for a governor that the 126A industrial engines had. driven by a mini timing belt
cool story. glad no one was hurt, and the bus lives on _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
