drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Aug 21, 2014 1:33 pm Post subject: |
I’m wondering.... It doesn’t make sense that you recently replaced the king pin bushings and still have play. Unless you left out the thrust washer. But that still shouldn’t give you the type of play you have.
There are two different styles of trailing arm. I’m not sure exactly what year the change came, but here’s the deal.
The early arms had flat faces on the trailing arms. They used 10 shims on each link pin.
The latter arms have a recess in the face and they use 8 shims and a special thing that looks like a stepped, square washer that is the O-ring cover.
If the link pins are not adjusted, you can get play at the link pin. But you shouldn’t have the camber change that you are seeing.
If you left out some of the shims, you can get play at the link pin. But you shouldn’t have the camber change that you are seeing.
So, if the wheel bearings are not sloppy, and the link pins are tight and adjusted, the only thing left that could give you that sort of camber change is the king pins and bushings unless your link pin bushings are totally trashed. _________________ Mother Nature is a Mean Evil Bitch! |
Snowking63 Samba Member
Joined: December 01, 2012 Posts: 161 Location: Cerritos, CA
Posted: Sun Sep 07, 2014 8:14 pm Post subject: |
Sooo I just replaced the old passenger spindle with the new one I got with the chinese pins. And of course my dad and I made sure we inspected everything as we took everything off. The bearings are fine and they were tight. Anyway, after installing the new spindle it was a huge improvement. After pushing and pulling on the tire at 12 and 6 there's no play!
So the spindle is on nice and tight and correctly and it seems the problem is fixed until I backed the car up. There is still as much camber as there was when backed up or drove forward as it's always been.
This might sound weird but we traced the problem down to being the tires. The tires are flexing because of the size and of course the style. My dad measured them when the car was moved back and when moved forward and they flex 5/8" of a difference.
I still have the driver side spindle to replace and I will also need some new tires. If there are any baja owners reading this I need a recommendation of some good tires that won't flex as much as mine do. I have bf Goodrich TA Radials and I'm not too sure on the size _________________ Money is a gas, not a trip
OGK
my 63 baja daily driver
http://www.thesamba.com/vw/forum/viewtopic.php?p=6485278&highlight=#6485278 |
Posted: Wed Sep 10, 2014 11:54 pm Post subject: |
After replacing the spindles and getting new tires, the car handles better than it ever has since I've had it. Haven't had time to look at the camber yet since I had to leave to work once I got it home from the tire shop but I honk it's safe to say the problem is fixed. There is some rubbing going on when the wheel is turned all the way to the right but that's an easy file down on something _________________ Money is a gas, not a trip
OGK
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Thu Sep 11, 2014 10:31 am Post subject: |
Snowking63 wrote: |
There is some rubbing going on when the wheel is turned all the way to the right but that's an easy file down on something |
Yea, that's how to fix it... . Sounds more like the steering box isn't centered or the tie rods need to be adjusted by lengthening the side that rubs and shorting the side that doesn't. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Thu Sep 11, 2014 9:07 pm Post subject: |
Steering stop for king and link pin front end was actually one of the bolts that hold the backing plate to the spindle. One of those 3 was longer then the others. If you needed more turning, you filed that bolt a little. _________________ Mother Nature is a Mean Evil Bitch! |
Joey Samba Member
Posted: Fri Sep 12, 2014 5:19 am Post subject: |
true - but filing the bolt will make it turn more which will cause more rubbing... _________________ Joey
raycer60 Samba Member
Joined: January 15, 2013 Posts: 167 Location: H Town Texas
Posted: Fri Sep 12, 2014 8:45 am Post subject: |
Then do the opposite. Replace bolt with a longer one, test and file as needed. Still, easy cheap fix. |
