vincent9993 Samba Member
Joined: November 09, 2006 Posts: 2025 Location: Montreal
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Tue Jul 22, 2014 4:19 pm Post subject: |
Buy cheap, get cheap.
Ever have a fan explode? I have and its not cheap to fix all the damage.
I'd only buy a OE welded fan. The question is "who welded it and was it balanced after". _________________ Glenn
Member #1009
#BlueSquare |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Tue Jul 22, 2014 4:26 pm Post subject: |
I recently got the oe vw fan from cip1,it is made by skoda ind in europe,seems like a good quality part.time will tell. |
Danwvw Samba Member
Posted: Tue Jul 22, 2014 4:33 pm Post subject: |
Depends on if your fan shroud is a Dog-House which uses the 35mm ID fans. the 32mm ID fans are for the non-Dog-house fan shrouds and would not cool as well if used in the Dog House fan shroud. If you go with the cheap one let us know if it holds up (it should be ok if you never rev above 4500 Rpm. What happens is you reach back there (engine off of course) after a few hi rev up's and find that a vain is missing. Probably laying on the flaps jamming them from operating normally. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
bornred62 Samba Member
Posted: Tue Jul 22, 2014 4:52 pm Post subject: |
Vincent, Spend the extra money buy the welded fan also buy a new washer. After you get it all together and the nut tight a quick tack weld will keep it in place and can be ground off if you should need to change it someday. As many miles as you drive it will be one less thing to worry about. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Jul 22, 2014 5:04 pm Post subject: |
Buy your fan from Gene Berg. I have been running a Berg fan in my sandrail for 25+ years and in my Manx for 10 years. Never a problem. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
monomanx Samba Member
Joined: September 25, 2004 Posts: 715 Location: Southeast
Posted: Tue Jul 22, 2014 6:49 pm Post subject: |
vincent
With the RPMs you run on your buggy and hte amount of traveling you do, I would also recommend the welded and balanced fan.
The suggestion to purchase a new flange and other components. If the fan wallowed out, the mounting flange is likely messed up as well.
I have had the same thing happen to a fan on an engine before. Time and high revs seem to take their toll on old components. |
Posted: Tue Jul 22, 2014 7:41 pm Post subject: |
Thanks for all the feedback. Let me be clear, I want to buy the best available from CIP1. I'm not interested in saving a few $ on this item. I do have a doghouse shroud.
The question is which is better:
joescoolcustoms Samba Member
Posted: Tue Jul 22, 2014 8:21 pm Post subject: |
No one makes a better fan than the OEM. Get the welded OE and balanced fan. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Jul 22, 2014 8:23 pm Post subject: |
joescoolcustoms wrote: |
No one makes a better fan than the OEM. Get the welded OE and balanced fan. |
Done, thanks Joe!
Also ordered new spindles in hope that it's going to fix my wheel bearing issues. I think they are bad again.
We'll get a list of things to work on for MOTB. |
