tlkolrod Samba Member
Posted: Wed Jul 23, 2014 5:06 am Post subject: Headliner instalation questions |
Good morning folks, My 69 needs a new headliner and I was looking at the different kinds. Original style , one piece style, the "fast" style. I want to speak to someone who has put one it.(any kind) Not a professional but a DIY guy/girl who did it him/her self in the driveway or garage. I need to know what tools are needed and what to do first and any tips you may have.
Thx in advance for the Samba support
Toby
Gettysburg area of PA |
smokey503 Samba Member
Joined: October 01, 2010 Posts: 713 Location: Ridgefield Washington
Posted: Wed Jul 23, 2014 10:26 am Post subject: |
I installed the black one from jbugs into my old bug by myself. Did this in the winter time and would of been ally easier when warmer.
Remove old headliner. Save the views and plastic end pieces, clean them and set aside.
Go buy a few hundred binder clips from office Depot
Go buy really good adhesive spray
Scrape clean all glue residue
Above does bend clips back slightly
There is a cardboard trick to put in the clips you bent back above the doors. Search for cardboard trick.
Duh! Make sure all windows are taken out, except the door windows.
Install the bows into headliner,
Start installing bows with liner into car.
Have a friend go to the back you at the front and position the liner in place
Once it's set where you like, break out the clips and start clipping away
From now you just need to heat and stretch the liner into shape starting to glue.
You and a friend should be able to do this in a couple hours on a nice warm day including putting the windows back in.
It's really not that hard to do a good job. Just take your time and use lots of the clips to get a tight fitting liner.
Good luck. _________________ If a car travels the speed of light, would the headlights work? |
Posted: Wed Jul 23, 2014 12:34 pm Post subject: headliner |
Smokey are the binder clips u mentioned the black ones that u squeeze together to open? What size do u reccomend? I know they make tiny ones on up to huge ones. Thx for the tips
Toby |
Posted: Wed Jul 23, 2014 12:40 pm Post subject: |
I used the ones about a inch wide. You will need allot of them. _________________ If a car travels the speed of light, would the headlights work? |
