andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Jul 23, 2014 1:51 pm Post subject: Need to fix tweaked 71 Super vert body |
Heres the scoop - buddy bought a beautiful 71 super vert. Had new heater channels, rocker braces all that done years ago - only a couple hundred miles after decade long resto.
BUT top wont seal, door gaps are way bigger at the top than at bottom. Someone did an attempt to repair by simply shimming the top hinges andadding material to the seals by the vent windows.
Had a brief converstation with Bob Cook (Cookers) about this and he suggested shimming the rear supports above the rear axles. Makes sense - BUT what I am wondering is if I can also shim the front of the body? I have done several body offs on standards, but dont know Supers that well. Is this possible and where are the front mounting points. Can I get to them easily?
Obviously this has to be done carefully and measure measure measure, but I think starting at the front may be the place to start instead of the rear. Would love to hear from anyone who has done anything like this. _________________ D-Dubya Manx clone - 63 Short pan,1914.
mountainkowboy Samba Member
Posted: Thu Jul 24, 2014 12:10 pm Post subject: |
From what I've found the shimming of the rear mounts is how VW adjusted the door gaps. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
runchman Samba Member
Joined: October 03, 2012 Posts: 254 Location: Algonquin, Illinois
Posted: Fri Jul 25, 2014 4:48 am Post subject: |
Thanks - but the once again - this is a super Vert - If I do anything at the front, where are the mounts? I do want to verify that everything is as it should be there. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Jul 25, 2014 11:39 am Post subject: |
You need to adjust the rear 4 mounts, the ones behind the rear wheels and the ones under the rear seat. If you have an engine hoist(that how I did mine) make a sling around the rear bumper mounts so you can lift the rear of the body. Back the bolts out till there just barely in, lift rear of body to the right door gap........measure and shim. Bolt back down and you should be done.
From what I know (did a pan swap on mine) there is no front adjustment on a super. You can loosen bolts and lift a little and retighten, the brace on the inside that goes to the tunnel is slotted, so there is a very small amount of adjustment. _________________ Chuck in Socal
78 Honda CB750K
Posted: Fri Jul 25, 2014 5:20 pm Post subject: |
Question on the shimming - you are shimming all 4 locations (2 under the seat and the 2 above the axle)? You kept the rest tight? Then lifted the rear and held it there- inserted shims and cranked it back down - How bad was the door gap off? I don't have the car here, but I am guessing 3/8" wider at the top. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Jul 25, 2014 8:41 pm Post subject: |
That's the general idea. Mine wasn't that far off, the ones under the rear seat.....no shim, behind the tires, just over a 1/4". My gap is dead even top to bottom now.
Once you get the gap right, you will see where the shims are needed. Maybe all 4 places or maybe just the rears ones. _________________ Chuck in Socal
78 Honda CB750K
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Jul 25, 2014 9:17 pm Post subject: |
andk5591 wrote: |
Thanks - but the once again - this is a super Vert - If I do anything at the front, where are the mounts? I do want to verify that everything is as it should be there. |
Convertibles never changed even with Supers, the body adjustmangs are still the same as a 50's VW Convertible. _________________ Good Luck
Al |
Posted: Sat Jul 26, 2014 4:19 am Post subject: |
OK cool - once again - I know standards pretty well, but never had a body off of a super, so was not familiar with how it mounted in the front and if I had any place there to shim if needed. Having him bring the car over in a couple weeks.
Have to tell ya - when I first saw the car before he bought it, it was in another shop. I was amazed at the quality of the paint and just how nice the car was in general. Was restored as a labor of love. But the mechanic working on it was trying to figure out why the top wouldnt pull down the whole way and why the vent/windshield fram seals werent mating up. Thats when I noticed the door gaps being way off. I thought the only way to fix it was to cut it apart and reweld it. Apparently he shimmed the top door hinges so it didnt look as bad and added material to the vent seals.
Then after my buddy bought it (didnt know it was the same car), I was half sick when I realized what car it was. You have no idea how happy I am that I should be able to fix it for him.
Thanks all and will post the end result when done. _________________ D-Dubya Manx clone - 63 Short pan,1914.
