winchin73blazinbaja Samba Member
Posted: Thu Jul 24, 2014 8:09 am Post subject: FOA shocks. |
http://www.mooreparts.com/6747-AC598500*/
also if anyone has cheaper prices for a full 3x3 kit or any other suggestions i am working on placing 33x10.5 inch tires on my baja bug. it is a 74 (despite my name the guy i bought the car from had it posted as a 73 and i made this account in order to ask some questions prior to purchasing it... but that is a whole story of its own)
I have a flexible budget but obviously the less i have to spend the better.
any input? i have read as many threads as i could find here and other places on the net just want to make sure for myself as i am rather new to the volkswagen scene.
Last edited by winchin73blazinbaja on Wed Aug 13, 2014 9:57 am; edited 1 time in total |
HERC Samba Member
Posted: Thu Jul 24, 2014 8:29 am Post subject: |
A cage and shock decisions _________________ Herc |
Posted: Thu Jul 24, 2014 8:34 am Post subject: |
i am not quite sure what you mean?[/quote] |
HERC Samba Member
Posted: Thu Jul 24, 2014 8:35 am Post subject: |
You must relocate shocks from the 3x3 arms to the inner roll cage.
Posted: Thu Jul 24, 2014 8:39 am Post subject: |
oh ok! as of right now there is no rollcage. that is one of the upcoming upgrades. i am not planning on racing or jumping this. just taking it out on trails. I am going with 33's for added ground clearance. and as of right now if i go with 33 i am hitting 1.5-2" inches into the fender well without suspension travel. so the 3x3 should put me out far enough. as far as shock mounts are concerned could i run a steel brace up from the frame and bolt onto that versus having to hook to a cage? |
Posted: Thu Jul 24, 2014 8:40 am Post subject: |
also that is a sweet suspension setup |
Posted: Thu Jul 24, 2014 8:42 am Post subject: |
if this is yours could you post a picture of where it attaches to the roll cage? |
2trackrat Samba Member
Joined: July 07, 2014 Posts: 27 Location: lansing mi.
Posted: Thu Jul 24, 2014 9:07 am Post subject: |
If the goal is ground clearance? Try adding wheel offset and high clearance fenders to make the 33's fit I like easy and cheep. just thought. |
it is weird that the link is not working i will post another one |
Posted: Thu Jul 24, 2014 9:10 am Post subject: |
i would need about 3 inches of offset to make them fit. i believe. the 31X15.5 inch terra tires that i have mounted on steel rims are only about 2" into the rim. so they clear the torsion bar and yes ground clearance is all i am trying to achieve.
Last edited by winchin73blazinbaja on Thu Jul 24, 2014 9:35 am; edited 1 time in total |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Thu Jul 24, 2014 10:45 am Post subject: |
If you do end up using the kit maybe let us know how it works for you. I'm considering buying the same kit some time down the line. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
Posted: Thu Jul 24, 2014 11:23 am Post subject: |
i am truly thinking of going with the #3 kit on the dansperformance website that includes the fox shocks. having a suspension like that would put me ahead of most of the baja bugs in my area. most of the ones in my area are running stock or near stock suspension setup with 31" tires being the largest i have seen so far. i am not a big fan of being the same or near the same as someone else. |
Jcr. Kat Samba Member
Joined: November 09, 2012 Posts: 180 Location: san diego ca.
Posted: Thu Jul 24, 2014 12:07 pm Post subject: |
Kit #3 is good but the shock is to short, better if it came with a 14 in.shock. |
Posted: Thu Jul 24, 2014 12:55 pm Post subject: |
Would I be better off with kit 2 and buying some 14 inch shocks seperately? |
HERC Samba Member
Posted: Thu Jul 24, 2014 1:40 pm Post subject: |
There's also the front to think about. Once you push the rear back and out, you'll need to address what will now be a narrower front end. _________________ Herc |
Posted: Thu Jul 24, 2014 2:24 pm Post subject: |
Yes kit#2 will work and find some used shocks and don't jump to far ahead of your self now your going need a cage to mount the shocks and extend the front end maybe you should get a cage first. |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
Posted: Thu Jul 24, 2014 7:23 pm Post subject: |
i am actually going to fab some shock mounts that will jump from the frame through the floor boards and hook just through the floor with sheet metal covers over them so they do not leave openings in the car. i will try to draw something up within the next week and post a pic. this is going to be about a 2 month project probably with the way my work schedule has been lately. |
