74 Superbeetle Samba Member
Posted: Thu Jul 24, 2014 5:53 pm Post subject: Yet More Brake Problems!!!!!!!!!!!!!! AHHHHHHHHHHHHH |
Someone help before I beat my bug to death!
Everyone is probably getting sick of me writing in with my brake problems but I still can't get them to work.
Ok here is what I replaced
All rubber lines
Passenger wheel cylinder
Master Cylinder
Front and back shoes.
I adjusted the shoes in tight against the drums and now the drums can't turn.
I push on the brake pedal and it just about hits the floor (light brake feeling about a inch before the floor)
I pump the brake pedal a few times and then hold it tight.
Someone else then opens the bleeder (has a hose hooked to it going to a jar)
We bleed it for a while, go through about 4 reserve tanks (never letting it get below half) and then when there is no more air we move to the next wheel.
We are starting with the closest to the master cylinder (I was told to start there) and I have done each wheel probably 10 times and yet there is not difference in the brakes.
If I pump the brakes a few times it gets a little better.
The bug is parked on clean cement and there isn't a drop of fluid anywhere. I pressurized the reserve tank for several days and it did not leak a drip. But I am wondering if I am sucking in air from somewhere?
This isn't the first time I have done brakes, I did my '81 Chevy 1 ton pickup and I didn't have much trouble at all.
But for some reason I can't get this bug.
I have been bleeding these brakes for about 3 hours a day for the past week.
Any ideas would be much appreciated.
Thanks |
Zundfolge1432 Samba Member
Posted: Thu Jul 24, 2014 6:10 pm Post subject: |
Ck the hard line running from the master cylinder through the car to the three way fitting in the back. This line develops pinhole leaks because of being in a wet damp environment. Sometimes overlooked because the fluid goes into the tar board or carpet and goes unnoticed . Another thing to ck is free play at the master cylinder rod. Bentley manual says never alter this setting but you and I know after all these years the cars have been dicked over sometimes pedal clusters replaced,stops moved because of pans replaced etc,etc. |
dasdachshund Samba Member
Joined: March 29, 2010 Posts: 728 Location: Vancouver, WA USA
Posted: Thu Jul 24, 2014 6:36 pm Post subject: Re: Yet More Brake Problems!!!!!!!!!!!!!! AHHHHHHHHHHHHH |
74 Superbeetle wrote: |
.........Any ideas would be much appreciated. |
I just went through an ordeal getting my neighbor's '63's brakes to work. I did everything bleeding wise, 3 master cylinders, etc. and nothing helped. Mine turned out to be someone had changed the length of the rod that goes into the master cylinder and it wasn't getting enough stoke to push fluid through the system. Just a thought.
-dasdachshund |
djghia Samba Member
Joined: May 08, 2006 Posts: 179 Location: Springfield, MO
Posted: Thu Jul 24, 2014 6:54 pm Post subject: |
Bleed from the farthest first and work your way closer.( RR, LR, RF and then LF) See if that helps, something I learned probably 40 years ago! Also remember; pressure(pumped up), then loosen bleeder, down(peddle of course), tight(bleeder). Repeat until no air comes out. I can still hear a couple of guys I worked with repeating this mantra in my head! Good luck! Dave J _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
Government Samba Member
Joined: July 10, 2014 Posts: 87 Location: Crestline, California
Posted: Thu Jul 24, 2014 7:07 pm Post subject: try this |
You are not adjusting it still... Just because the drums have stopped turning does not mean you have both sides adjusted all the way out. If you were, you would not have to pump pump pump hold anymore, you would barely have 3 in. Of travel if are adjusted to the max.
Not saying that you didn't adjust, just saying you can go more if you are still going all the way to floor, if... The circuit is closed that is. I was where you are now last week, bled dozens of Mer'ican brakes before. These are not Yankee brakes... Follow the instruction given by wise folks here. I would have already wracked my brain if not for this site. Adjust till you can no longer adjust on both stars per wheel. The pedal WILL feel solid and not go to floor when there.
Also make sure you have taken slack from brake actuator rod on pedal, new MC nave have majorly different rod depth before engaging.
Good luck. Step away and take some brakes to ponder situation if you get frustrated. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Fri Jul 25, 2014 3:57 am Post subject: |
There are literally hundreds of good threads on here about brake bleeding.
1) Adjust your drums ALL THE WAY TIGHT. This is the only way brake bleeding on a VW should start, IMO.
2) Pressure bleed your brakes.
3) Adjust your drums to spec.
4) Done.
It takes less than $20 in parts to build a pressure bleeder out of a garden sprayer from Walmart, a scavenged reservoir cap, and some rubber hose. You will be done with your brakes in thirty minutes. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Jul 25, 2014 4:50 am Post subject: |
djghia wrote: |
Bleed from the farthest first and work your way closer.( RR, LR, RF and then LF) See if that helps, something I learned probably 40 years ago! |
This only applies to single circuit master cylinders.
As mentioned above - make sure there is a small bit of play before the brake push rod makes contact with the master cylinder. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Fri Jul 25, 2014 5:02 am Post subject: |
Ok, thanks for all of the tips.
I guess I'll give it another go.
Thanks again |
Jeff_Birt Samba Member
Joined: June 06, 2012 Posts: 315 Location: Rolla MO, United States
Posted: Fri Jul 25, 2014 6:22 am Post subject: |
Joey wrote: |
djghia wrote: |
This only applies to single circuit master cylinders. |
No, it does not only apply to single circuit systems! The main idea applies to every system.
To be as generic as possible in the description; you want to start at the brake furthest away from the master cylinder and work to the closest. On a single circuit system on a left hand drive vehicle that is as written above. A right hand drive you would do LR, RR, LF, RF of course.
On a dual circuit you could do the front pair of brakes first and then the rear, again working from furthest away from the master cylinder to the closest. So on a left hand drive vehicle if you started at the front you would do the FR, FL and then move to the RR, RL.
Rather then remembering all the different way you 'could' do it based on single/dual circuit right/left hand drive the general rule of starting the furthest away from the master cylinder and working closest to it always works. |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Fri Jul 25, 2014 6:31 am Post subject: Re: try this |
Government wrote: |
adjust the brakes
adjust the brakes
all 8 of them
do it as many times as you have bled
if you would have adjusted the brakes you would have never come to this point |
gargamel Samba Member
Joined: December 20, 2011 Posts: 693 Location: Orange Grove, Texas
Posted: Fri Jul 25, 2014 9:29 am Post subject: |
Sorry to hear you are having ongoing brake issues. Try the suggestions above and check the brake push rod for proper length.
What worked for me was the good ole gravity pull method. I also used some clear fish tank line on the bleeder down to a glass jar. Made viewing bubbles easy, as I bled. I had the wife help pump the brake pedal, in the meantime. It is very low tech but it worked for me. If any of those parts are not on tight, then it is all in vain. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Jul 25, 2014 9:59 am Post subject: |
See if your distance of the Master cylinder brake rod at the pedal is correct. You should--when pushing on the brake pedal by hand--have only 1/4 inch of freeplay before you feel resistance. This 1/4 inch freeplay equals 1 mm at the opposing, inner, tip of the adjustment rod.
If not 1/4 inch at the pedal, loosen the rod's lock nut and turn the rod all the way in until it just stops. Now back off one half turn. Your pedal should now show the 1/4 inch freeplay. If not turn the rod in or out to get it (just tiny increments). Tighten the lock nut when done.
Tim |
fred69vert Samba Member
Joined: August 17, 2007 Posts: 2200 Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
Posted: Fri Jul 25, 2014 10:02 am Post subject: |
I bought one of these:
http://www.harborfreight.com/brake-fluid-bleeder-92924.html
Sucks the fluid (and air) through the system. Works great. _________________ I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi" |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Posted: Sat Jul 26, 2014 12:49 am Post subject: |
STOP ALL BLEEDING
concentrate on the actual adjustment of all 8 shoes
adjust them
adjust them
try the pedal and adjust them all again
do like everybody else and install disc brakes on front
then you have 2 wheels in adjustment by the fact of disc brakes
remember the parking brake
that works when the rear brakes are in adjustment |
Posted: Sat Jul 26, 2014 5:08 am Post subject: |
Thanks all for your time,
I just checked the brake push rod and it seems to be adjusted correctly, I will readjust the shoes tight and I will see where that gets me.
Thanks again for the info |
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Sat Jul 26, 2014 6:11 am Post subject: |
Stupid question.......when you 'pump up and hold' and someone else opens a bleed screw, do they then close the bleed screw after the peddle goes to the floor, while you 're-pump'? Just wondering.
mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
Posted: Sat Jul 26, 2014 6:55 am Post subject: |
vernonc wrote: |
mort |
Close the bleed valve, when the peddle is depressed down. Otherwise you can get air back in. |
Posted: Sat Jul 26, 2014 7:06 am Post subject: |
gargamel wrote: |
vernonc wrote: |
mort |
Yes, I know that but I was wondering if the OP (or many others) knows that.
Posted: Sat Jul 26, 2014 7:19 am Post subject: |
Untill they (the SHOES) are adjusted
you will not get any pedal resistance |
