albinogek Samba Member
Joined: January 31, 2011 Posts: 51 Location: LUBBOCK,TX
Posted: Thu Jul 24, 2014 9:22 pm Post subject: Positive Battery Cable |
I am new to all this, so i'll apologize for my ignorance. I am planning on replacing both negative & positive battery cables. The negative cable is a no brainer, but the positive is a different story. I am prettysure that the starter is on the passenger side of the car because of where the battery is located, but want to know if it is hard to get to. If any of y'all have any pictures of the location & what size the nut is, I would greatly appreciate it. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Jul 24, 2014 9:45 pm Post subject: |
The starter is relatively straightforward to get to mounted on top of transmission on passenger side (USA). I believe you'll need your 13mm wrench. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Jul 25, 2014 7:17 am Post subject: |
Just a couple tips.
FIRST, make sure you have the battery disconnected BEFORE you go underneath and remove the positive cable from the starter! Otherwise fireworks may ensue.
Next, where the positive cable mounts to the starter, there should be a nut under the cable end and another on top to secure it. You want to also have a thin wrench to hold that lower nut. If you don’t, sometimes when trying to get a cable off that is exceptionally tight, or been there for a long time, you can actually turn that threaded stud that the cable mounts to. That can damage the internals of the solenoid. Same goes for when it’s time to tighten the new cable up you don’t want that stud to turn.
PBblaster is a pretty good penetrating oil that may help on that stud to loosen the nut.
Before you reassemble, use a small wire brush to make sure that stud is clean and then make sure you get the top nut tight or else you may experience some poor connections and arcing there.
Bicycle shops are a great place to find thin wrenches. Or just dig a cheap Taiwan wrench out of the tool box and spend some time in front of the bench grinder. _________________ Mother Nature is a Mean Evil Bitch! |
grandpa pete Samba Member
Posted: Fri Jul 25, 2014 8:00 am Post subject: |
" the negative cable is a no brainer "
Grounding is a major problem ; especially with lighting .
I run a long negative directly to the bolt that secures the starter
It took less than a minute to search "starter" in the gallery ; several photos will show you what you are getting into without leaving your couch...Once you learn how to use these tools you can fix anything
in the second photo , The two small red wires are not original equipment ; probably to secondary fuse panel...aso note that positive cable is red in the first photo and black in the second photo ;
safety first ; use red for positive...it makes a real difference at the battery when jumping cables late at night
_________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Last edited by grandpa pete on Fri Jul 25, 2014 9:12 am; edited 5 times in total |
Posted: Fri Jul 25, 2014 8:44 am Post subject: |
Can you see the nut that is underneathe pretty easily? I assume that it is 13 as well? Is there anything that I need to move out of the way in order to reach the starter? |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Fri Jul 25, 2014 9:15 am Post subject: |
Nothing else needs to be removed to get access to the starter, aside from the passenger rear wheel which will make the job easier. _________________ 1958 Karmann Ghia owner |
jjohnson67 Samba Member
Posted: Fri Jul 25, 2014 10:30 am Post subject: |
JACK STANDS BEFORE getting under any vehicle. Only takes 1 time. |
Posted: Fri Jul 25, 2014 10:36 am Post subject: |
Planning on using some ramps along with blocking the front wheels with some chokes that I have. Placing emergency brake along with putting car in 1st gear. Hopefully that will work....thanks for the advice. .safety 1st!! |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Fri Jul 25, 2014 6:35 pm Post subject: |
Just another small tip since you said you are going to use ramps to get the car high enough to get under easily....check the ground strap on the tranny nose cone at the same time. Clean and refasten the bolted connections - this is the main ground connection from engine to the chassis, so it takes the full load of the starter current back to the battery. Replace the strap if it's at all corroded or frayed.
Bad ground/chassis connections makes for some strange electrical faults, so it's worth checking this one whilst you have the car high enough to do it easily. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jul 25, 2014 6:42 pm Post subject: |
Cleaning the mounting edge of the starter and the transaxle area the starter mounts to will help ground it better. Add some dielectric grease to the clean surfaces to keep corrosion away for as long as possible. _________________ In Stereo, Where Available! |
Posted: Fri Jul 25, 2014 8:27 pm Post subject: |
Ausiebug are there any pictures of the ground strap you are talking about near the nose of the tranny? |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Fri Jul 25, 2014 8:36 pm Post subject: |
albinogek wrote: |
That is at the front of the transmission. _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________
Thanks BWD !! That was super fast !!! |
Posted: Fri Jul 25, 2014 8:38 pm Post subject: |
Is that mounted from the tranny to the starter in this pic? The first pic looked different. |
BWD Samba Mailman
Posted: Fri Jul 25, 2014 8:39 pm Post subject: |
albinogek wrote: |
The search button is your friend! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
BWD Samba Mailman
Posted: Fri Jul 25, 2014 8:40 pm Post subject: |
albinogek wrote: |
Transmission to chassis. _________________ BWD
JHC
member #2850
1966 Beetle
Posted: Fri Jul 25, 2014 8:44 pm Post subject: |
I'm on my smartphone & every time I try to search something it doesn't allow me to go to that particular section. For instance if I click on gallery it doesn't allow me to go to the sub menu, it just pulls it up. Very annoying. |
Posted: Sat Jul 26, 2014 7:52 am Post subject: |
I had a feeling I was leaving myself wide open for that one! Thanks alot grandpa Pete!! Lol!! |
